Old 12-06-2005, 02:36 PM   #76
TrogDorWrx
Member#: 61097
2002 Wrx
Ive had this problem the past 3 winters but this winter the smell is so bad i cant take it. I had no clue this many other people are having the same problem till today when i finally decided to do a search. Just sent my complaint to the NHTS, going to see if my dealer will cover it but i highly doubt it.
TrogDorWrx is offline   Reply With Quote
Old 12-08-2005, 08:52 AM   #77
mastershakewrx
Member#: 80120
2002 Wrx sedan
MBP
i got this problem now im so ticked off... my warranty xpired 9k miles ago and subaru wont cover it. ive heard that getting a silicone turbo inlet so u can take the stock inlet out and tighten the clamp doesnt always work the clamp sometimes gets loose again. im thinking about the perrin fuel rails havnt found much info on this site for how much of a pain the install is for them. anyone installed the perrin fuel rails to solve this?
mastershakewrx is offline   Reply With Quote
Old 12-08-2005, 10:33 AM   #78
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
Got the smell again today...smelled it last year as well at this time. Ugh...I really don't want to take off the intake manifold but I don't want to burn either. :sad:
forced4 is offline   Reply With Quote
Old 12-08-2005, 10:39 AM   #79
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
I have installed Perrin fuel rails on my car and a couple others. You have to remove the intake manifold to install them, but it is not hard. Just take a little time and make sure you unhook all the connectors.
Kevin
Crazykev is offline   Reply With Quote
Old 12-08-2005, 10:42 AM   #80
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
I am not up to date on the fuel delivery system but installing aftermarket fuel rails will solve this problem?
Old 12-08-2005, 11:04 AM   #81
dolmen_tor
Member#: 31957
2013 Street Triple R
Explorer XC y DR650
Not sure about all aftermarket rails, but Perrin at least replaces the fuel lines that run under the manifold as well as the rails. The leakey lines aren't used anymore, so no leak.
On another note, it may be true that simply tightening the clamps will not always solve the problem but I replaced all four oem clamps under there with real hose clamps and three weeks and muuuch colder temps and I've had no more leaks. You do still have to remove the turbo inlet to get to them, though.
dolmen_tor is offline   Reply With Quote
Old 12-08-2005, 11:22 AM   #82
mastershakewrx
Member#: 80120
2002 Wrx sedan
MBP
im trying to decide on getting a perrin turbo inlet and just tightening/replacing the hose clamps or just getting the perrin fuel rails, anyone hav any suggestions? i figured the perrin lines would make sure no leaks in the future but the inlet and replacing the clamps would be easier
Old 12-08-2005, 12:34 PM   #83
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Nice thing about the Perrin rails is how quickly injectors can be remove once they are installed. I can swap injectors in 20 minutes tops!
Kevin
Old 12-08-2005, 01:06 PM   #84
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Originally Posted by qphilo
My problem is that my leak does not stop once the car is warmed up. I went 70 miles tonight before I discovered it, and had to turn around and go 70 back home, and it leaked the entire time. I think there should be a recall on this. Nobody should have to pay to fix this. I only hope my "Classic" extended warranty will cover it.
Your problem does not sound like the one in the TSB, rather you have a more significant issue. While I am unhappy that Subaru did not resolve this issue, I don't understand the logic that they should cover something that is outside of warranty. They cover everything up to 3 years, 36k miles, after that it's your problem unless you have an extended warranty. You could make the argument that this is different as it's a safety hazard, but that was shot down by the NHTSA.
I just had this fixed, $80 for parts 3.5 hours labor. $350 total, fix and move on.
Snowphun is offline   Reply With Quote
Old 12-08-2005, 01:16 PM   #85
mastershakewrx
Member#: 80120
2002 Wrx sedan
MBP
i just ordered the perrin rail kit should be here tommorrow(thanx JSCSPEED.COM!!!) for a long project on saturday cant wait to get this problem fixed permanetly.
Old 12-08-2005, 01:19 PM   #86
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Guys at JSC are awsome! I stall will take you 3-4 hours for the rails.
Kev
Old 12-09-2005, 01:03 PM   #87
fatray
Member#: 18150
2002 WRX Wagon EJ207
Velocity Red, Liberal kit
Kevin
I swapped the injectors in 19 minutes with STOCK rails (GBOD removed previously). Top that one!
Has anyone fixed this problem with out taking off the manifold? I tried and found it impossible. After taking off the manifold and replacing the hoses and clamps it's been good for 2 years now. About $15 in parts and $25,000 in labor (paid myself ).
fatray is offline   Reply With Quote
Old 12-09-2005, 11:21 PM   #88
MyFirstDeuce
Member#: 50193
1999 Rubasu Ziprema
Silverthorne
Well it turns out this is happening on my motor too. I have a 02 ej20 in my 99 GC8. I have never taken off intake manifold, and I dont' feel comfortable doing it.
Does anyone have any detailed pics of where the 4 screw can be found?
Thanks,
-al
MyFirstDeuce is offline   Reply With Quote
Old 01-11-2006, 08:43 AM   #89
LukeG
Member#: 49760
2002 WRX Wagon
Wow, they got you trained. In this case its not a wear and tear issue or failure due to misuse. This is a major and dangerous design flaw and should be covered under a recall situation. A puddle of leaky gasoline when heated turns to a dangerous and highly ignitable vapor. Subaru is probably waiting for one or more of their cars to kill someone because of this so that the cost of settlements exceeds the cost of repair.
