Old 11-09-2007, 10:57 PM   #1
ASpec818
Member#: 37059
03 WRX
World Rally Blue
Default bigger or smaller rims for snow?
which is better, 18", 17", 16"? and why? or does size not matter, only width?
ASpec818 is offline   Reply With Quote
Old 11-09-2007, 11:55 PM   #2
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
There are two dimensions to look at.
One is the diameter of the wheel and the other is the width of the tire.
Let's say you have 17" wheels on the car and can switch to a 16" wheel. This would be good. Why? Because by switching to a smaller diameter wheel, you effectively increase the height of the sidewall of the tire. Remember, you want to maintain the same overall diameter, which is a combination of both the wheel and the tire.
A larger sidewall on the tire means more give or flexibility which means the tire will absorb more energy changes, whether from the road or from the car. This means that the car will handle better in the snow because the tire gives more.
Think of this the other way. When you increase the wheel diameter you effectively decrease the sidewall of the tire to maintain the same overall diameter. A smaller or shorter tire sidewall means more handling ability. But the compromise is that in wet or snowy conditions, the car is more likely to skid or lose traction. It's great for predominantly dry conditions though.
A tire that is less wide means that the contact patch is more condensed and therefore more of the vehicles weight is placed per square inch. This translates into better traction.
A wider tire effectively makes the contact area bigger and thus there is less weight imposed per square inch.
Find yourself some pics of the WRX/STI WRC cars that are running in the snow and you'll see that, although specifically made for these WRC cars, the tires (and wheels) are skinny so that the can get through the snow.
I hope that what I have said makes sense and that if there are any experts out there that sees a need for correction, by all means, point out those areas that need to be clarified and/or corrected.
Old 11-10-2007, 12:31 AM   #3
ASpec818
Member#: 37059
03 WRX
World Rally Blue
nice response... so esentially 225/40/18 would be a bad idea?
Old 11-10-2007, 02:37 AM   #4
dbrunner
Member#: 122171
If it's for your WRX in your profile, stick with the stock 205/55-16 size tire. Big-E explained it perfectly, +1 for that post There are some 15" wheels out there that fit over WRX brakes too if you want an even better wheel/tire combo for snow and gravel roads.
Stay away from 18's and rubber band tires when in snow
dbrunner is offline   Reply With Quote
WTB steelie or smaller alloy for 93 impreza L aprezzal Tri-State Area Private Classifieds 8 09-26-2006 07:11 PM
WTB: OEM rims for snow tires for my my 2.5RS MR2fanatic Tri-State Area Forum 0 12-12-2004 06:03 PM
rims... bigger or smaller... panache Tire & Wheel 12 09-10-2004 02:29 AM
WTB: set of 15" rims for snow tires adam555 New England Impreza Club Forum -- NESIC 3 12-12-2003 04:53 PM
FS Local Only: Subaru OEM 15" Steel Rims for Snows! akuhner Tri-State Area Forum 1 12-06-2001 01:57 PM
