Old 01-21-2002, 07:13 PM   #1
shortlid
Member#: 10297
2003 Legacy GT Sedan
Silver, 4EAT, 42k
Default Rear Pad replacmnet at stealership
Does this look right?? i think my Mother got hosed for a rear pad replacment!!
Subaru of Wilton, Inc. 657 Danbury Road * Wilton, CT 06897 Phone (203) 761-9700 Fax (203) 761-0213
SERVICE ADVISOR: 9618 GERALD ULBRICHT
Color Year Make/model VIN License MILEAGEIN/OUT
Silver 98 LEGACY WAGON 4S31BK4352W7312113 59605/59608
Rate INV. Date
75.00 15JAN02
LINE OPCODE TECH TYPE HOURS LIST NET TOTAL
A
CUSTOMER STATES: REPAIR BRAKES AS PER LAST INSPECTION.
RBJ REAR BRAKE JOB MACHINED ROTORS/DRUMS AND
REPLACED PADS/SHOES
9752 VICTOR WINIGER LIC#: 9752
CP 2.50 187.50 187.50
1 26296AA062 BRAKE PAD KIT R 72.50 72.50 72.50
1 BC11 BRK CLEAN 5.95 5.95 5.95
NOTE: WE RECOMMEND PERFORMING THE 60,000 MILE TUNE UP SERVICE. COURTESY RENTAL CAR.
B** CUSTOMER STATES:SOMETIMES THE CAR LABORS WHEN SHIFTING IN CRUISE CONTROL. MISC ROADTEST AND INSPECT VEHICLE FOR SHIFT PATTERN. WE WERE NOT ABLE TO DUPLICATE PROBLEM AT THIS TIME.
@9752 9752 VICTOR WINIGER
CP 0.00 0.00 0.00
C** CUSTOMER STATES: PERFORM OIL CHANGE WTTH COUPON AND INSPECT FOR SERVICE. LOFSP $23-95 OIL CHANGE SPECIAL
Description Totals
Labor amount 200.98
Parts amount 88.92
Gas, oil, lube
Misc. charges 2.66
Total charges 292.56
Sales Tax 17.56
Pay this amount 310.12
shortlid is offline   Reply With Quote
Old 01-21-2002, 07:37 PM   #2
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Default Flat-Raided
shortlid,
Good ole Flat Rate manual at $75/hour. You could've done it yourself for your Dear Mum, including out sourcing the Rotor cut/surfacing for a whole lot less. And learned a little about the car while you were at it. This is pretty much standard MO for the Dealer. That's why many of us have taken on such things, aided by shared knowledge from our Brothers and Sisters that have gone before.
Glenn O
nuburu2 is offline   Reply With Quote
Old 01-21-2002, 07:56 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Check out this thread in the Suspension Forum: http://i-club.com/forums/showthread....hreadid=138061 . That dude's mom got scammed, maybe he could help you figure out why your mom got hosed.
Pat Olsen
'97 Legacy 2.5GT sedan
Helping double posters one thread at a time
Old 01-21-2002, 08:45 PM   #4
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Pat,
Same guy!
This is a classic example of the Tech and shop making money based on the dreaded "Flat Rate Manual". Book says 2.5 hours labor for pads and turn the rotors, that's what you get charged, even if tech can do it in 1 hour.
What's always bugged me, in addition to the "padding" is that the tech won't take the time to clean up around the work despite the fact that this is included in the "rate". Example is CV Boots, where the nice new boot is in place and the bill paid and you find the grease splatter from the old boot "explosion" still all over the under side of your ride. Grrrrr! And they'll even charge an "enviro" fee to discard the "toxic waste" rags! Or maybe that's only a California thing?
Glenn O
Old 01-21-2002, 09:15 PM   #5
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
I did this write-up when I replaced my pads/rotors. It is even easier than it looks.http://www.scoobymods.com/forums/sho...s=&threadid=84 Always check here and Scoobymods before you have any dealer work done. You can always get some good FREE advice here.
HIHO is offline   Reply With Quote
Old 01-21-2002, 09:20 PM   #6
HIHO
Member#: 7624
BD5; family sedan
If that is their special what is the regular charge. It cost about $10 to do the change yourself and it takes about 10 minutes. I take mine to the dealer because I trust them and the oil change is only $15.99. Plus they wash and vacuum too.
Old 01-21-2002, 11:25 PM   #7
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
Well, as far as the steps to installing pads and rotors may be very simple. However, this past weekend I tried to change the rear rotors on my car without any success. The bolts that hold the calipers on were completely frozen. I tried everything from soaking the bolts in P'Blaster to actually slowly lowering the car on the wrench (unsafe, i know, but it was a final desperate attempt)! Unless you have a very high lift and a HUGE breaker bar, you may have troubles freeing the calipers. I guess I'm going to have to take the car to a mechanic afterall
BJamerican is offline   Reply With Quote
Old 01-21-2002, 11:25 PM   #8
shortlid
Member#: 10297
Silver, 4EAT, 42k
Default I would!
I would and DO do all my mechaical work myself. But, it is hard to do whne you are 850 miles away at Collage!! Thanks for your insite guys. I just wanted to see how much time I should take to find her a good independant import mechaic in the area. I guess I should start looking!!
Old 01-22-2002, 02:36 AM   #9
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Default oops!
shortlid,
No offense intended. Only meant to encourage a little DIY and obviously unaware of your situation. Mea Culpa Brother. You're right on in looking for a good independent!
Glenn O
Old 01-22-2002, 09:33 AM   #10
HIHO
Member#: 7624
BD5; family sedan
Yeah you sometimes run into snags. Usually when one is to tight on the calibers it is because someone over tightened them. A frozen bolt is a major pain. I had the same problem when I had to install my exhaust.I had to finally take it to Midas. They had to torch them off. They only charged me $20 buck so I was pretty happy.
Yeah 850 miles is a long way to go to change brakes. That is one way woman are discriminated against. Some mechanics prey on woman and the elderly. If she had a male friend to go with her next time it my help. You could also teach her a few things about her car. It tends to help when you can walk in and say "I need my pads replaced and maybe resurfaced. Please clean the calibers and grease the pads well. I hate the noice of an ungreasesd pad. Instead of "My thingy that stops me is loud". That just sets a light of in their head.
FS: PFC01 front pads & DS2500 rear pads for STi stizzer Suspension/Brakes/Handling 10 10-19-2007 05:42 PM
Front/Rear Pad stagger or even track pad selection SoutFL_9-2x Motorsports 1 11-17-2006 08:47 AM
Front/Rear Pad stagger or even track pad selection SoutFL_9-2x Brakes, Steering & Suspension 4 11-17-2006 12:59 AM
Planning on Hawk front pads, which rear pads? Arnie Brakes, Steering & Suspension 0 07-29-2002 12:54 PM
Rear pad replacment at dealer shortlid Brakes, Steering & Suspension 2 01-21-2002 07:53 PM
