Old 11-08-2007, 05:21 PM   #1
KevlarSTi
Member#: 134036
2007 STi Limited
Satin White Pearl
Question TGV Delete on 07 STi - Motor/Sensor Unit and CEL?
I did a search, but couldn't turn anything up - I have an 07 STi, and I know that, unlike the previous STi and WRXes which had separate motors and sensors, the 07 has these combined in one unit. I picked up some used OEM 07 STi TGVs and plan on deleting the valves and dividers from them before swapping them out for my stock TGVs, but it'll be a few weeks before I'm able to make it down to GA to get a tune, and I'd like to prevent any CELs in the mean time.
What I'm wondering is, if I just disconnected the motor/sensor units from the TGVs and zip-tied them somewhere out of the way, would that throw a CEL? What that would hinge on, I think, is whether the sensor simply measures the angle of rotation from the motor to tell the motor when to stop/start, or if there is some sort of physical stop within the TGV that prevents the plate from opening/closing past a certain point, and the sensor simply confirms this position or lack of movement. Does anyone have any knowledge about this matter?
Thanks
KevlarSTi is offline   Reply With Quote
Old 11-08-2007, 06:21 PM   #2
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
If you have a spare pair, why dont you just do your delete on the spares, then zip tie the intact units somewhere in the engine bay for now?
vision.dynamix is online now   Reply With Quote
Old 11-08-2007, 06:45 PM   #3
KevlarSTi
Member#: 134036
2007 STi Limited
Satin White Pearl
That's what I said I'm doing (doing the delete on the spares, then pulling the original TGVs and putting the modded spares in). I'm just trying to figure out if zip tying the original motor/sensors somewhere in the engine bay will throw a CEL or not.
Old 11-08-2007, 06:47 PM   #4
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Oh I thought you meant just the motors and sensors themselves.
Old 11-08-2007, 06:56 PM   #5
KevlarSTi
Member#: 134036
2007 STi Limited
Satin White Pearl
Oh, sorry, no, I misunderstood you, haha. You mean ziptie the entire TGV units somewhere in the engine bay? I'd rather not do that.. I'm not sure there's really anywhere good to put them, as those areas are pretty cramped, and moving them far from their original locations would require extending the wires, etc, which I'd rather not do if not necessary. I -do- mean zip-tying the motor/sensor unit somewhere near the original location (the motor/sensor is one unit).
Old 11-08-2007, 09:03 PM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
if you remove the sensors or motors from the stock location
you will get cel..
Old 11-08-2007, 09:32 PM   #7
KevlarSTi
Member#: 134036
2007 STi Limited
Satin White Pearl
Where'd you hear that from? Remember, the motor = sensors, it's an 07.
Old 11-08-2007, 10:10 PM   #8
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Kevlar I second Jax's answer. My tuner will be deleting the CEL and once you do the deletes the ECU will go into a engine saving mode (forget the real name) it basically will limit your RPMs to like 4500 and cut your boost and open the WG duty so that it dumps all boost. So the answer is you will throw more than the cell you'll need a tune.
4ST-AIR is offline   Reply With Quote
Old 11-08-2007, 10:35 PM   #9
KevlarSTi
Member#: 134036
2007 STi Limited
Satin White Pearl
Damn, that bad? That sucks...
Old 11-08-2007, 10:41 PM   #10
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Limp mode.
Old 11-08-2007, 10:43 PM   #11
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Thats not bad just call and make an appointment for a tune the day after you do the deletes. I wouldn't drive it but to the tune after doing the deletes.
Old 11-08-2007, 10:44 PM   #12
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Limp mode.
I have heard it called that many times but is that really the official term?
Old 11-08-2007, 10:49 PM   #13
Freon
Member#: 88322
2009 BMW 135i
It's a lot more complicated than "limp mode." There is an array of fail safes, even if different failure conditions (like, coolant temperature sensor failure vs MAF sensor failure) can trigger some of the same fail safes. There is some overlap and some unique fail safes for given failures.
Disabling ignition advance is common. You can read the Subaru manuals. They have very detailed information.
Freon is offline   Reply With Quote
Old 11-08-2007, 11:02 PM   #14
KevlarSTi
Member#: 134036
2007 STi Limited
Satin White Pearl
Yeah, well, the problem is, I live in NC, and I'm getting it tuned in GA (at TopSpeed). That's a 6 hour drive...
