Old 04-16-2008, 12:10 PM   #51
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I would have planned on changing the return line anyhow...fuel in, fuel out. If you can flow too much in-in comparison to what you can flow out, I think you'll have an issue.
If you are going to run it that way, just go to a hardware/autoparts/plumbing supply and find a stepped fitting and use hose clamps.
what size is the oem lines and what size is your return from FPR?
Old 04-16-2008, 12:37 PM   #52
ec2k1gt
Member#: 129631
06 Obp Sti
back to slow lolz
-8 feed and -6 return. Oem return line is 5/16.
I would go with a stepped fitting but i dont think it would seal all to well. The hoses on the 06 are rubber with a hard plastic sleeve running through them.
-Vic
ec2k1gt is offline   Reply With Quote
Old 04-16-2008, 12:51 PM   #53
Homemade WRX
Member#: 33782
96 bastard child
I'd completely replace the line and use a bulkhead fitting at the tank.
Old 04-16-2008, 04:02 PM   #54
SaabTuner
Member#: 67608
Here's some nice, and special static-dissipating, "teflon" based braided steel hose, rated for 5,000 psi. You could probably put these in the cabin safely: http://www.ushosecorp.com/index.cfm/...uctID/1640.htm
Their Inconel 625 alloy hoses, up to 4" diameter might also interest certain people here looking to replace header flex-sections with something that takes a bit more thermal beating: http://www.ushosecorp.com/index.cfm/...uctID/1570.htm
I'll probably make a post about that in its own right. AFAIK, no aftermarket supplier here offers inconel flex sections that withstand 1800*F. Maybe soon, someone will?
SaabTuner is offline   Reply With Quote
Old 04-16-2008, 04:56 PM   #55
ec2k1gt
Member#: 129631
06 Obp Sti
back to slow lolz
Just purchased the lines and fittings. Ill be running both feed and return underneath the car for peace of mind, last thing i need is a ruptured line in the car.
-Vic
Old 04-16-2008, 05:03 PM   #56
Homemade WRX
Member#: 33782
96 bastard child
-12 to -24...that's some big line for our fuel systems...now if I were running meth or nitro-meth, those sizes could apply
hmm...
Old 04-16-2008, 05:06 PM   #57
SaabTuner
Member#: 67608
-12 to -24...that's some big line for our fuel systems...now if I were running meth or nitro-meth, those sizes could apply .
You misread it. Those are the larger sizes, and mentioned specifically because, in those sizes, additional layers are added for strength.
Typically, the lines are smaller.
Old 06-24-2008, 01:12 PM   #58
dunk
Member#: 15359
Started working on aquiring parts for my surge tank yesterday, after experiencing fuel cut at the 1/2 tank mark on my last track day.
Will be using a 2L tank and a walbro external in-line fuel pump. I plan on keeping the stock hard lines running through the car as it only makes about 400 whp. I'll post some pictures as I get everything together.
Duncan
dunk is offline   Reply With Quote
Old 06-24-2008, 03:31 PM   #59
9vapors
Member#: 92582
Yeah, just get the one from SMP, cheapest and is really well made.
9vapors is offline   Reply With Quote
Old 06-25-2008, 11:08 PM   #60
SL,UT_STI
Member#: 161458
1999 BLK 2.5RS
Swap in progress
whats SMP website?? i googled but nothing
SL,UT_STI is offline   Reply With Quote
Old 06-26-2008, 01:11 PM   #61
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
look for speed machine performance... I think their price went up !
engineerx is offline   Reply With Quote
Old 06-26-2008, 04:15 PM   #62
9vapors
Member#: 92582
I just tried to go to their website, and it seems down... Not sure, maybe it's just blocked from work.
Old 06-26-2008, 04:35 PM   #63
engineerx
Member#: 42614
0405 WRX STi/S2000
call them... maybe they went out of business?
http://411.sandiego.com/Speed+Machin...049p.home.html
Speed Machine Performance
1185 Park Center Dr
Vista, CA 92081
Business Summary
Contact Speed Machine Performance
Phone: (760) 727-8700
Old 06-27-2008, 11:46 AM   #64
dunk
Member#: 15359
Their website has been down for a few days.
Duncan
Old 07-07-2008, 01:00 PM   #65
engineerx
Member#: 42614
0405 WRX STi/S2000
I keep getting asked questions about my setup... so here's the answer
Originally Posted by Fellow Nasioc Member
I am working on my fuel setup. I plan on doing a walbro in tank to a surge tank then to a bosch 44 and filter pretty much like everyone else. I was wondering how much line you used in your setup and it looks like from your pics you used the prolite hose. Is that stuff easier to use compared to the braided ss? Do you get any fuel smell in the cabin?
