Old 12-11-2006, 09:29 AM   #101
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Wow, great pictures, really easy to see with the turbo inlet hose out of the way.
Snowphun is offline   Reply With Quote
Old 12-11-2006, 10:20 AM   #102
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I just fixed another leak yesterday for someone. Fixed one last year for him under the turbo inlet hose. This year it was leaking on the driver's side behind the AC compressor. Removed the AC compressor and replaced the hose without removing the manifold. Took about an hour.
Old 12-17-2006, 11:15 PM   #103
STIStalker
Member#: 92783
2004 WRX
Just adding to this that I to have this exact same problem, but now I just blew a hole in a piston so I will probably fix this while I am transfering everything over to the new 2.5 block.
STIStalker is offline   Reply With Quote
Old 01-03-2008, 06:40 PM   #104
Member#: 151119
Can the pictures of this be rehosted or something? I am haveing this raw fuel smell problem in a MY2002 WRX i just purchased this past summer. I also just filled up and i only got 12.5 mpg and i know it wasnt because of driving habits. I would really like to see the pictures so i can see if mine is spraying fuel out and i know which clamp to tightne to make this stop happening!
nevets87@siu.edu is offline   Reply With Quote
Old 01-03-2008, 09:35 PM   #105
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
yeah, mine did it at like 90k or so in a montana winter, I replaced them with an aftermarket fuel system
scby rex is offline   Reply With Quote
Old 01-04-2008, 02:38 AM   #106
Member#: 151119
I only have 54--- miles, do you think subaru will cover it??
Old 01-04-2008, 10:35 PM   #107
scby rex
Member#: 104878
02 wrxbastardchild
nope...
Old 07-05-2010, 05:53 AM   #108
oguitar
Member#: 206720
2002 WRX Wagon
Originally Posted by turd_ferguson View Post
Here are a few pictures I took tonight. I fixed the problem with ~$2 in hose clamps and doubled up on them just to make sure . Mine was spraying (not dripping) fuel out of the the spot where the bottom arrow is.
Sorry to bump a two year old thread but I wanted to ask how this held up for you Mr. Ferguson? I need to fix this issue and will be changing my turbo inlet soon. Thanks for the help.
oguitar is offline   Reply With Quote
Old 01-07-2015, 12:29 PM   #109
nycjon
Member#: 316990
2005 WRX STi
Can't see the pictures :/ having the same problem
nycjon is offline   Reply With Quote
Old 01-08-2015, 06:11 AM   #110
danger1138
Member#: 279525
04 rex luger!
Default Found Fuel Leak (Pics)
Seems like we're all having this issue this time of year especially in the north east with these older models.
I located my leak. Its in the location where the coolant tank is but beneath the turbo inlet. I can see drops of fuel in cold starts. After warm, it goes away.
Gonna pull the inlet and either replace the lines or tighten clamps whenever it gets warmer out.
danger1138 is offline   Reply With Quote
Old 01-08-2015, 08:50 AM   #111
chad042288
Member#: 397335
04 Wrx
Default Fuel leak
04 WRX. Completely rebuilt from the bottom up.
So it appears that I have the same fuel smell/leak coming from that general area.
Looked under the hood and used my nose to smell where it was coming from. As others have stated, it is in the same general location. I looked around that area and noticed that there was a film of fuel that has covered my turbo inlet and my IC piping. Also found a puddle sitting on top of the motor just under IM. With it being 6 degrees outside I felt the need to say Eff it and wait until it gets a little warmer outside before more investigating---> (I do not have a garage) So, everything points to this issue that has been posted multiple times about these hose clamps.
I would love to see those pictures to get more of a general idea as to what to look for in order to repair this issue. And if there are specific hose clamps or parts that were used for this fix could someone post them...
chad042288 is offline   Reply With Quote
Old 01-08-2015, 10:59 AM   #112
danger1138
Member#: 279525
04 rex luger!
You need 5/16 fuel line hose, if you want to replace the hose itself. You will also need fuel line clamps... NOT worm clamps.
