Old 11-01-2007, 02:08 AM   #1
norabder
Member#: 40530
2008 Legacy
Quartz Silver Metallic
Default Weird brake issues.
I've been having a weird rash of brake issues in the last couple of days. Both times driving to the same bank from work go figure. First as I pulled into the bank the brake idiot light comes on. Checked to see if I forgot the e-brake it was down. So I test the brakes they work so shut the car off. Go in come out turn it on the light comes on, when I press the brakes. Turn the car back off and on same thing its out until I push on the brakes. Say screw it go get food down the road shut off come out and start the car the lights out and stays out.
Second thing which has happened before is the ABS light comes on and there is a running pump like sound from under the hood. I stopped at a stop sign and could hear it with the engine running, turn the car off and it still was running or making the noise. Turn the car back on still does and the light comes on. Turn it off then on it goes out the pump noise goes away and the light is out. Drove it back to work from the bank car rested for 4 hours and then home 15 miles or so away no problem at all.
Any Ideas ?? The brakes work fine after each thing, I added brake fluid after the first but it really wasn't that low.
norabder is offline   Reply With Quote
Old 11-01-2007, 08:50 AM   #2
Gil
Member#: 20872
t3h rubber-neckers
must die!
check your fluid level.
Gil is offline   Reply With Quote
Old 11-01-2007, 09:29 AM   #3
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Yes, let's start with the maintenance questions first - when was the last time you flushed the brake fluid?
jey is offline   Reply With Quote
Old 11-01-2007, 09:31 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Check your reading comprehension.
Old 11-01-2007, 10:04 AM   #5
Gil
Member#: 20872
t3h rubber-neckers
must die!
well screw me!!
Old 11-01-2007, 10:40 AM   #6
norabder
Member#: 40530
2008 Legacy
Pretty much flushed the lines a couple of months ago when I added stainless lines and full synthetic. Haven't noticed any leaks anywhere and like I said the level hasn't dropped.
I also added 03 Rs two pots the same time as the stainless lines, not sure if they might be part of the issue but like I said I really haven't had any issues at all before or since the change.
Old 11-01-2007, 11:27 AM   #7
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
well, the abs comes on when the car thinks it is about to skid/lock up. The parking brake light is on when the parking brake is activated. Maybe you have a kink in your line that's keeping the parking break clamped down? Just a wild guess. Check for a dragging caliper or a stuck line.
janikphoto is offline   Reply With Quote
Old 11-01-2007, 08:37 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Did the system drain completely when you were installing all this stuff? There could be air in the ABS pump. I don't know why it wouldn't have become evident before, though.
When it comes to ABS issues I pretty much just accept I'm going to need the dealer to diagnose it. I vaguely recall the last time I had an intermittent ABS light the tech told me they couldn't pull a code from the ABS unless the light was on. I have something in the ABS system that about once every 6 months decides to act up, but I've never been able to locate the fault because it clears itself by the time I get it to the dealer to check it out.
The "BRAKE" light also comes on if the fluid in the reservoir is low. He addressed that already, but it could be an intermittent fault in the level switch.
And I'm not sure what you're referring to with "a kink in the line" for the parking brake. It's a cable-operated system, and it doesn't involve the calipers at all.
Old 11-01-2007, 09:45 PM   #9
janikphoto
Member#: 10471
2000 BMW Z3
Oh, I try to read any threads that I contribute to, but I must've missed his description...
Well, it should be obvious that a cable-operated system could kink.
and the caliper comment was not directly related to the parking brake comment. Jeez...
Old 11-02-2007, 01:09 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Really? I had no idea. How would a parking brake cable get kinked? How many people do you know of who have parking brake cable kinking problems? Once a parking brake cable is kinked (which is the obvious explanation for an intermittent "BRAKE" light), how does it magically unkink itself? Are there gnomes screwing around with his braking system?
So what was it related to? Did it have anything to do with this thread, or did you just want to mention parts of the brake system for fun?
