Old 11-08-2007, 06:38 PM   #1
act6464
Member#: 141709
2003 WRX Wagon
Question "Rolling the fenders" - What does it mean?
About to upgrade to larger wheels and tires. I keep hearing the term "rolling the fenders" on this site as well as other. What does it mean???
act6464 is offline   Reply With Quote
Old 11-08-2007, 07:10 PM   #2
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
It refers to using a device that bolts to the hub in place of the wheel that rolls along the inside of the fender lip and pushes it out to gain clearance for bigger/wider wheel and tires. This can also be accomplished by the much cruder method of using a baseball bat or pipe and doing the same thing using the tire as a fulcrum-NOT advised. If the combo you are looking into requires this be prepared to lose some performance from rolling resistance and weight,just my 2 cents.
Old 11-08-2007, 08:04 PM   #3
mattwalters
Member#: 422
1998 Legacy 2.5GT
Rio Red
Assumption is the mother of..?
I had to roll my fenders to make room for about 1" of drop and aftermarket lateral links with stock wheels. Lots of things can push the wheels out.
-Matt
mattwalters is offline   Reply With Quote
Old 11-09-2007, 02:49 AM   #4
gharari
Member#: 66695
2006 STI
Obsidian Black Pearl
I've always been curious as to what material is compressed/deformed/bent when you roll the fenders. Does it push the painted surface out or just the inner part of the fenders? How much clearance can this provide?
gharari is offline   Reply With Quote
Old 11-09-2007, 11:13 AM   #5
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
.....a quick Google search using the term "fender rolling" reveals quite a bit on the subject:
http://www.mazda6tech.com/index.php?...id=17&Itemid=1
http://forums.audiworld.com/s4/msgs/1745791.phtml
Kean is offline   Reply With Quote
Old 11-10-2007, 01:15 AM   #6
gharari
Member#: 66695
2006 STI
I was always looking for subaru specific info, and never found these. I guess a fender is a fender. Thanks for the links, but what is this thing you call "Google"?
Old 11-10-2007, 04:29 AM   #7
Kean
Member#: 25187
'08 Foz Prem TGM
......is this a weak attempt at being sarcastic?
easiest way is to go to google and put in "300 lbs/in in kg/mm" or vice versa. It will convert for you.
Old 11-10-2007, 06:55 PM   #8
gharari
Member#: 66695
2006 STI
You've busted me. I do know about google.
Old 11-10-2007, 08:32 PM   #9
act6464
Member#: 141709
2003 WRX Wagon
So what's the best method for rolling the fenders? Take it to a shop?
Old 11-10-2007, 08:56 PM   #10
Kean
Member#: 25187
'08 Foz Prem TGM
.....I guess I just didn't get the joke.
Old 11-12-2007, 12:15 PM   #11
gharari
Member#: 66695
2006 STI
no prob. Maybe you just need to unplug for a while. You know, get some R+R? Follow the white rabbit.
what does it mean when the turbo makes this sound? Antonios Kintos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-19-2005 05:37 AM
Question: What does it mean when a doctors title has D.O. at the end? crowbar Off-Topic 14 11-16-2004 06:32 AM
Hooked up with a girl over the weekend. What does it mean? Mud Pig Off-Topic 46 04-26-2004 03:35 PM
STi with 6 speed tranny... what does it mean for the WRX warranty? Porter Warranty Issues & SOA Problems 12 01-09-2003 11:12 AM
what does it mean when an Ex contacts you over the holidays? ColinL Off-Topic 45 12-31-2002 12:15 AM
