Old 11-02-2007, 05:28 PM   #1
awdftw
Member#: 138982
2004 subaru WRX STi
World Rally Blue
Default Package Deal for 30K mile maintenance? What do you use?
First, i have searched for any vendors selling a package deal on fluids to complete the 30K mile maintenance, and came up with nothing. If there is such a thing please help me out, and link me to it.
Now. My 2004 Sti is at 29,7XX miles, and i would like to change the oil, filter, brake fluid, trans fluid, diff fluid, coolant, clutch fluid, i have a K&N panel filter so im ok there, rotate the tires.. anything else i am missing?
If any vendors are reading this, than you should put together some sort of package deal.
Also what do you use in your personal car?
YR./Make/ Model-
oil-
filter-
trans-
diff-
brake-
Thanks in advance.
Brian.
awdftw is offline   Reply With Quote
Old 11-02-2007, 06:00 PM   #2
jay25RS
Member#: 4273
2011 GR-STI
& 2013 Impreza Sport
Just did a 30k service on my friends 2006 WRX wagon
oil- Royal Purple 10w40
filter- purolator pure one
air filter- SPT intake
Gear oil- Royal Purple 75-90
Rear diff- Royal Purple 75-90
brake- ATE Super Blue
jay25RS is offline   Reply With Quote
Old 11-02-2007, 06:03 PM   #3
mikeythejew
Member#: 141672
07' wrx
Uncle Scotty 5W30
Peak global lifetime coolant is silicate & phosphate free just like subaru coolant. Castrol GT LMA brake fluid is very good. LMA stands for low moisture activity.
mikeythejew is offline   Reply With Quote
Old 11-04-2007, 06:31 PM   #4
awdftw
Member#: 138982
2004 subaru WRX STi
World Rally Blue
thanks for the replys, any others?
Old 11-04-2007, 10:56 PM   #5
The_Prodigy
Member#: 116467
2004 STi
I did mine with the fallowings:
OEM air filter
OEM oil filter
Shell Rotella T 5w40 synthetic motor oil
Valvoline HP 75w90 tranny fluid
OEM STi rear LSD 75w90 fluid
OEM Subaru long-life coolant
Valvoline SynPower brake fluid
The_Prodigy is offline   Reply With Quote
Old 11-05-2007, 07:21 AM   #6
mikeythejew
Member#: 141672
07' wrx
Uncle Scotty 5W30
Even that I mentioned castrol brake fluid, it's hard to find. Valvoline synpower brake fluid is DOT 4 and the best place to get it cheap is Meijer.
Old 11-06-2007, 04:51 PM   #7
FtW_STi
Member#: 117016
2006 STi
Obsidian Black
I did mine recently with the following:
2006 STi
OEM Oil Filter
Prodrive air filter (part of CAI)
Motul 300V 5W-40
Motul Gear300 75W-90 (Tranny and front diff shared)
Motul 90PA (Rear diff, LSD specific oil)
Motul RBF600 (brakes)
Now, my car sees the track regularly so some of this might be overkill for you (not sure of your usage) but it certainly rocks the Casbah for me!
FtW_STi is offline   Reply With Quote
HR: Reputable shop that doesn't wallet rape for 30K mile maintenance? lando Mid Atlantic Impreza Club -- MAIC 3 07-20-2008 06:00 PM
I took my car in to goodyear for 30k mile maintenance phinespec Newbies & FAQs 18 09-17-2007 05:26 PM
What do you use for tuning 0% column for non stock injectors? cky211 UTEC 4 07-29-2006 09:59 PM
30k mile service, what do i need to do? ImprezedRS Normally Aspirated Powertrain 2 06-14-2001 07:26 AM
what do you use your scooby for? pwrup25RS General Forum Archive 23 12-07-2000 05:39 PM
Message Board Statistics All times are GMT -4. The time now is 11:46 AM.
