Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-21-2002, 07:38 AM   #1
WRXterminate
Member#: 5945
Question M2 Up-pipe EGT bung vs Vishnu
Will the latest M2 up-pipe have the same problem with EGT probe coming loose as the earlier Vishnu design did?
Wondering if I need to do anything to avoid this problem with my M2.
WRXterminate is offline   Reply With Quote
Old 01-21-2002, 09:07 AM   #2
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Hmm, no problems here with my M2 uppipe.
djerickd is offline   Reply With Quote
Old 01-21-2002, 09:50 AM   #3
TurboRex
Member#: 8635
04 STI, 07 FXT
Before you install the uppipe, install the egt probe. If it fits snugly with no play then you are set. If it does not, then just get a file and file it down a bit. I just used a regular file for mine and it only took a few minutes.
Good luck,
Greg
TurboRex is offline   Reply With Quote
Old 01-22-2002, 06:38 AM   #4
WRXterminate
Member#: 5945
Smile
Thanks. Since I'm putting in a new EGT probe with the M2 pipe anyway, I can mess around with the probe and pipe to check the fit and file if necessary before I install.
Up-pipe EGT Bung bolt size RichWRX04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-02-2012 03:35 PM
M2 up-pipe SQC 155 Private 'For Sale' Classifieds 1 01-27-2004 07:10 PM
M2 Up-pipe AutoSpeedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-08-2003 01:05 PM
M2 Up-pipe AutoSpeedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-07-2003 08:45 PM
Perrin Up-pipe - No bung now? RallyX13 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-11-2002 01:04 PM
