Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC > MWSOC Vendor Classifieds
Closed Thread
Old 11-09-2007, 03:51 PM   #1
AMS
Vendor Sales Rating: (4)
Member#: 27854
STI, WRX, GTR, EVO,
BMW, Porsche, + More!
Thumbs up AMS WRX/STi Timing Belt and Water Pump Special
For the holiday season we are offering a WRX/STi Timing Belt and Water Pump Special.
call AMS for pricing
Includes: ALL OEM Subaru parts.
- OEM Timing Belt
- OEM Tensioner
- OEM Water Pump
- Coolant & Labor
Water pump replacement is recommenced but not required. If you do not wish to replace the water pump the Special Price is $569.99
Subaru recommends replacing the timing belt every 105k miles under normal driving conditions in an unmodified vehicle. For modified vehicles and "spirited" driving styles this should be done more frequently.
Oil Change Special - $19.95 plus fluids.
Call today and schedule your appointment.
Thanks,
Darius
AMS is offline
Old 11-09-2007, 07:37 PM   #2
GDB-E-06
Member Sales Rating: (7)
Member#: 139721
Free Speach
Mother****ers
Subaru recommends replacing the timming belt every 105K under normal driving conditions. You guys would know that if you looked at your owners manual.
GDB-E-06 is offline
Old 11-09-2007, 09:09 PM   #3
dan13
Member Sales Rating: (2)
Member#: 157726
hunk of metal
Says 60k in my manual high speed.
dan13 is offline
Old 11-09-2007, 09:25 PM   #4
GDB-E-06
Member#: 139721
Free Speach
Mother****ers
I said under normal driving conditions.
GDB-E-06 is offline
Old 11-12-2007, 09:13 PM   #5
downshift1
Member Sales Rating: (21)
Member#: 15607
I'm not the type
to make angry
105k is the recommended service timing belt replacement on all 02' and up vehicles except 3.0l cars. If the car is used aggressively it should be replaced at 90k.
downshift1 is offline
Old 11-13-2007, 12:04 AM   #6
NITROS
Member Sales Rating: (26)
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
ARGH... I'd hate to say this but seriously how can you guys post that and not expect to get crap from members. Its bad information.
Tensioner can be reused as long as the cylinder is not leaking fluid. It must be compressed slowly(hours) and under xx lbs of compression force.
I also dont see why you would need a water pump at 60k its a metal impelar not a plastic one.
NITROS is offline
Old 11-13-2007, 01:53 AM   #7
AMS Eric #2
Member#: 85702
2006 Scion xB
I think Darius made the mistake of copying the technical info from our post on EvoM. I'll inform him of his slip-up.
AMS Eric #2 is offline
Old 11-13-2007, 10:35 AM   #8
AMS
Member#: 27854
STI, WRX, GTR, EVO,
That is correct. Sorry about that guys and thanks for catching that mistake. I just fixed it to 105k. The manual does say at 105k it should be replaced but it also does say to inspect or replace at 30/60/90k.
Even though it does say 105k, I would still recommend doing it before or at a very least having it checked for a piece of mind (like the manual says at 30/60/90k). Especially if your vehicle is even slightly modified.
Regards,
Darius
AMS is offline
Old 11-17-2007, 10:39 AM   #9
GDB-E-06
Member#: 139721
Free Speach
Mother****ers
Maybe you guys should just stick to Evo's.
GDB-E-06 is offline
Old 11-17-2007, 07:55 PM   #10
8Complex
Member Sales Rating: (4)
Member#: 922
16 WRX (white)
04 FXT (red)
You can recompress the tensioner over a couple of minutes, just have to do it very slowly. You're correct that there is a specific pressure you're only supposed to use to recompress it, mainly so that it doesn't overpressurize and blow out the seals.
The water pumps need to be replaced due to seals and bearings, not for the turbines specifically.
8Complex is offline
Old 11-18-2007, 02:33 AM   #11
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Don't be too afraid of the tensioner. You're supposed to compress it during the course of "more than three minutes" and use no more than 2,205 pounds of pressure.
Tim Sanderson is offline
Closed Thread
2004 STi - Timing belt and water pump set mizoo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-26-2008 06:34 AM
AMS WRX/STi Timing Belt and Water Pump Special AMS Services 2 11-13-2007 10:41 AM
Eip halloween timing belt & water pump special!! eipracing Engine/Power/Exhaust 0 10-22-2007 03:29 PM
96 impreza 2.2L timing belt and water pump installation guide sjtangb21 Normally Aspirated Powertrain 0 03-25-2005 09:36 PM
Timing Belt And Water Pump CRAZY KEN Service & Maintenance 2 06-11-2002 11:43 AM