Old 01-08-2015, 03:22 PM   #113
chad042288
Member#: 397335
04 Wrx
Thank you for the info danger1183.
Before I went and bought anything I did a tear down of that area with out taking off the IM just to look around. I just took off the piping for my FMIC that went from the TB to the next section. Took off the coolant tank that sits on the IM. The fuel line was directly behind that section of hose for the coolant coming out the bottom of the tank. I found that clamp that sits upside-down (Stupid Subaru Idea) and the one closer to the firewall that was right side up. Fortunately for me the upside-down clamp was not the culprit. It was the side that had the clamp facing a more favorable position. So with the help of an 18inch long phillips screwdriver i was able to tighten down the clamp just a little more and vualah!! No more leak. I let the car sit for about 2 hours or more and turned the key to "ON" and no fuel discharge coming from the line when cold starting.
Old 01-08-2015, 05:20 PM   #114
GravelRash
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
Oh, the memories...
I did a fix for this back in winter 03/04. In Fraser, CO, sometimes known as the coldest spot in the country. Unheated garage (a friend), one 60W trouble light, -20F outside.
Mine was dripping from the rear clamp, and spraying from the front one, resulting in a noticeable pool in the intake manifold. I tightened the rear one with a long phillips, same as you.
For the front one I used a small long nose vise grip to grab the end of the upside down screw...but after moving hoses/wiring out of the way there was enough flex in the clamp/hose that I couldn't swing the vise grip far enough to move the screw. I had to remove the position sensor for the secondary throttle valve shaft, and then I could get maybe 4-5 deg of movement on the screw with each grab of the vise grips. Got it as tight as I could, which was/is pretty much metal to metal on the two sides of the clamp.
Unfortunately, the sensor housing has a clock spring in it that went "sproing" when I pulled the housing off the manifold. So I didn't know how it was supposed to be indexed when replacing it. After considerable study of the relevant factory shop manual (I had the whole set with me) I decided that the default position of the valves would be closed, which told me how to index the spring - which was of course rotated under tension. I used a thin strip of steel from my tool roll to hold the spring in place, sliding it out at the last moment as I pushed the housing into place. Of course the odds of timing it exactly right so the housing would slide into place before the spring could sproing out of place when removing the steel strip were small to begin with, and Murphy, being Irish, was happy to be hanging out in the cold with me...
Whole job took ~6 hours, 'til maybe 4AM, but it worked. Drove back to my motel, and got up maybe 2 hours later to go to work.
The bad news is that I smell fuel again this winter. I was down in central OR before Thanksgiving, in minus temps, and sure enough it was back. This time I can't see any drip or spray, or any sign of liquid on the IM. Not sure what I'm going to do about it, since a real fix means removing the IM, and I'm not anxious to do that.
I had the engine out of the car a couple of winters ago, and put a slight tweak in the offending steel fuel line under the driver's rear of the IM, in an attempt to keep the hose from being tensioned by shrinking metal in the cold. Apparently either I didn't relax the tension on the leaking hose enough, or the hose/clamp combination is no longer capable of sealing at low temps.
Not sure what I'm going to do about this - other than the 2 fire extinguishers I've got in the car.
GravelRash is offline   Reply With Quote
Old 01-08-2015, 10:03 PM   #115
Bob Jacobson
Member#: 376203
Best answer is pull the intake. There are I think 6 of those little bastards under the intake.
My solution was remove intake apply thread locker and tighten.
It has been -36 to -20 for the last couple weeks and havent smelt anything.
Such a stupid design.
Bob Jacobson is offline   Reply With Quote
Old 01-08-2015, 10:05 PM   #116
chad042288
Member#: 397335
04 Wrx
Yeah. I don't understand why you would place one clamp accessible from the top and the other clamp upside down? It's almost as if these Subaru engineers purposely design these systems so you get irritated just to take it to a shop
Sent from my LG-D850 using NASIOC mobile app
Old 01-09-2015, 09:22 AM   #117
JWX
Member#: 28990
Best solution is to ditch the ****ty factory setup and get fuel rails. Even when you do the "fix" it happens again.
