Old 01-22-2002, 08:06 AM   #1
wreed
Member#: 14114
1999 Outback
Default 17" wheels on Outback?
Has anyone tried 17" wheels on a stock-suspension Outback? If so, what offset works best, and what tire size did you end up with?
To me, it looks like a 225/55r17 set-up would most closely approximate the current diameter of my stock wheels/tires.
Also, would the bigger wheels yield noticeable improvements in handling even though the suspension remained unchanged (from stock)?
Thanks!
wreed is offline   Reply With Quote
Old 01-22-2002, 10:15 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
First off, you will most likely need around the stock offset +53mm for tires that big. I've heard of people puttin on 215's, but not 225's
and Yes wider/larger wheels and tires does wonders for handling. That was probably one of the most dramatic changes in handling performance I did....just goin from the stock 14" wheels/tires to 16" wheels and tires. It's like driving a completely different car.
Legacy777 is offline   Reply With Quote
Old 01-22-2002, 10:34 AM   #3
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
A friend of mine has Team Loco 142s on his Outback with stock suspension wearing 215/45-17 Kumho Ecsta 712.
Let it be known that this car beat me in an auto-x once, i was mildly humiliated, but he did have a TCII, 5MT and working AWD.
DLC is offline   Reply With Quote
Old 01-22-2002, 08:36 PM   #4
Mako
Member#: 5770
2000 Legacy Outback
Green with Stromung & CAI
Default Sidewalls
I'm considering 17"s for my OB as well. Will having less sidewall be a major factor offroad?
I'd probably get 225-55/17 Pirelli Scorpions.
Mako is offline   Reply With Quote
Old 01-22-2002, 08:45 PM   #5
shirokuma
Member#: 5489
2013 FR-S
AVO Orange
All right, wait a minute. Unless I'm wrong, underneath the fender add-ons, the Outback has sheetmetal in exactly the same place as the standard Legacy line. If so, 225 series tyres will most likely rub on the fender. It is possible to get 225 series tyres on a Legacy, but usually you have to roll the inner fender lip up, which will probably mess up the paint there.
The standard rubber for Japanese spec Legacies is 215/45 17, and if the offset of non-stock rims is off enough, those will rub also.
Paul Hansen
shirokuma is offline   Reply With Quote
Old 01-22-2002, 10:04 PM   #6
Buell
Member#: 13494
2001 Outback VDC
Grey
It would be interesting to know if the 225 setup works for you- I might be considering the same thing.
Buell is offline   Reply With Quote
Old 01-22-2002, 10:27 PM   #7
Mako
Member#: 5770
2000 Legacy Outback
Default stock size
Stock tire size on my 2000 Legacy OB were 225-60/16 they fit perfectly
Old 01-22-2002, 11:58 PM   #8
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I have 225s on mine, lowered, but i do have enough negative camber that it doesn't rub.
Old 01-23-2002, 12:45 AM   #9
Gmachine
Member#: 8789
2006 Legacy Spec B
The Tirerack list the 225/55-R17 as the "Plus 1 size" for the 2000+
Outback. I just mounted Blizzaks on the stock 16's, and am planning to buy 17's for the warm months.
I don't see why the 225's would not fit as long as the wheel offset is correct. (99 and older models )
Dave C
ps. by chance would anyone know if stock WRX front brakes would bolt onto stock 2000 Legacy Outback?
Gmachine is offline   Reply With Quote
Old 01-23-2002, 01:37 AM   #10
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
You don't want 17" rims if you drive offroad. 16" is pushing it and they had better be strong rims. You will bend 17" rims because they do not have enough tire to protect them.
Rally cars run 15" rims. Smaller rims also rotate faster (assuming you don't have big tires on them).
remarcable is offline   Reply With Quote
Old 01-23-2002, 01:52 AM   #11
Gmachine
Member#: 8789
2006 Legacy Spec B
I agree with you about the 17" and offroading thing, but the wagon belongs to the wife and she never ever goes off tarmac!
We both commute together and I usually drive(rather briskly).
Originally wanted her to buy the GT wagon instead, but she likes the look of the Outback better.
Dave C
Old 01-24-2002, 04:21 PM   #12
dscottf
Member#: 3312
1999 Outback Wagon
Sapphire Blue
Default Re: 225s on a '99
On a MY99 (the original poster's car) I think 215 is the max due the the rear struts (at least on mine, there is not 5mm of clearance between the strut and my 215 SP 5000s)
2000 and up have a totally different rear suspension (I don't think they have rear struts), so they can have wider tires.
Some 225s may fit (225 does not nessessarily mean 225mm, there is some variation in hoe they can measure it), but you would have to put them on see if they rub.
So, to maintain the proper outside diameter, you would need a 215/55/17, of which tirerack only lists two 'standard touring' catagory tires.
You will be better off with 205/55/16's like Remarcable or 215/65/15's like mine (and I would be leary of 16s with the impacts I have had)
dscottf is offline   Reply With Quote
WRX wheels on outback wagon jpf310 Tire & Wheel 2 06-15-2009 12:53 PM
outback 17" wheels on 06 WRX verdee Tire & Wheel 1 01-05-2008 11:39 PM
Will STi Brembos fit under P1 17" wheels on WRX? MDRex Brakes, Steering & Suspension 9 04-05-2005 01:59 PM
17" wheels on a WRX ElectricEye Tire & Wheel 9 02-08-2005 12:55 PM
Finally got my blingin' 17" wheels on gjhsu Member's Car Gallery 16 06-18-2004 12:27 AM
