Alaskan Impreza Club
Old 01-22-2002, 03:43 PM   #1
RallyX13
Member#: 1543
2007 Jetta GLI
Yellow
Default GFB Underdrive Pulleys
Hello everyone,
I am getting ready to place an order with GFB (Go Fast Bits) in Australia, and am trying to gauge interest in their Underdrive Pulley Kits for the WRX. They are available in Red, Blue, and Silver anodized finishes, and come with the needed belts. Cost will depend on how many I order (due to shipping), but will be under $200.00
These units are lighter and smaller than stock units, creating less resistance and more horespower for your WRX. If you want more information, let me know and I can post more specs.
Well let me know if you might be interested, and what color, and I will gauge how many I should order. I will not ask for any money in advance, so if you are not serious please do not reply.
Thanks,
Kris
www.akautogear.com
***UPDATE***
1. Kato - Blue (paid)
2. Fig - Blue (paid)
3. RallyX13 - Silver (paid)
4. WRXnFX1974 - Blue (paid)
5. ThunderChief - Blue (paid)
6. aZiator - Silver (paid)
7. CaptWP11 - Blue
8. akfireaxe - Silver (paid)
9. kamehamehax3 - Blue (paid)
10. Farminded - Black (paid)
RallyX13 is offline   Reply With Quote
Old 01-23-2002, 04:11 AM   #2
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
very nice...can u pls post the specs? what kind does ben have?
SQUAD_907 is offline   Reply With Quote
Old 01-23-2002, 06:21 AM   #3
WRXnFX
Alaskan Mafia
Member#: 10398
Ben is going to kill me but he has the Unorthodox Racing pulley. Pulley singular. It only comes with one, the main pulley.
The GFBs have similar Dyno results or better than the Vishnu. They also come in a variety of colors such as Silver, Red, and Blue. The pic shows three pulleys but the kit only comes with two.
Here is a direct quote from GFB:
Average Power Gains that can be expected are up to 7kw for normally aspirated engines and up to 9kw for forced air systems. Coupled with the excellent anodised finish and fit, you'll have a pulley kit that will give you the extra edge you need!
How do they do this?
GFB's pulleys are manufactured on the latest Multi-Axis CNC machines from the highest grade 6061-T6 aluminium billet, making them immensely lighter than their factory steel counterparts. This lower weight yields a large reduction in the rotating inertia of the belt train, allowing the engine to accelerate faster. The effect is similar to fitting a lightened flywheel and is particularly noticeable in the lower RPM range before the turbo spools up. This is because the power required to accelerate a heavy pulley accounts for a much greater proportion of the available power at low RPM. Additional power increases also come from a slight change in the ratios to reduce the driven load of the power-robbing peripheral components (particularly at high RPM), without affecting their performance.
To convert Kw to HP, you multiply Kw x 1.34 and you get HP. Which means, an average gain of 12 HP from the pulleys.
Some side effects of lightweight, underdrive pulleys are dimming lights at idle.
Winslow
WRXnFX is offline   Reply With Quote
Old 01-23-2002, 07:39 AM   #4
WRXnFX
Alaskan Mafia
Member#: 10398
I forgot to post. I'll take a set in blue. Winslow
Old 01-23-2002, 12:36 PM   #5
RallyX13
Member#: 1543
2007 Jetta GLI
Yellow
Thanks for posting the specs Winslow, anyone else, will probably place the order in a day or two?
Kris
Old 01-23-2002, 07:44 PM   #6
RawCode
Member#: 3115
2002 Impreza 2.5RS
I would perfer an N1 pully set! hehe, but I cannot afford it either! lol
RawCode
RawCode is offline   Reply With Quote
Old 01-25-2002, 01:18 AM   #7
RallyX13
Member#: 1543
2007 Jetta GLI
Yellow
Well it turns out that AEM has released a set of Underdrive pulleys too, and they are quite a bit cheaper than the GFB (AEM should be under $100). Not sure if there is any quality difference between the two, but I am sure the AEM units are good.
I will let you know as soon as a distributor can get the AEM pulleys, if anyone is interested in them.
Kris
Old 01-25-2002, 01:37 AM   #8
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
i want the sti pulleys...ohh, they don't make those so i would the aem ones in silver!
