Old 11-10-2007, 12:46 AM   #1
ShawnRS
Member#: 18797
MY06 WRX Wagon
Question Rear wiper arm loose
Hello
On my MY06 Wagon the rear wiper arm is loose. I checked the motor (its tight) but I can't figure out how to pull the cover off cover (on outside) the nut that would bolt the arm to the motor shaft.
So everything in the inside is tight it's the wiper are in the out side that is loose
Can anyone give me a hint?
Hope this makes sence.
Shawnrs
ShawnRS is offline   Reply With Quote
Old 11-10-2007, 08:48 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
From the manual, it looks like the cover is held in place by a nub which sticks out of the sides of the cover
Old 12-24-2008, 03:07 PM   #3
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
Ever get this resolved? Just noticed that my rear wiper stalk is loose too, don't know how to fix it. Would tightening it from the outside work?
eurospek is offline   Reply With Quote
Old 12-25-2008, 03:52 PM   #4
Norseman5
Member#: 152475
2006 WRX Wagon
Dark Silver
Does it rattle?
Norseman5 is offline   Reply With Quote
Old 12-25-2008, 04:22 PM   #5
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
Originally Posted by Norseman5 View Post
Does it rattle?
Nope, just in the off position, it sits a tad lower than usual and you're able to move it back a forth a little, didn't have this much play in it before.
Old 12-25-2008, 04:29 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
pop the cover off and makes sure the nut that holds the arm to the motor is tight.
Old 12-25-2008, 04:39 PM   #7
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
That's what I did yesterday, it was on tight, I made it tighter still. But I think I'll just pop off the arm when it gets warmer and remount it at an angle to account for the bit of slop/play. Because right now, the end of the arm sits slightly lower than the heating element on the hatch glass.
Could it be that I broken something because this month I tried using the rear wiper without realizing it was still frozen to the glass, it didn't move an inch, the motor just worked.
When you go to use the rear wiper now, it works without a problem, covers the same amount of glass area, but when you open and close the rear hatch, the wiper arm drops a bit lower than usual.
wagon rear wiper arm removal Smity Subaru Newbies & FAQs 1 08-24-2009 12:18 PM
Replacement rear wiper arm for 08/09 wagoon? Garandman Service & Maintenance 0 01-09-2009 02:22 PM
Rear wiper stalk kinda loose eurospek Interior & Exterior Modification 0 12-24-2008 01:59 PM
Windshield Wiper Arms ( wipers arm ) FD777 Car Care & Detailing 16 12-21-2007 03:28 PM
Winshield wiper blade snaps off of wiper arm? plunk10 Off-Topic 2 02-13-2007 03:50 PM
