Old 11-05-2007, 06:42 PM   #1
SilverWRX13
Member#: 119571
2007 Legacy 2.5GT
350Z 35th Anniversary
Default What to do?? Coolant Question
I changed my coolant for the first time this weekend. I couldn't get in the full 50/50. Winter is just around the corner and want to make sure I get enough coolant, so it won't freeze up inside my radiator.
My question is can I drain the plastic bottle that holds the coolant? Then add oem coolant with no distilled water in the plastic coolant bottle. Would it recirclelate back into the radiator? or Should I just drain it from the plug on the bottom of the radiator?
TIA
SilverWRX13 is offline   Reply With Quote
Old 11-05-2007, 06:53 PM   #2
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
How close to 50/50 did you get? I'm guessing that you added water first and did not account for the block being filled, then went to add coolant and could not get enough in?
The overflow tank does recirculate back into the system. If you can figure out the proper mix % you can definitely do it that way.
Did you also use coolant conditioner (just wondering)?
surowrxa is offline   Reply With Quote
Old 11-05-2007, 07:08 PM   #3
SilverWRX13
Member#: 119571
2007 Legacy 2.5GT
I premixed the coolant. and I couldn't get in the last 15-20% of the premix in. I also added the coolant conditioner.
Old 11-05-2007, 07:22 PM   #4
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Me too. Clogged arteries here we come (but with no blown headgasket).
Ah, premix. Then yeah, the overflow can be your "rectifier" for your missing mix. You had coolant/water in the block and it took some volume out of your fill calculations.
Did you flush with water or just refill? As long as you had a decent mix in there to begin with (without flushing) you should be fine.
Old 11-05-2007, 07:43 PM   #5
SilverWRX13
Member#: 119571
2007 Legacy 2.5GT
I flushed it with distilled water. I was doing my 30,000. The coolant was really dirty. It was the original coolant. Can to much coolant cause the radiator to break or damage anything? Say 1 1/2 quart of coolant. I might just drain a little to play it safe. I'm probably just being anal about this.
Old 11-05-2007, 08:20 PM   #6
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Hmmm. Well, the extra 15-20% is all water, so...if you add 10% more coolant (after removing some overflow fluid) you're good.
Too much coolant can be bad, but I don't think you'll get there doing this.
Old 11-06-2007, 08:29 AM   #7
LorenzoS
Member#: 50995
2002 WRX Wagon
Having a lower concentration of coolant will raise the freezing point of the coolant. But for the amount you described, this should only be a problem if you live in Alaska. In NJ you are perfectly fine unless we go down to -50 F.
LorenzoS is offline   Reply With Quote
Chicago people, visiting June12 weekend, what to do!?! impreza_GC8 Mid West Subaru Owners Club Forum -- MWSOC 9 06-21-2010 03:30 PM
bad radiator. oil in coolant. what to do!?! koyo users.. jfizzle024 Factory 2.0L Turbo Powertrain 11 06-15-2006 09:27 AM
What to do with used brake fluids + coolant realwomble Service & Maintenance 8 03-16-2005 03:09 AM
What to do and Questions. crashnscar Factory 2.0L Turbo Powertrain 1 12-14-2004 11:57 PM
18g what to do with coolant lines? Works Factory 2.0L Turbo Powertrain 3 04-22-2004 11:37 AM
Message Board Statistics All times are GMT -4. The time now is 11:43 PM.