Old 01-25-2002, 12:13 PM   #9
akwrxdb
Member#: 14160
2002 WRX Wagon
Platinum Silver Metalic
Default AEM Pulleys
Unless Kris has found out something I have not then the AEM pulley and belts will cost $97 + shipping and produce 12 HP at the wheels.(Four wheel dyno testing)
I spoke to them directly yesterday (1/24/2002) and confirmed this but it is only one pulley, where the GFB Pulley kit I think replaces two. I do not know what the draw backs are to only replacing one, but the guy from AEM said that they will be adding at least one more pulley to their kit in the near future. He also said that if we wanted to replace them now he would go with the kit from GFB, if it replaces at least two of the pulleys. He said that should produce better results.
DB
akwrxdb is offline   Reply With Quote
Old 01-25-2002, 12:23 PM   #10
RallyX13
Member#: 1543
2007 Jetta GLI
Yellow
Well that would probably explain the cost difference between the AEM and the GFB.
David, thanks for doing the research on that, I appreciate it. I saw a picture of the AEM kit, and it had two pulleys, so I assumed. But you know what happens when you assume....
Well I am going to do some more research and see what price we can get the AEM's for, if anyone wants the single pulley. Our one AEM supplier has it listed as TBA (To Be Announced), but we will let you know when we find out.
Kris
Old 01-25-2002, 06:36 PM   #11
WRXnFX
Alaskan Mafia
Member#: 10398
Here is the deal on the AEM pulleys or pulley. Usually, AEM produces the Tru-Power Pulley set to include the power steering and alternator pulleys. The WRX on the other hand has a pressed on power steering pulley which would be difficult or impossible to replace. The only pulley that AEM is offering in their Tru-Power Pulley set is the alternator pulley. By the way, this pulley hasn't been designed as an underdrive pulley. It is actually larger than the stock pulley. The only advantage to this pulley is that it is lightweight which decreases its rotational mass. The performance increase will be negligible so don't expect any large gains.
The GFBs do replace two but I'm unsure which two. I will find out. I looked under my hood and did a quick inspection but couldn't find anything. I'm sure if I looked harder that I could find out.
As for only replacing one pulley, It really depends on the characteristics of that one pulley. If it is underdrive and lightweight, then you would definitely benefit from the upgrade. Here is an example. We do have a Vishnu Pulley in stock which is made from 7075 aluminum and underdriven by approx 15%. This pulley weighs less than 1/3 the weight of the stock WRX pulley. This Shiv special has proven dyno results of 7-9 wheel hp gains with just the pulley alone.
I think the GFB pulleys will be a much better alternative to the AEM and will give the Vishnu single pulley a run for its money. The GFB set is moderately priced between the AEM and Vishnu plus you get another pulley.
Besides dimming lights, I forgot to mention that another drawback to changing your pulleys is squealing belts when cold.
Like I said, "I'll take a set of GFB pulleys in blue, please!"
I hope this helps.
Winslow
www.akautogear.com
Old 01-25-2002, 11:00 PM   #12
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
very imformative...now i have changed my mind and will have to go with unorthodox! but that will be later! thanks winslow!
Old 01-25-2002, 11:19 PM   #13
KapaFool
Member#: 2679
2010 WRX4FD
Question
Can I match the AEM with the Vishnu Pulley? I am getting the Vishnu definitely but can I get the other pulleys (GFB or AEM) without compromising the Vishnu setup?
KapaFool is offline   Reply With Quote
Old 01-28-2002, 12:26 AM   #14
WRXnFX
Alaskan Mafia
Member#: 10398
The Unorthodox Racing pulley is similar to the Vishnu, AEM, and GFB. I believe the olny manufacture to make a two pulley set is GFB. AEM and Vishnu only supply the crank pulley.There is no way to mix them because they are the same.
Can you mix GFB pulleys with the Vishnu crank pulley?
It really depends if the pulley is underdrive or lightened. If the GFBs are lightened then I would say, "yes." If they are UD then I would say, "no." We will just have to install them and see. I'm sure you would be able to do it if you got the right size belts.