JWX is offline   Reply With Quote
Old 01-09-2015, 08:02 PM   #118
Bob Jacobson
Member#: 376203
Who sells rails? Im probably going to pull the intake again and do tgv deletes this spring.
Considering -30 is a regular occurence every winter here I might as well change out the stock set up.
Old 01-09-2015, 08:30 PM   #119
JWX
Member#: 28990
Google, "Subaru topfeed fuel rails" I really like the perrins, but I highly recommend replacing the plastic fittings they use with metal ones.
Old 01-11-2015, 01:32 AM   #120
chad042288
Member#: 397335
04 Wrx
Angry Effed something up while repairing fuel line
Okay so my temp fix didnt work so I replaced the fuel line with the 5/16 line that was suggested. I had unplugged the two coil packs on the passenger side and what ever that section of wire harness connected to. Without taking the IM all the way out I was able to lift it up enough to get some hand space under to replace the hoses and clamps.
So 5 hours later I get it all done and everything plugged back in and clamps and bolted tight and started the car to purge the coolant system. Ran fine for about 25 minutes total.
Started down the road and under very small amounts of boost I hesitated really bad, so I didnt push it or wot. I drove for about 6 miles and bam...the car dies. Tried restarting it and the only thing I got was the fuel pump relay constantly clicking with the empty fuel light on and my temp needle shot all the way up to very high.
So i dc'ed the battery to reset the ecu...bc with the key in the on position the AP was unable to connect to the ecu. The car turns over but wont start. I checked all my connections every last one of them. Checked all the vacuum lines and they are all connected.
I pulled the fuel pump fuse both under the hood and under the dash. Just continuously clicks. I can hear clicking coming from the fuel filter area and also on the passenger side of the fuel rail. I know i didnt reverse the fuel lines (hopefully) but is it possible for the car to run for a bit and then show these symptoms with that scenario?
If any one has had this issue please feel free to give some insight. I really hope I didnt brick the ECU.
Old 01-11-2015, 01:57 AM   #121
chad042288
Member#: 397335
04 Wrx
Old 01-11-2015, 10:32 AM   #122
danger1138
Member#: 279525
04 rex luger!
Hopefully your mechanic skills are better than your grammar, jeez.
Let me get this straight, you fixed the fuel lines on passenger side without removing turbo inlet? You just lifted that side of intake manifold a little?
Do you smell fuel when you have the key at the on position and fuel pump is priming? Sounds like it could be three issues;
-massive vac leak
- fuel lines still leaking more than before.
- you may have over stretched something relating to the ecu/engine harness.
Old 01-11-2015, 10:48 AM   #123
Bob Jacobson
Member#: 376203
There are a few other connections you could have stretched or broken doing that. Crank position sensor maybe?
I really dont understand how you managed to move the intake at all with one side still bolted down.
You also probably have a massive vacuum/boost leak as the intake manifold gaskets are not reuseable. Id suggest pulling the intake now to check all the connections and replace the gaskets.
Old 01-11-2015, 11:45 AM   #124
chad042288
Member#: 397335
04 Wrx
IM was completely removed.
Mechanical skills are great( was a tech for Honda)
Grammar--I honestly could care.
Old 01-11-2015, 12:00 PM   #125
chad042288
Member#: 397335
04 Wrx
I'm bolts were removed but IM was not taken all the way out...
02 Fuel leak. i dont think its the common leak! Robstunner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-21-2007 12:23 AM
Cold weather fuel leak from stock '02 fuel rails -- kudos to KTR scooterforever New England Impreza Club Forum -- NESIC 10 01-18-2006 05:21 PM
Fuel Leak? Should I get new fuel rails? CtGT Rocky Mountains Impreza Club Forum -- RMIC 10 11-03-2004 02:32 PM
Fuel leak / vacuum leak mmm3587 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-01-2004 08:38 AM
locating fuel leak and re-routing fuel lines Chris Stein Normally Aspirated with bolt-on Forced Induction Powertrain 2 12-09-2002 12:51 PM
