Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Vendor Classifieds
Old 10-31-2007, 10:55 PM   #1
Ultimate Collision Center
Vendor Sales Rating: (35)
Member#: 69072
Default Prosport Gauges...
Prosport Gauges is the largest manufacturer of performance gauges in Taiwan and we are proud to roll out the newest Line of PREMIUM Gauges featuring fully
programmable Warning & Memory functions. These new Gauges use Precision Stepper Motor Driven pointers for exceptional accuracy. Coupled with 2nd generation Electric Senders for unprecedented precision. This newest series of gauges features a daisy chain wiring system to make installation easier. For multiple gauge installations only the first in the series needs to wired for power, ground & Color choice. Each additional gauge can be powered using the supplied link wire.
Our full line of 52mm Gauges features Exhaust Gas Temperature (EGT), Boost, Oil Pressure, Fuel Pressure, Water Temperature, Tachometers, Digital Tachometers, Shift Lights, Air Fuel Ratio Gauges, Volt, Oil Temperature & Fuel Pressure. Be sure to check out 60mm Amber/White Gauges which by our unique design will also fit into a 52mm pod!
Be sure to check out our mounting options, Shift Lights, Digital Gauges & Installation Accessories.
Drawing from over 30 years experience and constantly utilizing the latest technology and equipment Prosport has led the way in the development of race car gauges in Asia. Prosport continues to break new ground by offering an affordable performance gauge with the hottest design and exceptional quality that exceeds gauges that cost three times as much. Each Gauge can be purchased & installed independent of each other.
"We Don't Need No Stinkin' Controller"
Now you can have the look and performance that you want at a fraction of the price.
All of our products are tested and inspected 100% before they are shipped and are backed by our exclusive No Hassle full one year warranty.
All of our Electric Performance Amber, Green & Blue series gauges utilize our exclusive quick connect wiring system to make installation easier for you.
Super Blue Gauges-52mm
Boost Gauge (ELECTRICAL) - Super Blue 52mm-Pointer sweep $54.50
Boost Gauge (mechanical) - Super Blue 52mm $37.99
Oil Pressure Gauge (Electric) w/sender - Super Blue 52mm $42.99
Exhaust Gas Temperature - Super Blue 52mm $93.99
Oil Temperature Gauge (Electric) w/sender - Super Blue 52mm $37.99
Water Temperature Gauge (Electric) w/sender - Super Blue 52mm $37.99
Voltmeter Gauge (Electric) - Super Blue 52mm $36.50
Tachometer (in-dash) Analog 0-8000RPM - Super Blue 52mm $43.99
Air - Fuel Ratio Gauge (analog) - Super Blue 52mm $44.50
Fuel Pressure Gauge (Electric) Super Blue 52mm $44.50
Amber / White Gauges-52mm
Boost Gauge (ELECTRICAL) - Amber/White 52mm $55.75
Boost Gauge (mechanical) - Amber/White 52mm $38.99
Oil Pressure Gauge (Electric) w/sender - Amber/White 52mm $43.99
Exhaust Gas Temperature - Amber/White 52mm $94.99
Oil Temperature Gauge (Electric) w/sender - Amber/White 52mm $39.50
Water Temperature Gauge (Electric) w/sender - Amber/White 52mm $39.50
Voltmeter Gauge (Electric) - Amber/White 52mm $37.50
Tachometer (in-dash) Analog 0-8000RPM - Amber/White 52mm $37.99
Air - Fuel Ratio Gauge (analog) - Amber/White 52mm $46.99
Fuel Pressure Gauge (Electric) Amber/White 52mm $46.99
Green / White Gauges-52mm
