Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 01-21-2002, 12:54 AM   #1
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Default Tumble Generation Valve Info
I need some...
What does it do and when?
As much info as possible is needed.
All I know is that it is an emmision device. They are closed when the car is cold and open after the normal operating temp is reached or until the TPS goes pass certain point.
Do they stay open all the time?
Do they do anything for idle control?
-Alex
Imprezer is offline   Reply With Quote
Old 01-21-2002, 01:00 AM   #2
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
I know there are a ton of engine codes relating to their operation.
Thinking about removing them when you go fully standalone, I take it? Would you use a different manifold, or are they between the manifold and the head? I haven't had my manifold off, so, I don't know.
take care,
rob
Conduit is offline   Reply With Quote
Old 01-21-2002, 01:06 AM   #3
d00f
Member#: 6000
2000 GC8 STi V4 swap
BRP
I did a lot of reading when someone proposed pulling these out. Not only do they improve emissions but they also give you more low end torque. The valves give your intake charge a higher velocity and better mixing in the cylinders.
Removing them will give you more power at the top end since there is less restriction in the intake. So you made a decision, low end torque for high end gain?
-Michael
d00f is offline   Reply With Quote
Old 01-21-2002, 01:23 AM   #4
savka
Member#: 12737
MY02 wagon 325/300
MBP
"...tumble generators" in each of the engine's four intake runners. The tumble generators are basically block-off plates placed just upstream of the fuel injectors, which create a vortex in intake air, promoting cleaner burn and leaner air-fuel mixture during cold-start and low-speed operation. The valves, which look and operate like throttle plates missing one side, open gradually beginning at 3000 rpm to allow intake air to flow freely..."
http://irvinesubaru.com/wrx/sccweb.html#bot
sav
savka is offline   Reply With Quote
Old 01-21-2002, 01:32 AM   #5
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Default Re: Tumble Generation Valve Info
Originally posted by Imprezer
I need some...
-Alex
If you email me I will bouce a PDF file to you with info about the TVs..
CT
AZScoobie is offline   Reply With Quote
Old 01-21-2002, 02:13 AM   #6
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I figure knife edging the leading edge can't be a bad thing. It shouldn't impede the intended operation, and should introduce less restriction when it matters (full open)
I thought someone was going to take them out and report back with butt dyno results.
Alex, if you search back for into, there was a prolonged thread on it (3+ pages) discussing removing/knife edging, but nobody had the wherewithall (or the downtime) to do it. Even so, there were some good discussions there.
Concillian is offline   Reply With Quote
Old 01-21-2002, 03:12 AM   #7
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
With the PEMS we are usuing - it seems the stand lone ecu runs everything we neeed
Therefore I suggest - that out the TVG part of the manifold and send it to a speed shop with a flow bentch - eg www.marrenmotorsports.com www.injector.com etc.
They can effectively remove that restrictive c rap right away !!!
alfriedesq is offline   Reply With Quote
Old 01-21-2002, 03:24 AM   #8
8Complex
Member#: 922
04 FXT
Red
P1086 Tumble generator valve #2 ?? GimpWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 03-31-2006 05:17 AM
P1088 Passenger Side Tumble Generator Valve Wrxified Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-04-2003 07:18 AM
P1088 Passenger Tumble Generator Valve Wrxified Service & Maintenance 0 06-03-2003 07:41 PM
Tumble Generator Valve - when do they swith off? rotorbaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 10-25-2002 08:11 AM
Check engine. Tumble generator valve EPD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-12-2001 11:47 AM