Winslow
Old 01-29-2002, 03:46 PM   #15
WRXnFX
Alaskan Mafia
Member#: 10398
The GFB pulleys are lightened and underdrive. They replace the crank and alternator pulleys on WRXs. On previous models or in the above GFB pic, the third pulley is the power steering pump pulley. Winslow
Old 02-01-2002, 03:30 AM   #16
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
i'd like to reserve a set in silver....
Old 02-01-2002, 11:26 PM   #17
RallyX13
Member#: 1543
2007 Jetta GLI
Yellow
This is on hold for the moment pending a few things to work out with vendors. I will let you know as soon as I know more.
Kris
Old 04-18-2002, 03:14 PM   #18
WRXnFX
Alaskan Mafia
Member#: 10398
Default Alaskan GFB pulley Group Buy
Ok, we finally worked out the details for these pulleys. If you are interested in these pulleys email me.
Just to correct myself, The AEM Tru-Power pulley only replaces the alternator pulley and the GFB set replaces the crank and alternator pulleys. The GFB pulleys are available in black, blue, silver, and red.
Winslow
Old 04-20-2002, 10:15 AM   #19
WRXnFX
Alaskan Mafia
Member#: 10398
Anyone?
Winslow
Old 04-20-2002, 08:29 PM   #20
aZiator
Member#: 10040
2002 WRX Wagon
Sedona Red Pearl
I would like to get in, I saw a good increase (13) on my 300ZX Twin Turbo when I went to the unorthodox underdrive crank. My only worry is what the dealer might say for warranty work? What have you guys done about this? Is it that big a deal (upgrades on the car when the dealer does work). Thanks
aZiator is offline   Reply With Quote
Old 04-20-2002, 11:42 PM   #21
WRXnFX
Alaskan Mafia
Member#: 10398
I don't think it will be a big deal if you have to take your car in for warranty work. Just remember that any aftermarket product runs the risk of dealer service rejection when it comes to warrant work. I have taken my car in for work and they haven't denied me service. For example, I had to get my alignment corrected and I have a complete exhaust system, intake, BOV and many other aftermarket products. Did those items cause my problem? All I can say is if there is a possibility that the aftermarket product caused a malfunction then of course the dealer is going to look at that item as being the culprit.
Winslow
Old 04-21-2002, 04:15 AM   #22
aZiator
Member#: 10040
2002 WRX Wagon
Sedona Red Pearl
I have just heard horror stories about dealers that tried to attribute mods to the cause of a problem. Like the dealer trying to blame an intake mod on the tranny having problems. Know what I mean?
Old 04-21-2002, 05:10 AM   #23
BlackNight
Member#: 16285
2004 VW .:R32
Tornado Red
Every car company blames Mods for the malfunction of a car . I really hate it.
BlackNight is offline   Reply With Quote
Old 04-21-2002, 05:25 AM   #24
WRXnFX
Alaskan Mafia
Member#: 10398
Yes, I know what you mean. They shouldn't give you a hard time and if you get them in black they won't even notice.
Winslow
Old 04-21-2002, 06:23 PM   #25
aZiator
Member#: 10040
2002 WRX Wagon
Sedona Red Pearl
It says only red blue or silver. Another question I have regards the effects on the engine. I am not to familiar with the WRX engine so bear with me. On my Z the crank pully also has a built in harmonic balancer. We can get away using an underdrive pully because the cranks harmonic balancer will do the job just fine without the one on the pulley. Is that a factor on the subie?? I have had the pulley on my other car for almost 2 years and 50K miles with no problems but I do know of a few engines (very few) that have had some serious problems attributed to the underdrive pulley. Just another thought. I am pretty new to he subaru and since I bought the car 4 days before I left for Korea i didn't have much time to get familiar with it.
GFB underdrive pulleys Whitey 19 Private 'For Sale' Classifieds 21 02-27-2006 11:53 AM
WTS: GFB Underdrive Pulleys Brand New 100.00 (NY) Techie Private 'For Sale' Classifieds 0 07-09-2005 07:08 PM
WTS: Brand New GFB Underdrive Pulleys Techie Private 'For Sale' Classifieds 0 07-09-2005 01:00 AM
GFB Underdrive pulley kit cky211 Private 'Wanted' Classifieds 2 03-13-2004 03:49 PM
FS OH: GFB Underdrive Pulleys SonicWRX Private 'For Sale' Classifieds 2 09-18-2003 08:34 AM
