Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Old 11-10-2007, 11:00 AM   #1
ZeppelinPie792
Member#: 160287
2007 Impreza 2.5i SE
Newport Pearl Blue
Default Switching airbag from A to B - Help!
I would like to get an STi steering wheel for my 2.5i, as I love leather steering wheels. I would also like to pay 50-100$ for one without an airbag instead of 350$ for one with an airbag. I have been told that I can just switch the airbag from my steering wheel to the new one. I can't find anywhere on how to do this, and don't want to screw up anything trying myself.
...Help?
ZeppelinPie792 is offline   Reply With Quote
Old 11-19-2007, 01:56 AM   #2
ZeppelinPie792
Member#: 160287
Newport Pearl Blue
..bump
Old 11-19-2007, 10:36 AM   #3
tludwins539
Member#: 149764
2007 2.5i
You will have to get the full steering wheel with airbag for it to work/look correct. Your airbag will not fit into a STi steering wheel. The only thing you can do is offset the cost of the STi steering wheel and airbag by selling yours.
tludwins539 is offline   Reply With Quote
Old 11-19-2007, 10:56 AM   #4
shemoves
Member#: 80663
2005 STi
Perhaps you could get one off a wrecked car (rear ended or rolled)?
Even if swapping airpbags were possible, that is not something I, an amateur mechanic, would want to perform. Perhaps you are a pro though. As other have said, I do not think it will fit though due to their differing shapes.
shemoves is offline   Reply With Quote
Old 11-19-2007, 02:17 PM   #5
ZeppelinPie792
Member#: 160287
Newport Pearl Blue
That's interesting, I thought an 05+ STi would fit the 05+ impreza airbag. Even the WRX one too, but if you say it is hard, it is not something I will try to attempt in fear of my safety.
Old 11-19-2007, 02:41 PM   #6
WagonR
Member#: 160011
2010 WRX
Satin White Pearl
I added an 07 WRX wheel to my 07 2.5i, and used the 2.5i airbag. There is no difference between the 05-07 2.5i airbag and the 05-07 WRX airbag, and the 05-07 sti airbag is exactly the same, except it has the sti logo, instead of the Subaru stars. So you can use your airbag with a 05-07 WRX wheel, or an 05-07 Sti wheel. I hope that helps.
WagonR is offline   Reply With Quote
Old 11-19-2007, 02:53 PM   #7
WagonR
Member#: 160011
2010 WRX
Satin White Pearl
To answer your original question; there is a write up on scoobymods.com for putting an "impreza wrx steering wheel in forester XT" that has a link to the install, and has a picture that describes how to disconnect the airbag during the swap. It is the older style wheel, and a different car, but the procedure is exactly the same.
Old 11-19-2007, 03:00 PM   #8
ZeppelinPie792
Member#: 160287
Newport Pearl Blue
I saw that, but I wasn't too sure if there was something about switching the airbag out too, like if it had some difficult procedure. Well, I guess I will just have buy off a steering wheel and get a torque wrench and find out!
Old 11-19-2007, 08:41 PM   #9
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
This is not true. The form factor should be the same as all the 05-07 impreza's share the same driverside airbag module. Chances are that the bags are also tuned the same across all the 05-07 imprezas seeing as how the chasis is relatively unchanged. (and by tuned I mean the ballistic performance of the airbag inflator)
This should be and easy switch. Literally unbolt, remove, replace, rebolt. If you do not have one already, buy a service manual for your car off of ebay (on CD or something). If I recall correctly one of the mods on here sells these on ebay.
Old 11-19-2007, 09:03 PM   #10
ZeppelinPie792
Member#: 160287
Newport Pearl Blue
Oh, alright, I thought it would be something more...complicated.
Thanks man a lot.
Swaybars from STi to WRX help shemoves Brakes, Steering & Suspension 6 03-25-2006 02:17 PM
sti slipping from 5th to 6th help bolio Transmission (AT/MT) & Driveline 2 04-15-2005 04:41 PM
Switching back from OLF to CLF bunot Engine Management & Tuning 19 01-10-2005 06:59 PM
Switching back from synthetic to regular oil mibobe Newbies & FAQs 9 07-16-2002 04:52 PM
('93-'01) Smart subie guys...help?switching mods from RS to WRX? Frey Bone Impreza Forum 7 07-25-2001 04:21 AM