Old 11-02-2007, 05:07 PM   #11
01gtlimited
Member#: 120658
01 LGT Ltd
about the parking brake:
i suppose it would be possible for the cable to kink and hang up. however, my intuition tells me it would be more likely for there to be some corrosion inside the cable sheath that would hang the cable up now and again. however, i'm not sure how relevant this information is to the problem. i'm not sure, but i would imagine the sensor for the parking brake is on the handle assembly somewhere. if the cable was hanging up and not releasing the brake all the way, the handle would likely still go all the way down. my best bet on the brake light would be an intermittent fault in the brake fluid level sensor circuit.
as far as the abs acting up, i'm not sure what to say. wheel speed sensors are a good place to start looking, since the abs looks at them to detect wheel lockup. many times, if it sees a disparate, inappropriate, or absent signal from one or more sensors, it will deactivate the system because it figures it's getting unreliable information. again, wheel speed sensors can be intermittent, and may not set a code if the fault is not currently present.
i'd be curious to see how this turns out.
01gtlimited is offline   Reply With Quote
Old 11-02-2007, 07:17 PM   #12
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
I agree with 01gtlimited.
Okay so you changed the front calipers, Caliper brackets, and rotors from the wimpy stock Legacy "L" size, to the larger more robost Impreza RS/ Legacy Outback/Legacy GT brake set up.
Did you paint the calipers, Caliper brakets, and other associated hardware ?
Did you use any form of a spray "Brake Cleaning" product ?
I am thinking you somehow got something that is somehow interfering with the speed sensors on one or more wheels. In other more simpiler terms, somehow the computer is not seeing a rotational speed signal from one or more wheels SOMETIMES and this is giving the ABS system fits... it knows some wheels are rotating, and perhaps doesnt know why its not getting a signal from another wheel.
I would DISABLE the ABS (pull the fuse?), until you can actually sit down and play with it and check out the operating condition of each of the speed sensours...
Obviously reading up on the Hayes and/or Chiltons manual Subaru ABS braking system might be a good first step, (if you have not done so) just so you know where to look for the ABS speed sensors. IIRC, there is a "tone ring" (A set of funny looking gear teeth) on the axles (or possibly brake rotors ?) that are only used to generate a "pulse" signal for the ABS system. If one of these "tone rings" has been removed, broken, mis-aligned, or covered in several coats of high-temperature brake caliper paint... the ABS speed sensor may not be receiving an especially reliable "pulse" signal. Something as simple as this could be giving your ABS system fits.
Jonathan is offline   Reply With Quote
Old 11-02-2007, 10:24 PM   #13
janikphoto
Member#: 10471
2000 BMW Z3
Jeez, pat. In all the years you've been here, you've never been so mean to me. You wake up on the wrong side of the bed?!?
I listed a kinked cable as a possibilty. Yeah, it was a stupid idea. I should've thought it through more. I figured that a parking brake stuck, well, it might just cause extra friction, causing heat, causing parts to malfunction, causing a light to come on. It was a dumb string of events. Now, would you like a little a-1 sauce on me, assuming you are done flaming me?!?
...and I DID want to mention other brake parts, but not for fun. It ultimately sounded like a caliper issue (whether or not a line kink was related to it), so I thought a double check of the calipers was in order.
I always respected your posts over the years, even the ones I didn't agree with. This jumping on a fellow nasioc member thing changes my view a bit. It's not like I'm some boy racer noob spouting off trash talk...
(now where's that crying imoticon? )
Old 11-03-2007, 01:49 AM   #14
norabder
Member#: 40530
2008 Legacy
Well the brakes are not painted I thought about it but didn't do it. The lines are not in the OEM spots as the stainless can't be run that way, they have been secured though. I haven't seen or felt any problems since and probably won't for another month, Knock on wood and hope I don't, its a quark or something.
when I had the old L brakes there was a drain right at a stop sign that if I hit just right there would be a clunk and you would hear the pump. I believe it was just the abs kicking in. With the new ones it doesn't do that or I haven't hit it right.
I don't know if this could be the problem but if one side drags slightly would that be enough to get the abs light or I could have had a rock or something could that cause the abs to do what it did?
ABS issue/braking issue SubaruImpreza_power Brakes, Steering & Suspension 5 08-30-2009 06:13 PM
Weird Brake Light issue whig-it Electrical & Lighting 3 09-10-2008 09:01 PM
Weird fueling issue. Not enough fuel, add a pump now insanely rich???A/F weirdness. Defiant Autospeed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 11-19-2007 04:30 AM
Weird Brake Issues lbk16 Brakes, Steering & Suspension 8 05-04-2001 08:24 PM
Weird alarm issues on my Legacy wagon. gtguy Legacy Forum 0 08-31-2000 10:19 PM