So is there anything I can do so it -doesn't- go into limp mode?
Would somehow leaving my stock TGV units connected off to the side actually work? (As un-ideal as that is).
Old 11-08-2007, 11:10 PM   #15
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
I dont see why it wouldnt.
Old 11-09-2007, 12:22 AM   #16
STIBungy
Member#: 51684
No it wouldnt work because the sensors are suppose to stop at a certain point (when the butterflies close or open). Setting them to the side leaves it no stopping point whether opened or closed.
TGV deletes arent worth it, IMO. If I could do it all over again, I wouldn't have wasted my time or money on it. The only reason I did it was I got a kickass deal on a deleted set, was going to install some Hondata tgv gasket spacers and install an APS turbo inlet.
I'm not sure if there are additional TGV CELs for the 07 but my 04 tripped off 4 codes when I removed the motors and sensors: P1086, P1088, P1094, P1096.
STIBungy is offline   Reply With Quote
Old 11-09-2007, 01:23 AM   #17
KevlarSTi
Member#: 134036
2007 STi Limited
Satin White Pearl
I mean setting my entire stock TGVs to the side (the actual TGV units, with the motor/sensors attached).
The reason I'm doing TGV deletes is I'm also installing an APS turbo inlet and Grimmspeed phenolic spacers, so I have to pull the intake manifold anyway. I figure I can sell my stock TGVs for what I got the replacements for, so it's essentially a free mod (minus my own labor).
Thanks to everyone for the help.
Old 11-09-2007, 01:25 AM   #18
STIBungy
Member#: 51684
Once the car is at operating temp, you can stop and restart it and it will take it out of limp mode.
Old 11-09-2007, 01:59 AM   #19
SplatZ400
Member#: 84377
2011 335d
pm sent.
SplatZ400 is offline   Reply With Quote
Old 11-29-2007, 02:00 PM   #20
johnsm
Member#: 95868
07 STI LTD#225
can you pm this also im doing same thing!
johnsm is offline   Reply With Quote
Old 11-29-2007, 04:35 PM   #21
KevlarSTi
Member#: 134036
2007 STi Limited
Satin White Pearl
He sent me a PM asking about buying my original TGV's after I swap them out and port/delete them as well. I'll post my results once I actually try something...
Old 11-29-2007, 04:48 PM   #22
SplatZ400
Member#: 84377
2011 335d
yep. so kevlar any updates for me?
Old 11-29-2007, 05:21 PM   #23
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
open ecu flash just eliminating the codes also works. I have done it an 02 wrx with a utec and an 07 sti that is using open ECU.
nosmo is offline   Reply With Quote
Old 11-30-2007, 01:21 AM   #24
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
agreed, dont worry about leaving the sensor/motor in the engine bay, just turn the cel off.
another question though, when you disable the trouble code via enginuity is it just turning off the light or is it making the ecu think that things are fine and dandy? does this really put the car into limp mode cause my car has run quite well with a tgv delete and disabling the code in enginuity.
TROLL is offline   Reply With Quote
Old 11-30-2007, 02:01 AM   #25
KevlarSTi
Member#: 134036
2007 STi Limited
Satin White Pearl
Yeah, but the problem with that is, I have a Cobb AP, and when I asked Cobb about this, they said that if I used Enginuity to remove the codes, it would 'unmarry' the AP, effectively, making me unable to reflash with the AP at all.
Splat: The TGV's I deleted/ported are ready to go in, I'm just waiting for a few more parts to arrive so I can do a big install at once. Then I'll port my stockers and shoot you a PM.
fs: aps tgv deletes with 04 sti tgv motors boostinwrx Engine/Power/Exhaust 2 12-03-2009 08:56 AM
WTB: Top Feed TGV Deletes for 07 Sti I_RIDE_RIMZ Private 'Wanted' Classifieds 0 04-25-2009 12:16 AM
TGV Deletes on Stock Motor handyRS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 08-08-2008 02:37 AM
TGV deletes on a rotated set up? raginbull74 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 12-20-2005 06:24 PM
TGV deletes on a XT? Anyone? Anyone?....................Bueller? Hondaslayer Forester Forum 3 03-07-2005 08:56 PM