-6 from tank to surge tank 3x 2'
-8 from surge tank to 044 1x 3.5'
-6 from 044 to fuel rail 1x11'
These lenghts are approximate. I recommend you first decide where you are going to route your lines then measure the path - add 1 foot so you don't end up short.
You'll benefit from my experience: I tried the pro-lite.... it sucks. While it's easier to couple the fittings and lighter than all other hoses, the fumes seep out when the car is parked and foul your cabin. Don't use it.
I used Icore (teflon lined) from tank to surge tank (from ebay Nascar surplus) and steel braided teflon-lined "SpeedFlex" hose & fittings from Earl's - go to ANPLUMBING.COM- fume problem solved!
I recommend you use Speedline on all your lines. You'll be happy you did.
Hope that helps
-Roland
Old 07-20-2008, 11:40 PM   #66
dunk
Member#: 15359
Finished my surge tank setup this weekend. Using the factory metal lines to run through the cabin. Pump is a walbro external. I also installed a metal bulkhead between the trunk and the passenger compartment. This is a track only car.
Some pictures.
Old 07-21-2008, 03:34 AM   #67
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
I just bought a surge tank like that but all the fittings were wrong. Did you just use a fuel pump relay kit to wire in your external pump?
speed_freak27 is offline   Reply With Quote
Old 07-21-2008, 03:36 AM   #68
engineerx
Member#: 42614
0405 WRX STi/S2000
Looks pretty good!
I like your firewall and it definitely is a good idea to have if you're not running the rear seatback cushion. I've been thinking about fabbing a firewall even with the seats, for peace of mind
Consider wrapping the power (+) cable on the pump. It shouldn't short unless you got some metal stuff in the trunk... but just for added safety
Old 07-21-2008, 08:49 AM   #69
dunk
Member#: 15359
I used a standard bosch relay. Tap'd the negative on the factory pump as the trigger so the pump primes and turns off with the factory pump. Power comes directly from the battery located in the trunk.
Duncan
Old 07-21-2008, 08:52 AM   #70
dunk
Member#: 15359
Originally Posted by engineerx View Post
Looks pretty good!
Thanks for the compliments.
The firewall was a last minute decision. It was pretty easy to fabricate using cardboard as a template. It bolts in to the factory locations where the vertical seat back braces used to be and has some extra rivets around the perimeter. Only cost about 40 dollars in materials.
Good idea on the postive pump wire.
Duncan
Old 07-21-2008, 05:14 PM   #71
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Sweet setup Duncan!
mick_the_ginge is offline   Reply With Quote
Old 07-22-2008, 10:45 AM   #72
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
It looks pretty good. Where did that tank come from? I've been looking for one identical to that.
bluescoobywagon is offline   Reply With Quote
Old 07-22-2008, 11:24 AM   #73
dunk
Member#: 15359
Tank came from ebay.
Old 09-14-2008, 12:15 AM   #74
Process West
Member#: 71459
2008 STi Silver
R Spec
Originally Posted by ec2k1gt View Post
Ran into a small snag yesterday. I was running all the lines yesterday and realized that the 06 comes with quick dissconnect lines. I have already purchased and cut all the braided hose, but need the fitting I have listed in the picture so I can use the factory return line, instead of having to rerun a new line from fpr to the surge tank. My original plan was to use the same fittings that engineerx used on his setup but from what i found out yesterday thats not gonna happen. Anyone know where i can pick up the fittings that are shown in the picture below?
I can supply you those fittings...they are about $700 and come with a free surge tank and Bosch 044 pump ;-)
Kev
Process West is offline   Reply With Quote
Old 05-10-2009, 01:32 PM   #75
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
For all those running crazy setup fuel systems, are you still running stock return lines? Or do you change those out as well?
D Money is offline   Reply With Quote
Need APS fuel system and tumbler deletes to use APS fuel rails? GoRacerXGo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-17-2005 03:07 AM
Difference between fuel SYSTEM cleaner and fuel INJECTOR cleaner? burnout555 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-17-2003 12:52 PM
Maximum HP on stock RS fuel system with walbro fuel pump Chav Normally Aspirated with bolt-on Forced Induction Powertrain 11 06-17-2002 04:42 PM
fuel system managment system jeffsnyder Normally Aspirated Powertrain 2 09-23-2001 02:13 PM
Fuel Injectors / Fuel system JC SPORTS Technical Forum Archive 75 07-14-2000 09:51 PM
