Old 01-17-2013, 11:07 PM   #1526
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Originally Posted by spoolinsti05 View Post
If its hooked to the manifold it won't release tank pressure when the cars in boost.
That's what the solenoids are for. It should only purge under certain conditions, low load high vacuum. Sometimes the vacuum source is the intake pre turbo
Old 01-18-2013, 09:05 AM   #1527
...CHUCKLES...
Member#: 149674
2006 LimitLess STI
SGM
As far as the plumbing the EVAP, I just let that sh** dangle with a K&N crankcase filter on it.
So far for me it has worked out just fine and looks pretty nice.
...CHUCKLES... is offline   Reply With Quote
Old 01-20-2013, 03:34 PM   #1528
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
How are you guys removing the factory fuel lines when replacing/upgrading the line sizes?
Big-Sexy907 is offline   Reply With Quote
Old 01-20-2013, 04:00 PM   #1529
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Rally Stuff
1. Remove intake manifold
2. Remove fuel rails
3. Re-install intake manifold
4. Profit
Old 01-20-2013, 09:55 PM   #1530
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
4. Profit
I meant when you're running a new line from the rear of the car to the front of the engine bay. Goob
Old 01-20-2013, 10:58 PM   #1531
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
We don't.
jnorth85 is online now   Reply With Quote
Old 01-20-2013, 11:25 PM   #1532
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
So what I'm hearing is I'd be better off asking Wayno, Joy, or D, how to go about it.
Thanks for the help!
Old 01-20-2013, 11:32 PM   #1533
jnorth85
Member#: 76785
SRP
They cut the lines and take them out in sections.
Old 01-26-2013, 05:46 PM   #1534
Scargod
Member#: 260314
2008 STI hatch
Default Ate the whole damn thing!
I've read it all; gobbled it up. Thanks to everyone, especially the satanic eggroll.
I'm not a special case, but I would like advice... 2008 STi track car.
I have the typical Walbro 255 in my tank. I have Boomba rails and a modified Boomba distribution block so everything is AN-6 or larger. I have Aeromotive FPR. I stripped out all the OEM stuff from the fuel lines and opened them up so there are no restrictions smaller than AN-6. Right now I do 400whp/400fpt with ID 1000 injectors. I've even run 28 PSI with this setup!
I am building a 600 HP motor so I end up with at least 450WHP. I plan on using ID 2000 injectors. I've used all the calculators and looks like I need 320-340 L/hr of fuel. It seems that I could install a Walbro 400 in my tank and be done with it. I do not want to do a bulkhead in my hatch if I can help it. I'd like to keep the pump in-tank for 1) cooling the pump and, 2) simplicity and, 3) not needing to have a bulkhead.
I intend to do an in-tank swirl pot/a baffled chamber around the pickup. I am willing and capable of a custom mods in that area. I will run 100 octane (Torco modified) 93 pump gas.
Does anyone have a better idea for me? I was thinking about an external pump and Hobbs switch in addition to my in-tank Walbro. Seems I am close to needing to do a lot more, but not quite there.
Thanks
Scargod is offline   Reply With Quote
Old 01-26-2013, 09:52 PM   #1535
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Scargod, I was debating on going with an surge tank mounted in the trunk. Radium has some very nice looking pieces at very affordable prices. I'm looking to rework my trunk area so the layout of equipment looks appealing. Realistically using a swirlpot is the only reasonable thing for me to do.
Old 01-27-2013, 02:34 PM   #1536
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Radium affordable? Last time I looked they were quite expensive.
alcoolaid is offline   Reply With Quote
Old 01-27-2013, 03:53 PM   #1537
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Radium was 400+ without pumps. Probably still is. Looks beautiful though. Would have jumped on it if it had -10 and -8 fittings. It has all -6.
slowgenius is offline   Reply With Quote
Old 01-27-2013, 06:31 PM   #1538
explicithero
Member#: 15893
2004 STi
The color of the burgh
When are you going to get your car up and running. 2014?
explicithero is offline   Reply With Quote
Old 01-27-2013, 08:14 PM   #1539
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Good Lord, what size injectors, fpr, and return line are you running?