Boost Gauge (ELECTRICAL) - Green/ White 52mm $55.75
Boost Gauge (Mechanical) - Green/ White 52mm $38.99
Water Temp. Gauge (Electric)-Green/White-52mm $39.50
Oil Pressure Gauge (Electric)-Green/White 52mm $43.99
Oil Temperature Gauge (Electric)-Green/White 52mm $39.50
Exhaust Gas Temperature -Green/White 52mm $94.99
Premium Series-With Warning & Peak Hold Amber/White Gauges-52mm
Boost (Electric) Warning & Peak Hold $81.99
Oil Pressure (Electric) Warning & Peak Hold $104.99
Water Temp. (Electric) Warning & Peak Hold $70.99
Exhaust Gas Temperature (Electric) Warning & Peak Hold $116.00
Volt (Electric) Warning & Peak Hold $69.99
Tachometer (electric) Warning & Peak Hold $70.99
Fuel Pressure (Electric) Warning & Peak $105.50
Oil Temperature (Electric) Warning & Peak Hold $70.99
Premium Series-With Warning & Peak Hold Green/White Gauges-52mm
Oil Pressure (elec.) Warning & Peak Hold $104.99
EGT with Warning & Peak Hold $116.99
Oil Temperature with Warning & Peak Hold $70.99
Fuel Pressure with Warning & Peak $105.50
Water Temp. with Warning & Peak $70.99
Boost Gauge (ELECTRICAL) -Amber/White-60mm $64.00
Exhaust Gas Temp. Gauge (electrical)-Amber/White-60mm $113.00
Oil Pressure Gauge (Electrical)- Amber/White-60mm $53.50
Water Temperature Gauge (Electrical)-Amber/White-60mm $52.50
Oil Temperature Gauge (Electrical)- Amber/White-60mm $52.50
Premium 60mm Amber/White Gauges
Boost (electrical) Warning & Peak-60mm 88.50
Oil Pressure (Elec.) Warning & Peak-60mm 110.00
Exhaust Gas Temperature (Elec.) Warning & Peak-60mm 123.99
Oil Temperature (Elec.) Warning & Peak-60mm 77.50
Water Temperature (Elec.) Warning & Peak-60mm 77.50
Misc.
Digital Tachometer 52mm $51.99
Shift Light w/Digital Tachometer - Black Case $49.99
Shift Light w/Digital Tachometer - Silver Case $49.95
Digital Air / Fuel Ratio & Voltage Gauge - 52mm $54.50
Mounting Strap - Metal- Single 52mm $9.99
Mounting Cup- Black Plastic 52mm $9.99
Oil Filter Adaptor Plate-Subaru, Honda, Ford, Mazda & Mits. $38.99
Oil Filter Adaptor Plate-Nissan,VW, Porsche, BMW & Toyota $38.99
EGT Probe K-Type 6' lead $65.00
Bosch Wideband LSU 4.2 5 Wire O2 sensor $79.99
Water Temp Sender Radiator Hose Adaptor 28mm-Purple $26.00
Water Temp Sender Radiator Hose Adaptor 30mm-Blue $26.00
Water Temp Sender Radiator Hose Adaptor 32mm-Gold $26.00
Water Temp Sender Radiator Hose Adaptor 34mm-Red $26.00
Water Temp Sender Radiator Hose Adaptor 38mm-Silver $26.00
External warning light for Premium Series gauges $20.00
3 3/4" Tachometer with shift light $47.99
Subaru Oil Galley Plug with 1/8" NPT threaded center $12.99
oil or Water Temp sender $9.50
Perfomance Oil Pressure Sender $18.50
Premium Oil Pressure Sender $33.50
Electric Bosot Sender $20.50
52mm Gauge Blank/switch Panel- $7.75
52mm Gauge hood $7.25
Please pm for package deals...
Last edited by Ultimate Collision Center; 01-22-2008 at 12:31 PM. Reason: new prices
Ultimate Collision Center is offline   Reply With Quote
Old 11-12-2007, 04:43 PM   #2
Member#: 69072
new shipment of prosport gauges...pm for best deals...
Old 11-14-2007, 11:16 PM   #3
vangstaboi86
Member Sales Rating: (42)
Member#: 119945
2004 sti
java black pearl
how much for amber color electrical boost gauge, oil, and air fuel ratio as a package... pm me
vangstaboi86 is offline   Reply With Quote
Old 11-23-2007, 07:20 AM   #4
Member#: 69072
all pms returned...
