Old 11-06-2007, 12:04 AM   #1
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
Default LC-1 logging using Enginuity
I grabbed the test version of Enginuity with LC-1 logging tonight and started her up. Does anyone else use Enginuity for LC-1 logging? Anyone have a clue why all my values are zero all the time when the LC-1 is working fine in LogWorks and I know the right COM port is selected?
Is there some change that needs to be made in the programmer or something?
/Brox
Broxma is offline   Reply With Quote
Old 11-06-2007, 08:40 AM   #2
WeldingHank
Member#: 98645
2002 WRX Wagon
what version do you have? there are a few versions out there. and there are 2 that work. version 774 is the latest version and it has worked flawlessly for myself.
WeldingHank is offline   Reply With Quote
Old 11-06-2007, 08:42 AM   #3
clemsonteg
Member#: 134610
2003 WRX
SONIC YELLOW STG 4
you need to make sure that you go into pluggins every time you start up the test version of the logger and select the com port for the lc-1, then uncheck then recheck the box and it should work
clemsonteg is offline   Reply With Quote
Old 11-06-2007, 09:29 PM   #4
scraggy
Member#: 136384
06 WRX
Dipped with custom blend
Thats exactly what I have to do.
scraggy is offline   Reply With Quote
Old 11-07-2007, 03:28 AM   #5
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
K. It's late but I'll fiddle with it tomorrow.
I have 774 I think. Whatever the last one posted on the Enginuity Forums was.
/Brox
Old 11-07-2007, 12:01 PM   #6
benw
Member#: 103320
1998 swapped
Forester L
+1 this is exactly what I have to do.
benw is offline   Reply With Quote
Old 11-07-2007, 12:09 PM   #7
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
Looks unanimous.
I just woke up so I'm planning on trying to get this to work in a few.
Thanks for the reply's guys.
/Brox
Old 11-08-2007, 02:48 AM   #8
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
I finally did get it to work. Had to change the factory setting in the LM Programmer to gas but it read perfectly. Thanks for all the help.
I may release my map soon. Few more revisions and I may post it.
/Brox
Old 11-08-2007, 03:58 PM   #9
Toolz
Member#: 145568
2002 WRX Wagon
WRB :)
/Brox
Interested in seeing it, what mods do you have?
Toolz is offline   Reply With Quote
Old 11-08-2007, 04:28 PM   #10
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
Catless TBE, Bellmouth DP
Catless UP
P&P TD04
STI TMIC STI Scoop with water sprayer
Perrin Crank Pulley
Injen CAI
Perrin EBCS
Gimmick Turbo Inlet
02 ECU
It has a lot of other mods, JIC FLT A-1 Coilovers, Integrated DIY AC outlet, Short throw, washer relocation, etc. Next I'm doing the TGV's, raising the manifold with spacers, possible reverse with a FMIC and port matching the whole top end.
It's LC-1/Enginuity tuned running max 18 PSI. My DLL dyno last night showed a hair over 240 WHP. I have a new Clutch and Streetlite flywheel going in within the week. I am finishing a few tweaks on the fuel map and then I'll see about posting it.
/Brox
enginuity - how to log LC-1 dynamix Commercial ECU Reflashes 5 11-17-2007 02:39 PM
Data logging with enginuity Nutz North West Impreza Club Forum -- NWIC 5 06-11-2007 09:08 PM
data logging with enginuity Nutz Commercial ECU Reflashes 6 06-10-2007 02:08 PM
Data Logging with Enginuity Brock31 Commercial ECU Reflashes 9 02-16-2007 09:13 PM
LC-1 widband:anybody using a heatsink? quazimoto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-12-2006 08:21 AM