Old 01-27-2013, 11:38 PM   #1540
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
sard has some nice tanks on rhd japan. 250ish for a 2ltr.
scby rex is offline   Reply With Quote
Old 01-27-2013, 11:57 PM   #1541
Ballistic1350
Member#: 156877
04 sti
Too bad they're aluminum
Ballistic1350 is offline   Reply With Quote
Old 01-28-2013, 03:12 AM   #1542
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Radium has a pump manifold that joins the output of both pumps and goes to a -8 fitting. Total cost including pumps is about 1k.
I'm waiting to see if D$'s old setup is getting used or not before purchasing.
Old 01-28-2013, 03:49 AM   #1543
berdugo
Member#: 163108
07 EuroDM STi 2.5L
I have Sard 5L surge tank (not yet installed), I had it anodized.
berdugo is offline   Reply With Quote
Old 01-28-2013, 05:22 PM   #1544
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Lol my new goal is by summer 2013. I think i settled on the gtx3076.
As far as lines i really want to run a flared stainless hardline and return. If not some teflon lines. I have 1.5L cx racing surge tank, aluminum that i need to get anodized.
My fuelab pump requires a -10 inlet so it doesnt burn up.
Old 02-07-2013, 08:41 PM   #1545
WhatTurboLag?
Member#: 243992
2006 WRX TR
Would a fuel system just in the trunk (surge tank feeding a inline pump) be a good idea for an otherwise stock fuel system. Will later do the whole thing
WhatTurboLag? is offline   Reply With Quote
Old 02-08-2013, 11:35 AM   #1546
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
As long as your pump can handle it, the stock lines are pretty decent size. I dont see why my inline pump wouldnt work as long as the inlet was the right size, to use untill they became a restriction.
Old 02-08-2013, 01:22 PM   #1547
WhatTurboLag?
Member#: 243992
2006 WRX TR
I was thinking about doing it on my vf39 for now just so I don't have to worry when running less than half a tank of gas. And then for when I go big turbo.
Old 02-08-2013, 03:50 PM   #1548
alcoolaid
Member#: 134949
'07 SWP STi
If you plan to do some road course then yes! Fuel starvation is a bad thing.
Old 02-08-2013, 06:52 PM   #1549
WhatTurboLag?
Member#: 243992
2006 WRX TR
That I will be. And its not a ton more expensive to do than just upgrading the pump. Will a single 044 be good enough for like 600whp on e?
My wally 255 would be the lift pump.
Aso, is possible to make one with a fuel door on it so you can just little amounts of e85, race gas etc and run the tank on empty or even shut the lift pump off to act as a small fuel cell for say the drag strip?
Old 02-10-2013, 08:33 AM   #1550
Scargod
Member#: 260314
2008 STI hatch
Got my ID 2000 injectors. Got my BW 8374 turbo. I am expecting 450 WHP.
I am going to add a Bosch 044 inline and I am going to try and do an in-tank surge suppressor, in addition to, or in combination with, the Walbro 255 in the stock pickup, or as a replacement for the stock fuel pick-up setup. There's got to be something you can do in-tank versus an expensive swirl pot.
Need APS fuel system and tumbler deletes to use APS fuel rails? GoRacerXGo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-17-2005 02:07 AM
Difference between fuel SYSTEM cleaner and fuel INJECTOR cleaner? burnout555 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-17-2003 11:52 AM
Maximum HP on stock RS fuel system with walbro fuel pump Chav Normally Aspirated with bolt-on Forced Induction Powertrain 11 06-17-2002 03:42 PM
fuel system managment system jeffsnyder Normally Aspirated Powertrain 2 09-23-2001 01:13 PM
Fuel Injectors / Fuel system JC SPORTS Technical Forum Archive 75 07-14-2000 08:51 PM
