Old 11-04-2007, 10:16 PM   #1
javi-sti
Member#: 147346
04 Need help!
Installing injectors! $$$
Default OEM 04 STI suspension into 05 WRX wagon
My friend has an 05 WRX wagon and I was wondering if my OEM 04 STI take off swaybars and spring/shocks/top hats fit into his. He is just starting out and I ratther give him these than selling/shipping them.
javi-sti is offline   Reply With Quote
Old 11-04-2007, 10:18 PM   #2
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
I'm not sure about the swaybars, but pretty unlikely. The 04 STi strut assembly should bolt right up. He'll just lose out on some negative camber up front.
Edit: This is assuming all USDM vehicles. I don't know what, if anything was different in Europe.
flyboymike is offline   Reply With Quote
Old 11-04-2007, 10:52 PM   #3
javi-sti
Member#: 147346
04 Need help!
Both are USDM models. We are military stationed in Germany.
Can some aftermarket camber bolts fix that?
Damn! I washoping the sways fit too... Thanks for the help!
Old 11-05-2007, 01:17 PM   #4
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
Bolts can certainly help, or camber plates. The loss is typically 0.7 degrees when putting a sedan suspension on a wagon. Getting back to factory spec shouldn't be a problem. If you're looking for -3 degrees because you autocross or track the car, it might be a little tougher.
04 STi Cluster into 05 WRX. Sir Wagon Interior & Exterior Modification 8 11-28-2008 02:23 PM
04 STi Suspension on 05 WRX problems Uncle Tattoo Brakes, Steering & Suspension 4 05-23-2008 09:56 PM
'06 usdm sti suspension into '07 wrx wagon TS 2.5 Brakes, Steering & Suspension 4 12-15-2006 11:42 AM
how to swap 04 STi motor into 05 WRX? whateverwrx Newbies & FAQs 4 05-22-2006 12:48 AM
04 STi suspension on 02 WRX wagon? Subahaulic Brakes, Steering & Suspension 5 06-29-2004 08:02 PM
