Old 01-21-2002, 04:41 PM   #1
WRxednEffect
Member#: 13105
Default weird problem with throtttle sticking
k how to explain, under normal driving its fine. The minute i am half wot or full wot it sticks. this is the scenario.
driving: press gas down untill shift point, shift with foot off throttle. but at this point the rpms jump 500 or 1000rpms up. then back on gas and noraml. when i press teh gas with no gear in or load its fine. but when the car has load it jumps rpms after a shift out of gear
really weird, i have my boost line tied to the throttle cable down south. weird. but its not tight enough to restrict ti. uness the engine is moving or sumint
WRxednEffect is offline   Reply With Quote
Old 01-21-2002, 05:13 PM   #2
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
I have noticed this, too. Accelerate easily (or even half throttle) in a gear, let off gas, press clutch, and the rpms either stay up or actually climb some while shifting. Almost feels like a slipping clutch, or super heavy flywheel...but it doesn't happen all the time, some days it doesn't happen at all. Something is definitely not right, just not sure what it is?
Anyone else have this sporadically and figure out what it was?
Kevin
Force[FED] is offline   Reply With Quote
Old 01-21-2002, 05:17 PM   #3
WRxednEffect
Member#: 13105
this is weird, i called my suby dealer and he said that its kinda normal with subarus. SEems like all these weird hickups are "normal" **** man i should of bought an evo but i cant. I can deal cause I really love this car
Old 01-21-2002, 05:20 PM   #4
WRX Power
Member#: 7142
Guys this is normal w/ turbo cars.... and even some N/A cars.
Do a search, there is a thread that discussed this!
Bryan
WRX Power is offline   Reply With Quote
Old 01-21-2002, 07:07 PM   #5
larryg
Member#: 13911
2002 Maxima
Mine does it too and it drives me nuts (short drive...). Anyway, it only happens under part throttle acceleration. It doesn't do it when I am driving hard so I am not worried about over-reving it.
larryg is offline   Reply With Quote
Old 01-21-2002, 07:20 PM   #6
WRxednEffect
Member#: 13105
ya think for 42g's canadian this wouldnt happen
Old 01-21-2002, 07:22 PM   #7
mitch808
Member#: 10228
2002 Subaru WRX
This is a emmisions feature, some sort of purge valve that is in place that makes the RPM's jump inbetween shifts. Do not worry about it.
mitch808 is offline   Reply With Quote
Old 01-21-2002, 07:24 PM   #8
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Suby engines drink a lot of oil. Try taking the IC and look how much oil is in there. Now the TB sits at an angle and all that oil drains into the manifold. All that oil gathers by the butterfly plate and eventually builds up to a point so that at idle the TB passage becomes blocked with oil build-up or almost blocked and the butterfly gets sucked in by the vacuum when you let off the gas pedal.
The solution?
1. Take the TB off and clean it.
2. Up your idle screw a bit (if you dont want to do #3)
3. Install oil catch can.
Hope this helps.
-Alex
Imprezer is offline   Reply With Quote
Old 01-21-2002, 08:02 PM   #9
WRxednEffect
Member#: 13105
i have a god damn oil catch can, but i dont know how to install the ****er!!!!!! and all the faq's arent helping caues they arent detailed enough
Old 01-21-2002, 08:50 PM   #10
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Default Re: weird problem with throtttle sticking
This is normal for turbocharged, intercooled engines. All the air that your turbo is compressing when your throttle is half to wide open is being pushed into the intercool before the engine. The intercooler, being very big is going to "store" lots of air. This is the reason intercoolers cause lag and bigger intercoolers cause more lag. Anyway, all this pressurized air continues to flow through the system and expand to normal volumes after you close the throttle. This is manifested by the engine burning fuel to match the air. This, of course, causes the rpms to rise if it's out of gear.
nhluhr is offline   Reply With Quote
Old 01-21-2002, 09:12 PM   #11
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Hmmm I noticed this also. My SVT contour did the exact same thing. The people at Contour.org called it "throttle hang" Between shifts the throttle would not drop for a very brief period or sometimes even jump a little. All while your foot was off the gas and your pushing in the clutch to shift. Very annoying. They had a fix which I don't know if it would be applicable in our cars. Had something to do with inserting a copper plug with a 7/32" or similar size hole drilled in it, into a hose somewhere on the emissions equipment. (sorry that's all I remember ) Anyway, It (throttle hang) is built into the car on purpose for emission reasons. It is supposed to be there. Just annoying.
cheers
mr2guru is offline   Reply With Quote
Old 01-22-2002, 12:49 AM   #12
cronic
Member#: 9749
it also happens to me. i hate it!
cronic is offline   Reply With Quote
Weird Problem With My Motor scoobaru_wagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-15-2005 11:33 AM
Weird problem with Perrin Modifieds.... Project Rex STi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-22-2005 09:08 PM
Small weird problem with my STI wing... thsiao Interior & Exterior Modification 5 04-10-2005 10:34 PM
hmmm weird problem with A/F install Impreza25RS Normally Aspirated Powertrain 3 11-25-2001 09:21 PM
Any weird problems with the Website? Nick General Forum Archive 41 01-31-2001 10:53 AM
