Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 11-20-2007, 02:48 PM   #1
Built Industries
Vendor Sales Rating: (24)
Member#: 33839
Default Slowboy Racing Overstock List Sale!
Please call into our sales line for pricing! 724-349-8417
ACT SB2-HDSS x 1 (ACT Subaru Impreza 2100 Clutch SB2-HDSS)
600175 x 2-WRX Flywheel
600170 x 1-WRX Prolite Flywheel
AEM 30-1910-AEM Fuel / Ignition
Controller (F/IC) AEM 30-1910
AEM Uego's-5 in stock
30-4300 x 8-19 Channel Serial Gauge -
23-852C x 2-AEM cam Gear (single) for 4g64 AEM 23-852C/R/B
23-802B x 1-99-00 B16 Adj. Cam Gear (single gear) Red. AEM 23-802
30-4350 x 2 -52mm Boost Control Gauge
AEROMOTIVE:
14132-Aeromotive Evo Billet Fuel Rail - AER 14132 ( 7 in stock)
12302-Pro-Series, In-Line Fuel Filter (AN-12) 100 micron stainless steel element
14105-Fuel rail Mitsu 4 cyl
11106-Aeromotive 800 HP Pump
13105-Compact EFI Regulator, Billet, Adjustable, EFI, (1) AN-6 male inlet and return, AER 13105
12301-Aeromotive 10 Micron Fuel Filter
12304-Aeromotive 100 Micron Fuel Filter
APEXI- 147-KM01 (2G AWD downpipe)
NEO's-11 in stock
Blitz SBC-1DIII Black 15095 sequential boost controller
Brad Penn Oil
COBB-
513500 (SS turbo heat shield WRX/STI)
511301-Cobb Urethane Exhaust Hanger Subaru Impreza STi 2004-2007
111212 (brake pads, 05-06 Rear Subaru Legacy GT)
213320 x 4 (Shifter bush 02-06 WRX)
213315 x 2 (STI double adj, 6 spd shift)
912240 (WRX Tubular anti sway bar kit-front and rear)
Cosworth:
KK3814-Subaru WRX STI EJ25 (2.5L) Set of four (AVCS Type) North American spec Int."260" deg. 9.6mm lift / Exh. "260" deg. 9.6mm lift
20000922 x 2-WRX EJ20 Head Gasket Bore = 93mm T ~ 1.1mm each COS 20000922
20000916 x 2-STI Bore= 101mm T ~ 1.1mm each COS 20000916
20000913 x 2-STI Headgasket Bore = 101mm T~ .78 mm each COS 20000913
SB0006 x 4-High Performance Engine Bearings Subaru WRX/ STI EJ25/EJ20 Main Bearing Set-Tri Metal: Race
PR7243 x 2-Head Stud Kit Subaru WRX STI EJ25/EJ20 (2.5L) 11mm
PA2667-Forged Piston Sets Subaru WRX STI EJ25 (2.5L) 99.5mm 8.2:1cr Includes pistons, pins and circlips
DEI-lots of all this stuff in stock!!!
Fidanza
110661 x 2 (STI flywheel 04 and up)
Greddy Exhaust- 10136622
Hawk HB367F.585 (95+ Rear brake pads)
HB 352F3665 (front brake pads, WRX)
INNOVATE:
3730 (3 instock)- 6-ft. long, mini to stripped-and-tinned, matching LM-1 analog output specifications. The cable has (2) Analog Outputs 0-5 volts that are fully programmable with the LM-1 software. - Innovate 3730
3741 (lots in stock)- Serial cable - Innovate 3741
3737 (lots in stock)- Bosch LSU4.2 5-wire, wide-band O2 sensor (replacement LM-1 Sensor) - Innovate 3737
3723 (7 in stock)- LM-1 BASIC KIT - Innovate 3723
3769 (5 in stock)- LC-1 Lambda Cable (Standalone Wideband Controller and Sensor) Innovate 3769
3780 (5 in stock)- Innovate XD-16: (16 in 1 gauge only)
3781 (3 in stock)- Standalone Wideband Guage kit - Innovate - 3781
K&N-lots and lots in stock!!