Old 11-23-2007, 02:13 PM   #5
jconaty07
Member#: 139124
pm sent
jconaty07 is offline   Reply With Quote
Old 11-28-2007, 09:32 PM   #6
subaru_west
Member#: 151373
Chapter/Region: PRSIC
2006 wrx wagon
red
hello im interesting in :
Boost (electrical) Warning & Peak-60mm 87.50
Oil Pressure (Elec.) Warning & Peak-60mm 106.00
Exhaust Gas Temperature (Elec.) Warning & Peak-60mm 120.00
Subaru Oil Galley Plug with 1/8" NPT threaded center $10.00
make me a good packages... You ship to puerto rico ? my zipe code are 00681
subaru_west is offline   Reply With Quote
Old 12-02-2007, 02:30 PM   #7
Member#: 69072
pm's returned....
Old 12-03-2007, 04:51 PM   #8
Fetteichhornchen
Member Sales Rating: (26)
Member#: 105689
2009 STI Hatch
pm'ed you
Fetteichhornchen is offline   Reply With Quote
Old 01-20-2008, 11:27 PM   #9
Member#: 69072
new shipment of Prosport Gauges...pm for best deals
Old 03-03-2008, 11:00 PM   #10
Member#: 69072
bump for more instock
Old 03-04-2008, 09:37 PM   #11
ruggedman
Member Sales Rating: (4)
Member#: 17590
2006 WRX Limited
WR Blue
PM me a price shipped for the 52mm blank. Thanks!
ruggedman is offline   Reply With Quote
Old 03-07-2008, 08:13 AM   #12
growling_boxer
Member Sales Rating: (5)
Member#: 165744
2000 LGT
2007 STi
I am interested in the following 52mm Premium Amber gages: Boost, Oil Temp, Oil Pressure, Water Temp. I'd also like the Oil Filter Adapter plate for Subaru, Water Temp Sender Radiator Hose Adapter 34mm-Red, oil temper sender, water temp sender, and one of your oil pressure senders (what is the difference between the performance and the premium?). I'd also like one cup...do you offer any other mounting options, or do I need to get those elsewhere? I'm looking for a single a-pillar mount and a dual gage bezel mount.
growling_boxer is offline   Reply With Quote
Old 03-07-2008, 05:09 PM   #13
kuks
Member#: 39753
07 OBP WRX
03 Sonic Yellow WRX
can you pm me a price for 3 of the "Premium Series-With Warning & Peak Hold Green/White Gauges-52mm?" I'm looking for boost, egt, and oil temp.
Thanks!
kuks is offline   Reply With Quote
Old 03-07-2008, 07:02 PM   #14
06njsti
Member Sales Rating: (35)
Member#: 150986
06 #001 LSB STi
whats going on with prosports wideband 02? i have 3 prosports already and wanna throw 3 gauges in my a-pillar however i have the premium gauges and i dont wanna have 5 prosport gauges and 1 other brand
06njsti is offline   Reply With Quote
Old 03-09-2008, 10:28 PM   #15
Member#: 69072
all pm's returned, as for the wideband i haven't heard of any updates of when it will be released. Soon as i know i will be sure to post.
Old 03-19-2008, 08:07 PM   #16
Member#: 69072
prosport gauges...
Old 04-02-2008, 10:35 AM   #17
Deity
Member#: 3443
0102 2.5 RS & WRX
STM and PSM
Deity is offline   Reply With Quote
Old 06-06-2008, 01:13 AM   #18
Member#: 69072
New shipment of Prosport Gauges...PM me for the best deals.
__________________
[B]
| Monstaliner- Bedliner | MetalCloak- Jeep Parts |
[/B]
ATi Gauge Pod & Prosport Gauges? erik hagstrom Car Part Reviews 14 07-20-2012 06:25 PM
Wiring for prosport gauges? NWSTi-wa Electrical & Lighting 5 06-16-2010 04:54 PM
FS : Pair of Prosport gauges...BNIB Pacobeagle Interior/Dressup/Audio & Security 14 06-07-2010 06:53 PM
Most important gauges?? also prosport gauges question??? litowrx Newbies & FAQs 2 08-11-2007 12:27 PM
Prosport Gauge and custom center gauge pod jeeps1998 Interior & Exterior Modification 7 10-09-2006 03:47 AM
