Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 10-31-2007, 08:16 PM   #1
Zspectrum
Member#: 152933
CT9A
TB
Default Need tire help - widest tire on 17x8 wheel?
I'm currently running falken Azenis rt615. 235/40/17
my tires are gonna be replaced my kuhmo mx ecsta what's the widest rubber I can run on my 17x8 wheels without it looking weird or having any bowing. I was thinking 245/40/17 or can I run 255/40/17?
Zspectrum is offline   Reply With Quote
Old 10-31-2007, 08:23 PM   #2
Zspectrum
Member#: 152933
CT9A
TB
move to tire and wheel sorry posting from iPhone
Old 10-31-2007, 08:45 PM   #3
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
What do you use the car for?
Old 10-31-2007, 09:36 PM   #4
nismofly
Member#: 163063
1989 240SX
2006 WRX Limited OBP
personally i wouldnt go wider than 235 on an 8, some 245s will be rated to go on an 8 inch wide some wont, but it will probably feel spongy regardless depending on the tire you get
nismofly is offline   Reply With Quote
Old 10-31-2007, 09:39 PM   #5
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I think a 245/40-17 will fit fine. My last 2 sets of track tires were 245/40-17 on a 17x8 and worked great. A 255 would be pushing it.
Old 10-31-2007, 09:58 PM   #6
The Deliverator
Member#: 42376
2006 92x Aero
235's worked nicely on my 17x7.5's.
I'd have no problem at all putting 245's onto 8" wide wheels.
The Deliverator is offline   Reply With Quote
Old 11-01-2007, 02:31 AM   #7
Zspectrum
Member#: 152933
CT9A
TB
Car will be used for road courses, and daily driver. I can get the kuhmo ecsta mxs locally. But has anyone run the 245/40/17 on an 17x8 wheel? If you have, what tire pressures did you run for street, as well as on the track. Im gonna order these tires tomorrow.
Old 11-01-2007, 07:45 AM   #8
gregr01
Member#: 49333
04 STi
java pearl black
255/40 will fit and look fine... (friend's ride, not mine, 17x8 Rotas, gharari is his screen name):
615s are unusually wide for their nominal size, so I imagine the MXs would be even better.
If you're not stock height you may run into clearance issues either autox or track, but shouldn't on the street.
gregr01 is offline   Reply With Quote
Old 11-01-2007, 09:09 AM   #9
Zspectrum
Member#: 152933
CT9A
TB
Those look kinda bowed, Im dropped on s techs, or will be saturday. I think im gonna stick with 245/40/17, thanks for posting bro
Old 11-01-2007, 09:29 AM   #10
waktasz
Member#: 86356
2015 s1000r
wheelie monster
All 17x8s
235
245
275
waktasz is offline   Reply With Quote
Old 11-01-2007, 10:50 AM   #11
Butt Dyno
Member#: 17301
is the "dark side"
Old 11-01-2007, 11:07 AM   #12
Zspectrum
Member#: 152933
CT9A
TB
Originally Posted by ButtDyno View Post
Im assuming the sad banana is crying because of the stechs. there only temporary, coilovers are coming.
Old 11-01-2007, 01:19 PM   #13
Back Road Runner
Member#: 60082
2004 Forester STI
Lol, S-Tech is like a swear word around here.
How wide a tire can fit in your wheel well before rubbing? 235, 245 is not a problem on an 8" wide rim. Whatever you use still has to fit without rubbing though.
Old 11-01-2007, 01:24 PM   #14
Zspectrum
Member#: 152933
CT9A
TB
hahaa yeah i got that impression, so they kill my ride quality. Already sucks who cares. Im curious to see what will rub, I guess ill figure it out tomorrow when the springs go on. I cant imagine a 245 which is .5 I believe wider rubbing, its a slightly taller tire so its not a big deal there. We shall see.
Old 11-02-2007, 02:37 PM   #15
wanalaugh74
Member#: 148922
2004 Sti
what about 235/45/17?? i only ask b/c the all season tire i want only has the 45 profile. It's for a stock Sti BBS rim. Thanks.
wanalaugh74 is offline   Reply With Quote
Old 11-02-2007, 02:42 PM   #16
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Would be fine. A better choice for an STI than a WRX because it helps stretch out the gearing a little.
Old 11-02-2007, 03:08 PM   #17
Proxy One
Member#: 130959
06 OBP STI
94 Chaste White Rx7
What about 245/45/17 on stock sti wheels with Eibach springs. For road courses and will probably be Falken RT615's
Proxy One is offline   Reply With Quote
Old 11-04-2007, 03:05 PM   #18
gregr01
Member#: 49333
04 STi
java pearl black
You need to be very selective in your tire choice with Eibach springs (assuming ProKit). I rubbed 225/45/17 both front (inner fender liner) and rear (outer) on max-g turns at track days, and occasionally autox. 245/45s are considerably taller, though 245/40 is a great choice with that spring (it's a tad lower than OEM in most fitments), though you still may have issues with the inner fender liner, depending on your camber.
Caveat: I was on 17x8.5 +48 wheels, and an 04 vs your 06.
I've long since ditched the Eibach springs (now running Zero 2Rs). I did like them for their street ride and they were satisfactory for autox and track days on street tires, but just too limiting in what tire I could run.
225 tires on 17x8 wheels lotarg Tire & Wheel 4 09-27-2007 07:46 PM
How big of tires on 17x8 wheels? Ntercooled Tire & Wheel 10 12-15-2006 10:09 AM
whats the widest tire we could use on 17x8.5 aceking66 Tire & Wheel 16 05-02-2005 04:02 PM
245's on 17x8 wheels on WRX? aakrusen Tire & Wheel 18 03-15-2005 02:10 PM
widest tire you can mount on stock wheels? casualsurfer Newbies & FAQs 2 05-16-2004 10:41 AM
