Old 11-09-2007, 11:00 AM   #1
KoalaSlim
Member#: 94002
Default Will 16" 2004-2005 WRX wheels clear 2006 four pots?
I'm thinking about going to a smaller rim and these rims are pretty cheap. advice? I searched!
KoalaSlim is offline   Reply With Quote
Old 11-09-2007, 11:23 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
no...not without spacers
tire rack sells 16's and 15's that clear....some cheap...some not
research tire rack
Old 11-09-2007, 11:26 AM   #3
KoalaSlim
Member#: 94002
yeah i figured... I just found a set of painted stockers that would have been a good cheap option. Thanks!
Old 11-12-2007, 07:29 PM   #4
Scowboy
Member#: 149474
06 WRX
CGM
I am currently in this boat as well. Do you know why they won't? From what I can tell the offset is in proportion to the width loss. I hate having rubber bands for tyres and plan on going with steel 16" rims. If factory WRX wheels won't work, does anyone know what factory steels in 16 would?
Scowboy is offline   Reply With Quote
Old 11-12-2007, 08:12 PM   #5
REX8
Member#: 24038
Yep, offset related in conjunction with the wider caliper, not a "height" issue.
OEM alternatives: 98-01 Impreza RS wheels will fit.
A 3mm spacer and OEM 16" WRX wheels will work <--- cheapest alternative
I don't think OEM steelies work, but again, the 15" alloys off of tire rack are a pretty cheap option....and the cost of tires goes down with 15's as well...
Will 09 wrx wheels clear 4 pots on 07wrx? ricepapertiger Tire & Wheel 2 10-16-2009 08:44 PM
Will 02 WRX Wheels clear 4 pots? Local_Skater Tire & Wheel 6 12-25-2008 12:18 AM
Will these wheels clear the 4 pots DanThom Tire & Wheel 6 11-01-2005 09:43 PM
NJ: FS 16" OEM 2005 WRX wheels n tires wrxwhip Tire & Wheel 1 04-29-2005 02:57 PM
Will stock 16" WRX wheel clear rear R180 Brembos? fragment Brakes, Steering & Suspension 1 12-15-2004 07:55 PM
