Old 11-09-2007, 11:08 AM   #1
Haelan
Member#: 151045
2013 Subaru STI
CBP
Default Bad Timing Belt Tensioner
I've noticed some ticking / knocking sound coming from my engine bay on cold start. Never noticed it before, but it has gotten much cooler outside near Chicago. The sound disappears after a few minutes when the engine temperature normalizes.
I'm almost positive it is the timing belt tensioner.
Question #1: how hard is this to replace myself? I haven't dug around in that area of the engine or removed the timing belt covers yet.
Question #2: What's the cost on the tensioner?
I welcome any help.
Haelan is offline   Reply With Quote
Old 11-09-2007, 02:14 PM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
how do you know it's not piston slap?
much more likely to go away with operating temp than a t-belt tensioner.
Old 11-09-2007, 02:26 PM   #3
Haelan
Member#: 151045
2013 Subaru STI
CBP
I thought of that, but is that common on a 2004 with < 35k miles? Oil levels have been OK as far as I've owned it. Only noticed the problem since it's gotten colder.
I'm going to see if I can pinpoint the source of the noise after work.
Old 11-09-2007, 03:21 PM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it's common on a subie boxer engine when it gets cold out.
Old 11-09-2007, 03:31 PM   #5
Haelan
Member#: 151045
2013 Subaru STI
CBP
I must've read about 60 posts on the cold piston slap issue in the last couple days--it definitely does sound common, but I didn't see much info about the later models (2004+).
I guess deep down I'm hoping it's the tensioner so I can make the noise go away . At about 2k RPM during cold idle I hear the noise maybe 2-3 times a second. Piston slap would be a bit faster than that, no?
Either way, I'll post my results this weekend if I can pinpoint the source of the noise. Thanks for the input.
Old 11-10-2007, 08:32 AM   #6
dinosmash
Member#: 143598
05 lgt
Default dont worry
just let your car get to operating temp in the morning.stay off boost for for first few mins of driving.youll be fine.mine does it when its cold too.i would worry if it doesnt go away when warmed up.btw my car did this all last year and runs 12 sec quarter mile.im right at 40+ k
dinosmash is offline   Reply With Quote
Old 11-10-2007, 09:04 AM   #7
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
You can test this without taking everything apart. Just remove the radiator and the accessory belts. Take off the left and right timing covers but do not touch the center cover. Start the car for 20 seconds or so and see if the belt is thrashing around. It will be very obvious if you have an issue. Just dont run the car to long because you will have no cooling system and no coolant going through your turbo. Trust me, it will be fine for 20 seconds or so. I do this often while looking for timing issues.
dexterous is offline   Reply With Quote
Old 11-10-2007, 09:22 PM   #8
djoye
Member#: 50072
2003 WRX
[email protected] 20psi
My AC compressor would make a scratchy noise for a little bit while the car was cool and once I got driving around and the car warmed up the noise would go away. I figured out it was the AC by cutting the AC belt. I know it's not the tensioner. Damn that compressor is expensive.
djoye is offline   Reply With Quote
Old 11-10-2007, 11:14 PM   #9
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
i say piston slap
ozzy370 is offline   Reply With Quote
can i Subaru tech tell if a timing belt tensioner is bad by looking at it? BlackoutWRX Newbies & FAQs 9 10-18-2012 10:09 PM
new short block, bad timing belt tensioner????? Vinnyzwrx Built Motor Discussion 12 05-26-2010 08:38 AM
FS:Brand New OEM Timing Belt Tensioner & Timing Belt jsnm Engine/Power/Exhaust 5 04-06-2010 12:58 PM
bad timing belt tensioner? double07 Service & Maintenance 12 03-30-2008 01:59 AM
Driving with a bad timing belt tensioner BlackoutWRX General Community 7 06-07-2005 10:27 AM
