Old 11-06-2007, 12:49 PM   #1
fractur3
Member#: 151974
Default help with timing
took a look at my timing for my car becuase im having a missfire, and a bit of a hesitation issue at low rpm's. but for my timing advance for A, B and C, at .7 g/rev load at 800 is 8.09 and at 1200 is 5.98.. 8.09 seems way to high because under 2.9 g/rev it is 5.98.. something cant be right, but i dont know what any of this means as far as timing goes, so i dont want to change it because it could be that way for a reason...
then timing compensation for cylinder B and D, is 0 across the board. But for cylinder A, it reads this:
800= 0
1200= 0
1600= 0
2000= 0
2400= 0
2800= 0
3200= 0
3600= 0
4000= 0
4400= 0
4800= 0
5200= -1
5600= -2
6000= -3
6400= -1
6800= 0
then for cylinder C reads:
800
1200= 0
1600= 0
2000= 0
2400= 0
2800= 0
3200= 0
3600= 0
4000= 0
4400= 0
4800= 0
5200= -2
5600= -2
6000= -3
6400= -2
6800= 0
i can send you the rom to your email if you feel like helping me look at it, i have no idea what timing is or how to fix it, so im hoping someone on here does
fractur3 is offline   Reply With Quote
Old 11-06-2007, 01:12 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Those tables are normal, you should leave them alone.
The table you are looking for is Timing Advance, but you need to also look at the total ignition timing. Final timing is a combination of the base timing plus timing advance, having 8 there isn't that much if the base timing in that area is 2 or something like that. Just looking at the Timing Advance won't tell you anything.
Old 11-06-2007, 07:47 PM   #3
bboy
Member#: 56468
04 Improved STI
Dirty White
Yes leave them alone. Those compensate for the propensity of cylinders 2 and 4 to detonate.
Old 11-07-2007, 10:14 AM   #4
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Which cylinder does logged ignition timing monitor? This may explain some STi logs I have of the car running less timing from 5000-6500rpm than base + IAM*KC. KC is exactly what is in the table, feedback correction is 0, but the logged timing is 2-3* less than it should be, but quickly comes back up to normal at high rpm.
06rexwagon is offline   Reply With Quote
Old 11-07-2007, 10:53 AM   #5
Tea cups
Member#: 103136
When you log ignition timing, you are logging cylinder #1 which corresponds to table A. There are also rpm(max), ECT(min), load(min) thresholds involved that determine whether the compensation is active. It is likely that table B,C,D correspond to cylinders 2,3,4.
Tea cups is offline   Reply With Quote
Old 11-07-2007, 04:25 PM   #6
crazymikie
Member#: 56321
2006 Honda El Camino
Green
If A=1, then isn't timing being pulled from cyls 1 and 3?
crazymikie is offline   Reply With Quote
Old 11-07-2007, 06:29 PM   #7
jays05
Member#: 78165
05 STI 35r + e85
Yup and #1/3 are further away from the knock sensor than 2/4
jays05 is offline   Reply With Quote
Need help with timing belt. Norcalrallyist Subaru Conversions 9 07-06-2006 05:13 PM
Advance Utec user Help with Timing. Knocks! Confused on Fuel/Timing Knock. bluesube2000 Engine Management & Tuning 8 11-21-2005 02:08 AM
help with timing belt subiekid Legacy Forum 12 01-06-2004 06:46 PM
Need BIG help with timing pls, take a look at the log. schwarzenegger Engine Management & Tuning 4 12-15-2003 10:14 AM
HELP with Timing Belt J.E.T. Outback Forum 2 12-02-2003 08:52 AM
