11-09-2007, 07:50 AM | #1 |
Member#: 130012
Vehicle:04 wrx w/sti block silver |
car randomly shuts off with the clutch depressed
ok
here's a for instance i'll be backing up in my drive way, cut the wheel, push the clutch in, and the car just shuts off...NOT stalls, just shuts off i'll be pulling up to a light, push the clutch in, and the idle yo-yo's for about 5 seconds, that happens all the time...and sometimes if i'm really lucky, it'll just shut off does anyone know what can cause this? is it the starter? it seems to mainly happen when power steering is involved.... i've got no clue what it could be please help thanks ~Brendan
11-09-2007, 11:28 AM | #2 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
fill in yer damned profile so we AT LEAST KNOW WHAT THE HELL KIND OF CAR YA GOT
...and if ya have a 'BOV'(bet so)....it may be leaking and stalling yer rig |
11-09-2007, 11:39 AM | #3 | |
Member#: 130012
it's an 04 wrx with an STi short block and wrx heads, i'll check the BOV when i get home but the thing seems to idle fine usually... i've got a .9 bar spring in the tial bov is there anything else i should look for that would be a sure fire sign that this is the problem? it never gives me any trouble when i've got a load on the thing, just when i'm coasting with the foot on the clutch |
11-09-2007, 09:06 PM | #4 |
Member#: 157445
Vehicle:05 Honda Civic Black |
not the starter, the starter has only one purpose and it's to start the car, after the car is started no power goes to that thing. it's nothing in the starting/charging system. anyway, more details on the problem would be helpful....like does it happen only when you're coming to a stop? does it happen when you're stopped? does it try to cut out when you're traveling above 10? etc etc etc
11-09-2007, 09:27 PM | #5 |
Member#: 130012
it's only happened traveling above 10mph 1 time, and that was on an off ramp (clover leaf), it's usually when i'm rolling up to a stop sign, traffic, etc...like if i've had a minor load on it, and then coast
but it's never happened if i put the car into neutral, just when it's in gear and the foot is on the clutch, i know that really hos nothing to do with it, but i just find it weird |
11-10-2007, 08:30 PM | #6 |
Member#: 68902
Vehicle:2011 WRX - WRBM 1988 Fiero GT - black |
I've heard of this problem being caused by the BOV as well. It's usually listed as one of the main reasons to not run an atmospheric BOV, just a recirc one.
But if you are sure that it isn't the BOV, I'd check your fuel delivery. I.E. fuel pump and fuel filter. If malfunctioning or clogged, the engine is getting starved at lower rpms. I'd take it in. |
11-10-2007, 10:36 PM | #7 |
Member#: 60142
Vehicle:2011 WRX Grey |
Dying out with throttle drop or at low idle can also be caused by a vacuum leak, as well as by poor tuning of larger injectors.
need help! car randomly shuts off! | anthonyfur | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 11-05-2008 09:29 AM |
So my car decides to just randomly shut off while driving today | stryfewrx | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 19 | 05-30-2006 12:37 AM |
Help: Random CEL and Random Shut Off | FatStraws | Texas Impreza Club Forum -- TXIC | 38 | 07-22-2005 07:17 PM |
car is shutting off randomly | 03 Black R3x | Electrical & Lighting | 11 | 11-22-2004 09:52 PM |
Holding MT cars on an incline with the clutch? | balajc | Newbies & FAQs | 11 | 02-17-2003 01:11 AM |
