Old 11-04-2007, 01:02 PM   #1
SubyTR07
Member#: 156365
2007 WRX TR
White Pearl
Default Oil Sandwich Adaptor for Prosport Oil Pressure Gauge?
Like the title says...just curious if anybody is running an Oil Sandwich Adaptor for a Oil Pressure/Temp Gauge and if you had any issues. I ordered mine from machv motorsports: Oil Pressure with the sadwich adaptor....Went to do the install this weekend...gauge hooked up with no issues, but the oil sadwich adaptor doesn't fit my oil filter. It's a upgraded mobile 1 filter, but it should should still fit regardless...Only thing that I can think of is that the oil sadwich filter is the wrong one....directions list many makes and subaru is lacking it's the only thing I can come up with...Any tips/help would be nice, thank you
SubyTR07 is offline   Reply With Quote
Old 11-04-2007, 02:38 PM   #2
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
search, there was just a thread about this.
I am running the PS adapter and am using the OEM Subaru replacement filter and have had no problems.
B00st3dWRX is offline   Reply With Quote
Old 11-05-2007, 11:32 AM   #3
Spike66
Member#: 153010
I had a fitment issue with my oil adapter and hooked up my oil pressure sensor to the stock outlet just to the left of the alternator.
If you remove the stock sensor you do not get a CEL code either.
It was a piece of mind that the sandwich is not leaking oil.
Spike66 is offline   Reply With Quote
Old 11-05-2007, 11:36 AM   #4
10rtim
Member#: 94871
05 sti
I have been running the sandwich adapter that Prosport sells for my oil pressure. I have done 4 oil changes and about 12k miles with no leaks/no problems.
10rtim is offline   Reply With Quote
Old 11-05-2007, 12:11 PM   #5
SuBart
Member#: 2956
06 Sti-white Stg 2
98RS-rally blue
Same here, no problems, the adapter from Mach V works good.
SuBart is offline   Reply With Quote
Old 11-05-2007, 12:13 PM   #6
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
I have the maddad one and it fits fine with oem or aftermarket filters...
Sound like you either have the wrong adapter or the wrong filter. Sure you got it on properly?
Got pics?
Gfunk720 is offline   Reply With Quote
Old 11-05-2007, 02:20 PM   #7
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Sandwich plates FTL. Use the top Oil gallery plug. I used a M NPT x F x F BSPT T-fitting and it worked killer. My press sender is horizontal with the temp probe vertical. Cleanest install I've ever seen if I do say so myself.
bushflyr is offline   Reply With Quote
Old 02-01-2008, 04:57 PM   #8
csmith335
Member#: 150530
when any of you used the oil sandwich adapter, where did u run the sender wire? as in, where hole did u put it through to get it bak up the the gauge inside the car?
csmith335 is offline   Reply With Quote
Old 02-01-2008, 05:44 PM   #9
csmith335
Member#: 150530
anyone?? i know plenty of people have done this install!!!
Old 02-01-2008, 05:55 PM   #10
camshaft06
Member#: 149694
2005 Stage 2 Sti
CGM
Do you mean which grommet in the firewall? Or how did I route the lines from the bottom of the block to the top of the engine and then through the firewall?
Any how, use the grommet that is on the driver's side just behind the intercooler, it is easiest if you remove the IC before. Running the wires up from the bottom you can zip tie the wires for the sensors to the radiator fan housing, and then up, run it along the back of the radiator and hug the side of the car...behind the fuse box and about up to the strut tower, and through the hole. Zip ties are your friends in this install. Hope this helps
camshaft06 is offline   Reply With Quote
Old 02-01-2008, 05:58 PM   #11
SimonJ
Member#: 135309
ditch it and use the gallery plug under the alternator.
SimonJ is offline   Reply With Quote
looking for oil sandwich adaptor for oil cooler berdugo Built Motor Discussion 0 08-18-2009 11:30 PM
FS NJ:: Sandwich Adaptor! for Oil Pressure & Temperature WRXDriftR Engine/Power/Exhaust 3 12-19-2006 12:48 AM
Sandwich adaptor for oil pressure chaddeus Newbies & FAQs 5 04-05-2006 02:41 PM
need sandwich adaptor for Greddy temp gauge flyKen74 MWSOC Private Classifieds 10 03-06-2006 03:02 AM
Sandwich Adaptor for Oil Pressure & Temperature Senders WRX05noob Newbies & FAQs 1 05-24-2005 07:38 AM
