#1 |
Vendor Sales Rating: (4)
Member#: 27854
Vehicle:STI, WRX, GTR, EVO, BMW, Porsche, + More! |
For the holiday season we are offering a WRX/STi Timing Belt and Water Pump Special.
Normally $936 SPECIAL PRICE $$$ Call AMS today Includes: ALL OEM Subaru parts. - OEM Timing Belt - OEM Tensioner - OEM Water Pump - Coolant & Labor Water pump replacement is recommenced but not required. If you do not wish to replace the water pump the Special Price is $569.99 Subaru recommends replacing the timing belt every 105k miles under normal driving conditions in an unmodified vehicle. For modified vehicles and "spirited" driving styles this should be done more frequently. Oil Change Special - $19.95 plus fluids. Call today and schedule your appointment. Thanks, Darius
__________________
[B][I]Ty Curtin[/I][/B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [B]Tel. (847) 709-0530 x2009[/B] [LIST][*] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [*] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [*] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [*] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [*] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [*] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/LIST] Last edited by AMS; 11-30-2007 at 11:09 AM. |
#3 |
Member#: 27854
That is correct. Sorry about that guys and thanks for catching that mistake. I just fixed it to 105k. The manual does say at 105k it should be replaced but it also does say to inspect or replace at 30/60/90k. Even though it does say 105k, I would still recommend doing it before or at a very least having it checked for a piece of mind (like the manual says at 30/60/90k). Especially if your vehicle is even slightly modified. Regards, Darius
__________________
[B][I]Ty Curtin[/I][/B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [B]Tel. (847) 709-0530 x2009[/B] [LIST][*] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [*] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [*] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [*] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [*] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [*] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/LIST] |
| Thread Tools | |
| Display Modes | |
| 2004 STi - Timing belt and water pump set | mizoo | Factory 2.0L Turbo Powertrain | 2 | 07-26-2008 06:34 AM |
| AMS WRX/STi Timing Belt and Water Pump Special | AMS | MWSOC Vendor Classifieds | 10 | 11-18-2007 02:33 AM |
| Eip halloween timing belt & water pump special!! | eipracing | Engine/Power/Exhaust | 0 | 10-22-2007 03:29 PM |
| 96 impreza 2.2L timing belt and water pump installation guide | sjtangb21 | Normally Aspirated Powertrain | 0 | 03-25-2005 09:36 PM |
| Timing Belt And Water Pump | CRAZY KEN | Service & Maintenance | 2 | 06-11-2002 11:43 AM |
