Old 11-01-2007, 11:04 PM   #1
wrxrex
Member#: 130196
Old Stage 4 bugeye
Default K&N oil filter - spraying oil on the filter
What's the consequence of not spraying enough oil on the filter? I've had bad experience first time (too much oil) I sprayed oil on the filter, so I am trying not to put too much oil this time.
What could be the implication of putting too little (or excessive amount) oil on the filter? I understand that MAF sensor can get dirty.
wrxrex is offline   Reply With Quote
Old 11-01-2007, 11:11 PM   #2
MD04WRX
Member#: 72891
2014 Molten ST
98 2.5GT -2014 XV
Subaru Banner
Use too much oil and some can get on your MAF (which you can clean). Too little and the filter won't be as effective.
MD04WRX is offline   Reply With Quote
Old 11-01-2007, 11:13 PM   #3
hdempsey
Member#: 126374
2001 Impreza 2.5RS
Pure Aspen White
n/m.
hdempsey is offline   Reply With Quote
Old 11-01-2007, 11:45 PM   #4
Chino Bling
Member#: 129743
2009 335i
Jet Black
Originally Posted by v8subie View Post
K&N oil filters are crap. Go OEM.
i suggest that you go and re-read the OP.
Chino Bling is offline   Reply With Quote
Old 11-02-2007, 01:07 AM   #5
autoxrf/p
Member#: 161633
A friend used a KN on his Mustang and had problems with oil fouling his maf. I used one for years in my Mustang and had no problems. Haven't put one in my WRX. Just don't use too much oil. Let the oil dry thouroughly before installing. At least several hours in warm area.
autoxrf/p is offline   Reply With Quote
Old 11-02-2007, 02:36 AM   #6
hotrod
Member#: 14141
2002 Impreza WRX
Too little oil will compromise the filtering capability, too much will increase the possibility of contaminating the MAF sensor. The MAF sensor can be cleaned, and you can pull excess oil out of the filter by letting it sit for a while on some old newspaper. The excess oil will be absorbed by the paper.
K&N have good detailed instructions on how to oil the filters in their cleaning kit and last I looked the same info was on their web site.
Larry
hotrod is offline   Reply With Quote
oil catch can problems on the 2.0 03WRX-WRB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-22-2008 09:18 PM
sources of high-pressure oil lines/possible leaks on the pass side of the engine bay Jasper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 06-01-2007 06:27 PM
What is the K&N part number for the K&N Filter on the APS CAI? Red Rexx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-23-2005 09:44 PM
K&N air filter and oil - does it mess up the MAF? root Service & Maintenance 6 06-17-2004 02:37 PM
How do U stop spray going on the back window? toerag Forester Forum 6 12-06-2001 06:52 AM
