Welcome to the North American Subaru Impreza Owners Club Thursday April 24, 2014
Old 01-21-2002, 10:05 PM   #1
Kenneth2000
Member#: 6375
2004 STi
Java Black Pearl
Default P1312 - Exhaust Temp. Sensor Malfunction
I just pulled this code from my car.....(2002 WRX)
Does this typically mean that the O2 sensor is screwed? Maybe we goofed it up putting in the new up-pipe & downpipe? (installed them 10 days ago)
Any thoughts? Should I just order a new OEM 02 sensor?
Kenneth2000 is offline   Reply With Quote
Old 01-22-2002, 09:06 AM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
Check again to make sure their aren't additional trouble codes stored, like P0545, P0546 or P1544. If P1312 was the only code stored, then you'll have to replace the EGT sensor (NOT the O2 sensor) which is located on the uppipe.
Jon [in CT] is offline   Reply With Quote
Old 03-18-2002, 10:46 PM   #3
krex
Member#: 14343
Question egt sensor malfunction
i am interested in how this was handled. i have an aftermarket uppipe and downpipe as well, and my egt has decided to quit?
krex is offline   Reply With Quote
Old 03-19-2002, 06:51 PM   #4
WRXSTi69
Member#: 12012
Default Re: P1312 - Exhaust Temp. Sensor Malfunction
Your aftermarket up/downpipes are causing higher than normal exhaust temps, that cooked the sensor. Just hope they're not also causing a lean condition as well, or pistons will be next.
WRXSTi69 is offline   Reply With Quote
Old 03-19-2002, 07:30 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
I happen to subscribe to the theory that the EGT sensor mounting bungs used by most aftermarket uppipes do not allow the sensor to seat properly. This leads, according to my theory, to either a loose sensor or to sensor damage. There probably was a reason why the Service Manual cautioned that the EGT sensor must be oriented in a particular way in the OEM uppipe.
Old 03-19-2002, 11:17 PM   #6
Greenracer6
Member#: 7962
08 335i TwinTurbo
PSM 02WRX, 97 Dipped CRV
Default egt sensor
My stock sensor went bad and caused my car to be a paper weight. I finally made SUbaru change the egt probe at MY expense and that solved the problem. $80, then install ed by Subaru only.
This is upseting of coarse.
Greenracer6 is offline   Reply With Quote
Old 04-04-2012, 12:12 PM   #7
rotheee
Member#: 291964
2003 WRX
So does anyone know for a fact that the probe needs to be oriented a certain way? And if so, what way does it need to be put in?
I need help! I believe this is why my car is stuck in limp mode. Just ordered a new OEM EGT probe for it, will be in soon.
rotheee is offline   Reply With Quote
Old 08-31-2012, 12:03 PM   #8
ToddMcF2002
Member#: 135007
2014 STi Hatch
Crystal Black Silica
Question: I have a megan downpipe and a stock uppipe with the EGT, and a p1312. Should I do the resistor mod or replace the EGT? Thanks for any advice...
ToddMcF2002 is online now   Reply With Quote
Old 08-31-2012, 03:34 PM   #9
ToddMcF2002
Member#: 135007
2014 STi Hatch
OK so I went and did the resistor mod and after driving for about a half hour the code was still on so I cleared the ECU. I drove another half hour and so far no code... but I've been fooled before
Old 08-31-2012, 11:24 PM   #10
ToddMcF2002
Member#: 135007
2014 STi Hatch
I enjoy talking to myself I guess. Maybe it will help someone some day... 70 miles and no cell. Should I get my hopes up? Hard to believe $1.20 in resistors can fix something
exhaust temperature sensor malfunction andrew3776 AccessPort 1 07-31-2008 08:55 AM
how to change exhaust temp sensor? scritchy Factory 2.0L Turbo Powertrain 8 02-05-2007 08:36 PM
P1312 Exhaust temperature sensor malfunction NorCalEnthu Service & Maintenance 1 08-25-2005 12:42 PM
Exhaust Temp sensor on JDM up pipe savageblitz Factory 2.0L Turbo Powertrain 2 01-17-2005 09:08 AM
stock exhaust temp sensor wRx137 Factory 2.0L Turbo Powertrain 1 01-16-2003 09:21 AM
