Old 11-06-2007, 01:43 PM   #1
drkramm
Member#: 159156
2007 wrx
wrb
Default reflash and warrenty
now i know that if they would see it reflashed they could deny a claim but my question is if i flashed to stage 1 would they have any reason to look at my ecu ?
has anyone takin there stage 1 car in for say an oil change or inspection and for some reason they checked the map
drkramm is offline   Reply With Quote
Old 11-06-2007, 01:48 PM   #2
Gethin
Member#: 2998
They more than likely won't notice the difference. But once you go down this path of modding, kiss goodbye to warranty stuff. IMHO.
Gethin is offline   Reply With Quote
Old 11-06-2007, 02:58 PM   #3
MasterKwan
Member#: 98961
2003 WRX
I have a copy of my stock rom right here. If I think the dealer's going to see it, I'd flash to stock then flash back when I got home.
Old 11-07-2007, 03:30 AM   #4
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
If at any time I brought my car to a dealer, it's to trade it in.
If I was the warranty type, I'd reflash to stock.
/Brox
Broxma is offline   Reply With Quote
Old 11-07-2007, 11:46 AM   #5
drkramm
Member#: 159156
2007 wrx
wrb
if i did flash i would reflash back to stock at any times where i would have to go in for warranty work
but what im concerned is that if say i take it to the dealer for my free inspection for life would they be able to tell it was flashed i know they could tell if they looked but would they look ?
Old 11-07-2007, 11:56 AM   #6
rkramer
Member#: 118209
2015 WRX Limitec
yes if they can tell if it has been flashed and then reflashed back to stock. in most cases though it is fairly rare for them to check.
Old 11-07-2007, 12:10 PM   #7
drkramm
Member#: 159156
2007 wrx
wrb
that what i wanted to know is there a reason other then to check the base map for them to actually look in there
Old 11-07-2007, 01:01 PM   #8
drkramm
Member#: 159156
2007 wrx
wrb
well i called a dealer just to ask them and i said "if i were to reflash my computer with a cobb ap would this make it possible to deny a claim " there short answer "yes"
then i asked if i were to bring it in for normal maintenance oil change inspection what have you, he said "if theres no reason to check it they wouldn't check the computer but if there is a problem with inspection ( emissions ) they would look into it more and may find it with the flash if the flash has made modifications to the emissions that cause them to go out of spec"
he also said " but that would throw a cel so that would be your first clue"
annnnnddddd
"but these cars are built very tough
Old 11-07-2007, 02:39 PM   #9
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
Open sorce doesn't change the calibration ID's not sure about AP's. Only way a dealer would know for sure is when they test drive car and boost levels are raised and timing maps are different, they will notice.
icslowmo is offline   Reply With Quote
Old 11-08-2007, 08:30 AM   #10
drkramm
Member#: 159156
2007 wrx
wrb
yea i just asked with cobb so they wouldn't know i was the tuner lol
anyone ever have problems with emissions testing ? i still have both cats but i don't want to have to reflash every year to pass inspection
Old 11-08-2007, 02:37 PM   #11
Loubaru
Member#: 155489
07 STi
huh? so did you actually talk to the dealer?
Loubaru is offline   Reply With Quote
Old 11-09-2007, 12:47 PM   #12
drkramm
Member#: 159156
2007 wrx
wrb
yea i just told them it was a cobb ap not open source
if i would flash it would be with open source
Cobb reflash and dealer reflash question battosai Bay Area Impreza Club Forum -- BAIC 0 09-11-2003 11:23 PM
Unichip and warrenty?? questWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-17-2001 10:21 AM
turboback exaust and warrenty questWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-10-2001 08:40 AM
Boost Controller and warrenties Fyxtion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-24-2001 09:53 AM
Q about ABS and warrenty Jonathan_Yi Brakes, Steering & Suspension 1 02-05-2001 06:09 PM
