Old 11-08-2007, 09:26 AM   #1
Holypiston
Member#: 50351
Default Useing up rear tires
I wear the rear tires a lot more than the fronts, good quess would be twice as much than the fronts. Reasons why? I thought I would use up the fronts more being heavier on the front and the car's wanting to push.
stock suspension WRX, 17" subaru wheels, lots of back country roads, good even wear across the tires.
Holypiston is offline   Reply With Quote
Old 11-08-2007, 02:56 PM   #2
flukewrx
Member#: 75081
2003 WRX
How often do you rotate your tires?
How often do you get an alignment?
What are your air pressures in your tires?
flukewrx is offline   Reply With Quote
Old 11-12-2007, 10:42 AM   #3
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
Driving style. I bet you are the type that brakes early, gets the back to rotate, and powers through the corners. Reason why: because I do the same. I also really wear the rears more than the fronts-even on my Baja.
I do it even when I'm driving normal speeds and don't think about it. It took awhile for the wife to get use to it (getting on the gas entering the corner). I think it comes from years and years of racing karts.
If your tires have even wear across the tread your pressures are perfect.
WRX03 is offline   Reply With Quote
FS: (4) Used Bridgestone RE070 Tires (225/45/17) /Rear Camber Bolts/ 3rd Brake Light ccss NWIC Private Classifieds 7 06-01-2010 01:29 PM
FS: Pick up in S.NJ- Used WRX Rear Rotors ScoobyNubieToo! Tri-State Area Private Classifieds 0 01-27-2009 06:49 AM
FS: 04 stock WRX wheels with used up tires. trevoro NWIC Private Classifieds 1 07-26-2006 12:24 AM
If I staggar my rear tires will it mess anything up? FastSubaru8 Transmission (AT/MT) & Driveline 10 05-25-2006 01:34 PM
Rear tire pressure up or down to increase oversteer? boxerT Brakes, Steering & Suspension 10 07-02-2004 01:49 PM