RU-3480 (2G- 4")
E2875 (1G)
33-2232 (WRX 02+)
HP-1010 (oil filter)
57-5504 (2G FIPK)
33-2105 (EVO 8)
69-8001TS x 10 (typhoon system )
KOYO-
R2704 x 3 (03-06 WRX)
Mahle
SUB209917I22-1 set-Subaru 2.5L TURBO US STI 8.5:1 Pistons 99.5mm Bore std - Mahle SUB209917I22
Magnaflow 10778-Magnaflow 3" Y pipe dual 2.5" outlet - Magnaflow 10778
Motul- Dot 5.1 Brake Fluid
Engine clean
SAE 90
SAE 5W30
SAE 15W50
Fuel system cleaner
Brake cleaner
PE oil filters, mag power II-OF-04A
Perrin PSP-ENG-201-black-Perrin Performance Subaru WRX Top Feed Fuel Rails - Perrin PSP-ENG-201
Redline 75W90
Tial WG-38 and 44
Tial BOV
TUR 10763-Turbonetics RAPTOR BOV Kit 17063
TURBOS-
PTE PTB-300-5031E-Precision 50 Trim, Stage 3 Wheel, E Cover PTB 300-5031
PTE-PTB 300-6152E-6152E Standard Bearing *Please specify Housings* - PTB 300-6152 (THM3-52 housing)
PTE PTB 400-6077-PTB 400-6077 4" inlet/ 2.5" outlet, THM3.76W housing
PTE PTB 300-6031E-PTE 60-1 with Stage III Turbine Wheel PTB 300-6031E, THF 3.31W housing
PTE 300-6153-PTE 6152RE Dual Ball Bearing Turbo PTB 300-6153
SBR- 4342- WRX/STI 20G 06H turbine wheel w/ 8cm Housing SBR-4342 (2 in stock)
SBR-4312- WRX/STI 20G 06H turbine wheel SBR-4312- no gaskets x 2
SBR-4455-WRX/ STI GT 35R BB Internal WG SBR-4455 (1 in stock)
SBR 4403-WRX/ STI GT13 BB External WG 700177-0013 CHRA (one in stock)
SBR-4452-WRX/ STI GT12 BB Internal WG 700177-0012 CHRA (3 in stock)
Borg Warner-KO4E-53049500001 x 1
53049880015 x 1
EVO III 16 G's x 11
Built Industries is offline
Old 11-20-2007, 05:19 PM   #2
Ammata
Member Sales Rating: (9)
Member#: 155819
2004 Impreza WRX
how much for the sbr 20g 8cm?
and also the evoIII 16g
Ammata is offline
Old 11-20-2007, 08:23 PM   #3
dunnojack
Member Sales Rating: (3)
Member#: 91713
how much for the aeromotive fuel rails?
dunnojack is offline
Old 11-20-2007, 10:16 PM   #4
Raf
Member Sales Rating: (4)
Member#: 13258
2002 WRX Wagon
WR Blue
Can I get a price on the EVO III 16G.
Raf is offline
Old 11-21-2007, 09:53 AM   #5
Built Industries
Member#: 33839
for a mitsu? evo? we only have perrin or turboxs for sube's
Old 11-27-2007, 04:48 PM   #6
vangstaboi86
Member Sales Rating: (42)
Member#: 119945
2004 sti
java black pearl
om me on the sbr 20g 8cm
vangstaboi86 is offline
Old 11-27-2007, 07:33 PM   #7
orwrx
Member Sales Rating: (102)
Member#: 33869
2002 wrx
rally blue
How much shipped to CA94044 for the 912240 (WRX Tubular anti sway bar kit-front and rear)? Is it just the two swaybar? Or it comes with the swaybar mount for the rear too?
orwrx is offline
Old 11-28-2007, 05:40 AM   #8
wuuusaa
Member Sales Rating: (20)
Member#: 92894
2015 Wrx
Mike,
when is you guys fmic coming out?
still waiting for pics
wuuusaa is offline
Closed Thread
Slowboy Racing is hiring!! Sales / Techs / Machine Shop Help! Built Industries South East Region Forum 1 02-17-2010 04:39 PM
Slowboy Racing Overstock List Sale! Built Industries Engine/Power/Exhaust 4 02-11-2008 02:16 AM
Slowboy Racing New Website Sale!!! Built Industries Engine/Power/Exhaust 0 03-08-2007 07:46 PM
Slowboy Racing Head Parts Sale!!! Built Industries Engine/Power/Exhaust 0 11-06-2006 03:43 PM
Slowboy Racing Turbo for Sale dlewis Private 'For Sale' Classifieds 5 06-26-2005 02:51 PM
