Welcome to the North American Subaru Impreza Owners Club Friday July 11, 2014
Old 11-09-2007, 08:56 AM   #1
Sausage
Member#: 104998
2007 vf39 SuperWagon
I haz teh bed gramers
Smile DIY SSAC FMIC Shroud & grill
Yup... another one of these writeups... ever since I learned about the magic of fiberglass I can't stop.
Anyways,
Here's what we're making:
This one is easy, all you need is:
1 can of truck bed liner
Some fiberglass matte OR thicker flat plastic sheet
Resin
2 90 degree brackets
Masonry mesh from home depot
couple of bolts.
2" strait bracket
Prep: I noticed that a lot of people have some rough dremel spots after cutting their front bumper. To smooth those out, get a sanding block and some 60 grit paper. Hold the block perpendicular to the cut edge and go to town in long smooth arcs for about a half hour or as long as it takes. After you're done, you should have a smooth lower cut. (not necessary but looks nice)
1.) Get some cardboard and make some mock side plates. Meaning, just do some trial and error with the cardboard until you have the sides lines up nicely. Both sides aren't going to be identical unless you bolted the fmic in place with laser guided precision.
2.) If you're using matte and resin, put down a piece of aluminum foil on a flat surface and make a flat large square that you can cut the side pieces from. use 2 layers of matte to make it nice and hard.
3.) Cut the side flaps from either plastic4.) or your fiberglass piece.
4.) cut a large chunk of mesh from the masonry mesh. It should fit inside the hole in the bumper but should be taller then the hose by about 6"
5.) Then, make a 90 degree bend in the netting about 1.5" off the bottom kind like this:
You will use this bend to bolt it to the bumper that way it sits flush with the cuts in the bumper.
6.) Take the 2" strait bracket and bent 2 90 degree bends it it. This will hold the mesh to the top of the bumper, Like
7.) Next, bolt on the side pieces to the flaps in the bumper using the 90 degree brackets.
8.) Once everything is set and looks good, you will flip the bumper in it's face and apply small amount of resin to the places where the mesh overlaps the back of the sides. Like in the pic above. Do a little bit at at time because it will run. If it runs off the edge, use a tooth pick to get it off. Try to clean it as best as you can while it's still semi soft. Before it gets really hard, it gets jelly like and crubles off, this would be the best time to get the last little pieces.
9. Once everything is set, take it off and spray it down generously with truck bed liner. Make sure you cover all the metal.
10. Bolt it up and seal off any small crack from the back with what ever black goo you want. I used window ribbon, the stuff that seals your windows or the front headlights.
And that's it, easy as pie
Sausage is offline   Reply With Quote
Old 11-09-2007, 09:52 AM   #2
Rene2.5RS
Member#: 4574
2011 Outback 2.5i L
VRP
Nice write up. Looks great.
-Rene
Rene2.5RS is offline   Reply With Quote
Old 11-09-2007, 11:19 AM   #3
chewbakarox
Member#: 25478
2003 WRX Sport Wagon
Looking good. DIY FTW.
chewbakarox is offline   Reply With Quote
Old 11-09-2007, 12:44 PM   #4
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
i thought about doing something simialr with metal. looks good. i kind of like the way mine looks though. not so much open area on the 04 w. the ssac
vtecTHIS is offline   Reply With Quote
Old 11-09-2007, 02:04 PM   #5
chris-man
Member#: 90572
2013 WRX STI
07 ninja ZX6R
looks good
chris-man is offline   Reply With Quote
Old 11-20-2007, 10:12 AM   #6
Rene2.5RS
Member#: 4574
2011 Outback 2.5i L
VRP
Did some thing similar. Thanks for the write up.
-Rene
Old 11-20-2007, 10:46 PM   #7
demartinoink
Member#: 164494
looks good!
demartinoink is offline   Reply With Quote
Old 11-21-2007, 10:01 AM   #8
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
The only issue I've had is that screening will eventually tarnish or rust & look like crap. I'd shoot some epoxy enamel (I like the Russel's Chassis Epoxy) on it before mounting.
-Keith-
CTKAG is offline   Reply With Quote
Old 11-21-2007, 10:08 AM   #9
Rene2.5RS
Member#: 4574
2011 Outback 2.5i L
VRP
-Keith-
I coated mine in rubberized under coating for that reason and to better withstand getting hit from road debris .
I believe the OP stated to used the undercoating in his write up.
-Rene
Old 11-21-2007, 11:10 AM   #10
Sausage
Member#: 104998
Yup, rubberized undercoating FTW.
BTW, nice job on the grille!
Old 02-03-2008, 07:27 PM   #11
awdturbo04
Member#: 39487
2006 sti
obp
awdturbo04 is offline   Reply With Quote
Old 02-03-2008, 10:44 PM   #12
Julianh06
Member#: 167660
2006 STi
looks good
Julianh06 is offline   Reply With Quote
Old 02-04-2008, 12:27 AM   #13
Rene2.5RS
Member#: 4574
2011 Outback 2.5i L
VRP
Came out looking good. Nice work.
-Rene
Old 03-17-2008, 07:13 AM   #14
pawlooo
Member#: 123959
08 LGT
bump for a great idea
pawlooo is offline   Reply With Quote
Old 06-27-2009, 05:58 PM   #15
Ashr
Member#: 210984
2009 WRX 265
Is their a write up to removing the front nose to get to the grill? I need to replace mine but have no idea how to get it started!!
Ashr is offline   Reply With Quote
Old 06-27-2009, 07:33 PM   #16
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
Originally Posted by awdturbo04 View Post
IMO you should move the shrouds a little farther to the sides. Show a little more end tank. Right now it looks like an a/c condensor.
cpunlamd is offline   Reply With Quote
Old 04-13-2012, 04:11 PM   #17
Rally Snow
Member#: 193614
02 Aspen WRX
need blinker fluid change
I'm working on this right now on my bug eye thanks for the ideas!
Rally Snow is offline   Reply With Quote
Possible FT: UGM wagon bumper w/lip & fmic shroud for stock Bad Noodle Tri-State Area Private Classifieds 15 06-08-2009 08:16 PM
Swift Sport Springs & SSAC FMIC sub-e90 NWIC Private Classifieds 24 05-17-2009 07:48 PM
wtb: elbow & stock bpv flange 4 ssac fmic mxpunk409 Private 'Wanted' Classifieds 2 11-30-2008 11:33 AM
FT:My SSAC FMIC for your STi TMIC and Shroud/air splitter vividwrx13 SWIC Private Classifieds 10 08-18-2008 11:53 PM
DIY CAI for SSAC FMIC Psipwrd Factory 2.0L Turbo Powertrain 13 04-14-2007 08:13 PM
