Old 11-09-2007, 12:04 AM   #1
ulei eagle
Member#: 108017
'97 Legacy Wagon
Red 2.2L w/AT
Default Leaking Gas Filler Neck?
Greetings!
The little lady's '97 Brighton [station wagon] seems to have developed a gas leak...As far as I can tell, it appears to be in the filler neck itself, not the tank or any gas lines....Is the filler neck something that can be replaced?..And if so, can it be replaced without replacing/removing the tank?.... Or if not [& I can find the leak in the filler neck], is there any way of patching/sealing the leak?
ulei eagle is offline   Reply With Quote
Old 11-10-2007, 08:21 AM   #2
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
I would think that you could solder the filler neck (after removing it from the vehicle) or you could maybe get away with some "JB Weld" or maybe some sort of gas resistant two-part epoxy goo... assuming the filler neck itself is the culprit. It is perhaps more likely to be the line to the evarporative emmisions charcol canister ?
First run the car as low on gas as you dare... remove the tank, then the filler neck.
Jonathan is offline   Reply With Quote
Old 11-10-2007, 08:26 AM   #3
Aczwild
Member#: 71721
'98 RS (Race Car)
'13 GMC Sierra (Tow Rig)
Yes you can replace the filler neck, I had the same problem with my old '97 GT, I think it was about $150 for a shop to replace it. Its a better idea to replace it that cobb-job it
Aczwild is offline   Reply With Quote
gas filler neck vent plugged imperium Service & Maintenance 6 01-25-2010 02:16 PM
HD RSB mount install help. gas filler neck, charcoal canister, argh!! doubledribble Brakes, Steering & Suspension 16 05-15-2007 03:26 PM
FS: 2.5RS Gas tank with filler neck! perfect for smaller L tanks! scobaru MWSOC Private Classifieds 3 01-21-2007 07:56 PM
2006 Impreza gas tank fill - fuel tank filler neck problems. Psybin Warranty Issues & SOA Problems 11 01-08-2007 09:48 PM
fuel filler neck leaking yUraBuS Normally Aspirated Powertrain 3 11-30-2006 11:28 AM
