![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 159963
NESIC
Vehicle:2003 Subaru Baja Black & Silver |
Can the rear wheels on a AWD car be wider than the fronts? I heard its bad for a AWD car but i thought it was just bad to have different size tires as in diameter??
#2 |
Member#: 30907
SWIC
Vehicle:SWP GDB-G |
Its bad for the diffs to have tires different size diameter....good luck trying to find tires that are different widths and the exact same diameter.
It doesnt make any sense to put wider tires in the back anyway...some Auto-x guys in Evos and STis put wider wheels up front (with the same TIRE front and rear)...some people also experiment with staggered setups for competition use only...not for long term street use. |
#3 |
Member#: 159963
NESIC
So as long as its only the width that differs it should be ok? I was thinking going 225 Rear and 205/215 Front. Not a big difference.
#4 |
Member#: 10197
So, can someone explain to me how Porsches can run staggard?
#5 |
Member#: 75081
BAIC
Vehicle:2003 WRX WRB |
Most Modern Porshe's run a Mid Engine RWD or Rear Engine RWD layout.
#6 |
Member#: 87979
Vehicle:2006 Mazda RX-8 want Impreza daily driver |
#7 |
Member#: 140838
SCIC
Vehicle:2007 Forester 2.5X Had: 03 WRX/06 STi/08 Leg |
^ True that
#8 |
Member#: 10197
#9 |
Member#: 131067
SCIC
Vehicle:your "stance" sucks |
all 4wd porsches are staggered
#10 |
Member#: 99289
Just because porsche does it on a toally different platform doesn't mean you can do it on a subaru. And you need to calculate the outside diamater of the wheel/tire combinations before just looking at the wheels and saying, hey that's good!
#11 |
Member#: 99289
![]() That's almost 3% difference. and I can't remember of the allowable tolerance is 2% or 5%. Last edited by LastResort; 11-02-2007 at 07:23 PM. |
#12 |
Member#: 115154
Vehicle:2003 Legacy L Turbo silver |
Yes the AWD turbo porsches run staggered because they have that engine hanging over the rear axle. They need as much grip in the rear as possible to keep you from spinning into a tree.
Why would you want to run wider tires in the back? You're not doing your handing or performance any favors by doing so anyway. If one thing, having wider tires in the front to help keep the front end gripping would at least have some sort of logic behind it. |
#13 | |
Member#: 75081
BAIC
If you really want to know how they are able to do it, you probably will have to ask the Porsche Engineers. However, having the engine in the rear of the vehicle instead of in the front probably has something to do with why they are able to run a staggered fitment. Just because it works on a Porsche does not mean it will be able to work on a Subaru, however, feel free to try for yourself. |
#14 | |
Member#: 11279
Vehicle:2o11 wrx dgm 2oo8 tribeca swp |
Go here and play around for yourself: http://www.miata.net/garage/tirecalc.html |
#15 | |
Member#: 159963
NESIC
Yes there is no logic behind why i want to do it, But it looks good ![]() Thats the only reason. |
#16 |
Member#: 159963
NESIC
Looks like 225/40/17 and 205/45/17 might work though!!
#17 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
....d00000000000000000d.....
the GD chassis is a pig and understeers as it is...why do ya wanna make it WORSE??? this is a really dumb idea...been discussed here before....more than once ....and the answers will not change, this timeya better off putting the bigger tires on the FRONT |
#18 |
Member#: 30907
SWIC
Vehicle:SWP GDB-G |
Different width tires are almost NEVER going to be the same diameter/circumference...there are very few exceptions (like the 225/45-17 and 255/40-17 mentioned above)
Porsches can run staggered sizes because they are DESIGNED that way and the gearing is set up to accept it...if the Porsche owner put 4 of the same diameter tires on he would be in trouble. The front 2 wheels and the back 2 wheels need to be traveling the same speed (most of the time)...by running different size tires you would have one set rotating faster than the other and the center diff would die a horrible death. Its dumb when people do it on VWs, and its even dumber on a Subaru...and like Uncle mentioned above, you would be better off with bigger tires in the FRONT. |
#19 |
Member#: 159963
NESIC
Yes but if you go to this do-da http://www.miata.net/garage/tirecalc.html 225/40/17R and 205/45/17F is such a little difference that it should be within tolerance. And ill be doing it on the GC Wagon chassis not GD.
I dont know maybe it is a bad idea, thats why im asking. Last edited by Slug71; 11-03-2007 at 12:48 AM. Reason: Forgot something |
#20 |
Member#: 11279
#21 |
Member#: 159963
NESIC
Looks like ill be bagging that idea then.
#22 | |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
And I thought the accepted difference was 1/4" diameter, not circumference. Unfortunately, I can't find my Owner's Manual (or any of the other stuff in my glove box - what did I do with all that at my last track event... ) to confirm that.Pat Olsen |
#23 | ||
Member#: 11279
#24 |
Member#: 38120
South East
Vehicle:1991 Rio Red Legacy Turbo |
Tirerack says 1/4" circumference, or 2/32 tread depth.
#25 |
Member#: 61860
Vehicle:2004 WRX STi Aspen White |
Our AWD system is different. the Porsche has a more rear biased system. Also their suspension geometry is different. Not to mention the engine is in the back. Long story short if you put wider wheels and / or tires on the back your car will suck to drive compared to what it does now. Like a few have said so far wider up front would likely be a better choice.
| Thread Tools | |
| Display Modes | |
| RWD back to AWD... | Sti_044 | Transmission (AT/MT) & Driveline | 1 | 03-18-2009 09:55 PM |
| noobs here looking to get back into awd | genax | Newbies & FAQs | 10 | 01-01-2009 10:13 AM |
| Are wider / improved wheels and tires considered suspension mods? | Red Rexx | Brakes, Steering & Suspension | 1 | 04-11-2005 11:59 PM |
| wider 16" wheels? | SgWRX | Tire & Wheel | 3 | 03-21-2004 12:43 PM |
| advantage of wider rear wheels and sizes? | iloveturbos | Brakes, Steering & Suspension | 19 | 09-06-2002 04:45 AM |
