Old 10-31-2007, 03:47 AM   #1
si12j12
Member#: 99697
04 wrx [wrb]
ni stage-ah san!
Default flat flange dp vs bellmouth vs divorced ... power gains?
I have 04 wrx and Im planing on going stage 2 i currently at stage 1 with b&b catback . Im thinking i will probably be stuck at stage 2 until i get turbo and supporting mods ,my question is ,will i see noticeable power with a dp that is divorced or bellmouth compared to flat flange type dp like hks ?
I would be running the stage 2 generic map from cobb until i get tunned , Im looking for dp but not shure if gains will be much to invest on a more expensive dp like cobb or just buy a cheap hks dp?
Any input would be greatly apreaciated
si12j12 is offline   Reply With Quote
Old 10-31-2007, 07:13 AM   #2
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
At Stage 2 levels, you won't notice a power difference between flat plate/BM/DWG pipes.
But since you're already thinking turbo swap, go ahead and buy a BM or DWG. If you want LOUD turbo spooling noises, get the DWG.
Spenk is offline   Reply With Quote
Old 10-31-2007, 09:52 AM   #3
Mr.Sparkle
Member#: 83725
2015 WRX
I believe that COBB tuned the stage 2 map using a Bellmouth DP so your better off going with that. I did check the website and didn't see that noted in the map notes, but I thought I read that somewhere.
Mr.Sparkle is offline   Reply With Quote
Old 10-31-2007, 12:54 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...there is a HUGE difference in 'power gains' and throttle response....and most of the 'power gains' that a good DW dp are made below where the vast majority of dyno d000ds start their pulls, anyway
there is good resaon that so many of the top companies...like Prodrive and APS make DW dp's
ya want a drag car....get the TXS bellmouth
ya doin an EW...get the hks
ya doin an IWG street car and DD it......
Old 10-31-2007, 01:23 PM   #5
AMG Eater
Member#: 44821
Blue/Gold
what does EW ,IWG and DD mean??
AMG Eater is offline   Reply With Quote
Old 10-31-2007, 01:47 PM   #6
SUBOO5
Member#: 85825
08 EVOH10
pretty sure this is what it means
ew- external wastegate
iwg- internal wastegate
dd- divorced downpipe
frankly, it all depends on what route you are going, if your running external wastegate, go with hks and if your running a bigger than 20g turbo, id say go with the aps downpipe, one of the best divorced downpipes out their.
SUBOO5 is offline   Reply With Quote
Old 10-31-2007, 05:45 PM   #7
AMG Eater
Member#: 44821
Blue/Gold
So, unless you a running a bigger than stock turbo...you won't see much differance between a flat plate dp to bellmouth or divorced????
Old 10-31-2007, 07:10 PM   #8
Hiflyer731
Member#: 30307
2008 FXT
the biggest difference would be between a flat plate and either a bellmouth or divorced. Just buy a good used divorced or bellmouth and call it good. Unless you're trying to pull out every last bit of power and running huge turbos then the bellmouth vs divorced design isn't a big deal.
Hiflyer731 is offline   Reply With Quote
Old 10-31-2007, 08:19 PM   #9
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
just go EWG!
djerickd is offline   Reply With Quote
Old 10-31-2007, 08:49 PM   #10
ajrally19
Member#: 85650
2006 WRX
ajrally19 is offline   Reply With Quote
Old 10-31-2007, 10:00 PM   #11
si12j12
Member#: 99697
04 wrx [wrb]
ni stage-ah san!
ive been thinking and i really just want to stay at a reliable stage 2 for the moment , i think i might just buy a used dp like helix or titek or something like that , and get a tune . But ewg will def be something i would want in the near future.
Old 11-01-2007, 12:32 AM   #12
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
...and if you go DWG, I'd strongly recommend the Crucial unit. Beeyootifull piece w/great fitment. I've never been anything but ecstatic with their stuff.
FromageTheDog is offline   Reply With Quote
Old 11-01-2007, 01:22 AM   #13
02redwagone
Member#: 87067
02 Old but tasty
SRP
Or Maddad. Mine is perfection.
02redwagone is offline   Reply With Quote
bellmouth vs. divorced wastegate DP bjonesy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-03-2007 08:56 PM
Divorced DP vs Bellmouth DP...? SiriX Newbies & FAQs 21 03-17-2006 03:05 PM
Flat flange DP and boost creep mapleleaf Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 02-06-2006 09:32 AM
Donut Flange DP to flat-flange midpipe? Panic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-07-2005 10:01 PM
Donut Flange DP to flat-flange midpipe? Panic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-06-2005 10:27 AM