LukeG is offline   Reply With Quote
Old 01-15-2006, 01:01 PM   #90
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Luke, you seem to be out of touch with reality. The NHTSA already performed an investigation and deemed the fuel leak to not be a safety issue, therefore no recall is needed. "Design flaws" do not have to be fixed by maunfacturers outside of warranty, and that's where we are with this situation. Explain to me why SOA should fix this, anymore than they would cover wheel bearings or interior pieces that fail outside of warranty. Again, it has been determined that this is not a safety issue (this is not my opinion).
If you can get a dealer to fix it for free, good job. I tried, SOA was not having it, and I didn't want my family inhaling gasoline fumes so I had it fixed for a reasonable price.
Old 02-19-2006, 08:56 PM   #91
Scooby_Rex
Member#: 98827
2005 Leggy 2.5iWagon
So, to recap what everyone is saying....
You can spend $350-500 for the dealer to "fix" the problem
or
Spend $350 for the Perrin kit and take out the variables.....
Scooby_Rex is offline   Reply With Quote
Old 02-19-2006, 09:22 PM   #92
qphilo
Member#: 93634
You fell for the red herring. Subaru with the help of the NHTSA is taking a "no fire no problem" attitude. If fire were the actual problem, they might be right. But check out the thread on this problem in the Warranty forum, and look more closely. The toxic emissions hazard is the health and safety problem. For Subaru, it is a LIABILITY, an actionable one. Those of us who had the persistent problem noted raw gasoline being fed into the cabin air intake and forced into the cabin. By the time I got home the first time, my face was covered with a film of gasoline, and I was nauseated for a full day.
qphilo is offline   Reply With Quote
Old 02-19-2006, 10:09 PM   #93
Jon [in CT]
Member#: 2992
02 WRX Sedan
Gee, maybe you should appeal to the EPA. But wait! Last time I checked, the EPA doesn't have any rules regulating gasoline vapors entering the passenger compartment.
Jon [in CT] is offline   Reply With Quote
Old 03-21-2006, 07:11 PM   #94
1QWIK4
Member#: 78353
Default So Where Is That Pdf?
I see a lot of ppl posting but I rememebr seeing a pdf floating around at one point in time concerning the bulletin.
The TSB you need to refer to is
09-36-0334719
PM me your email addy and I'll send you the PDF.
text below
NUMBER:09-36-03
DATE:04/01/03
APPLICABILITY:2002MY Impreza WRX
SUBJECT:Fuel Smell in Cold Weather
A AA AA
INTRODUCTION
Some 2002 model Impreza WRX (2.0L Turbo) may experience a fuel smell in cold weather
(temperature below 14F) from the rubber hose connector, located under the intake manifold,
between two direct fuel-feed metal lines to the injectors.
REPAIR
The changing of the pipe and hose size was adopted, starting with engine number 673467
to better align the two fuel lines. This was accomplished by shortening the fuel pipe and
lengthening the hose both by 30mm. To complete this service procedure, you must replace the
fuel pipe assembly and hose as a set.
Follow the service procedure in the appropriate service manual to remove the intake
manifold from the vehicle.
PARTS
Replace the pipe and hose as a set.
PART NUMBER DESCRIPTION
17544AA134 Pipe complete
(30mm shorter than Old one)
807707140 Hose
(30mm longer than Old one)
such as that. anyone??
1QWIK4 is offline   Reply With Quote
Old 03-21-2006, 07:18 PM   #95
Jon [in CT]
Member#: 2992
02 WRX Sedan
09-36-0334719
People don't need to PM you for the TSB. It was included in this thread in post #57:
http://forums.nasioc.com/forums/show...0&postcount=57
Old 10-02-2006, 02:41 PM   #96
PhilJensen
Member#: 93195
The pictures at the beginning of this thread don't work anymore. Anyone have them still? I would like to tighten up the fuel line on my 02 WRX with the long screw driver, and the pics would probably help.
Thanks,
Phil
PhilJensen is offline   Reply With Quote
Old 12-08-2006, 01:31 PM   #97
MarcinR
Member#: 134352
white
noticed the fuel smell today...the pics at the beginning of the thread would be helpful..thanks in advance
MarcinR is offline   Reply With Quote
Old 12-08-2006, 10:25 PM   #98
turd_ferguson
Member#: 114609
Here are a few pictures I took tonight. I fixed the problem with ~$2 in hose clamps and doubled up on them just to make sure . Mine was spraying (not dripping) fuel out of the the spot where the bottom arrow is.
turd_ferguson is offline   Reply With Quote
Old 12-09-2006, 04:25 PM   #99
fatray
Member#: 18150
You fixed yours without taking the manifold off? Nice... Mine was leaking on the other side, a lot harder to get to.
Old 12-09-2006, 05:15 PM   #100
turd_ferguson
Member#: 114609
If I had to do it over again, I'd probably take the manifold off, it was a huge PITA
02 Fuel leak. i dont think its the common leak! Robstunner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-21-2007 12:23 AM
Cold weather fuel leak from stock '02 fuel rails -- kudos to KTR scooterforever New England Impreza Club Forum -- NESIC 10 01-18-2006 05:21 PM
Fuel Leak? Should I get new fuel rails? CtGT Rocky Mountains Impreza Club Forum -- RMIC 10 11-03-2004 02:32 PM
Fuel leak / vacuum leak mmm3587 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-01-2004 08:38 AM
locating fuel leak and re-routing fuel lines Chris Stein Normally Aspirated with bolt-on Forced Induction Powertrain 2 12-09-2002 12:51 PM
