Old 11-10-2007, 10:20 PM   #1
CarterMarkham
Member#: 79085
2011 Subaru WRX Lim
LRP
Question Can someone check my logs?
Here are my logs from my stock 08 LGT 5EAT. I'm mostly confused about the RPM's fluctuating a bit in the 3K and 4K range.
http://cartermarkham.homestead.com/f...110_115028.csv
http://cartermarkham.homestead.com/f...110_115324.csv
CarterMarkham is offline   Reply With Quote
Old 11-10-2007, 11:47 PM   #2
WeldingHank
Member#: 98645
2002 WRX Wagon
what concerns me the most, is how long the car stays in closed-loop. at your peak boost of 14psi and 3000RPMs, your car is still trying to maintain stoich A/F's. is there a reflash for the 08's yet? if there is, atleast clean-up that open/closed loop transition.
WeldingHank is offline   Reply With Quote
Old 11-11-2007, 01:06 AM   #3
MasterKwan
Member#: 98961
2003 WRX
I see what you mean, I think. Looks like 8 seconds from WOT till it starts dropping the AF ratio.
Old 11-11-2007, 10:29 AM   #4
CarterMarkham
Member#: 79085
2011 Subaru WRX Lim
LRP
There is a flash update for 2008 models, BUT only for manual transmissions. Doesnt make sense to me.
Ive been fighting with SOA for months now.
Old 11-11-2007, 10:56 AM   #5
MasterKwan
Member#: 98961
2003 WRX
Hank's talking about an aftermarket flash I believe. That delay is designed in by Subaru.
Old 11-11-2007, 09:31 PM   #6
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
That may be from pinging with the A/F ratio still above 14:1... Try higher octane and ecm reset and see if it smooths out.... Not sure why it's staying in closed loop for so long....
icslowmo is offline   Reply With Quote
Old 11-11-2007, 09:35 PM   #7
WeldingHank
Member#: 98645
2002 WRX Wagon
thats how subaru has tuned it from the factory. to try and get better emissions numbers.
Old 11-11-2007, 09:41 PM   #8
MasterKwan
Member#: 98961
2003 WRX
Yeah. I programmed it out of my 03 WRX. Apparently the newer the car, the worse the delay.
Old 11-12-2007, 08:50 AM   #9
CarterMarkham
Member#: 79085
2011 Subaru WRX Lim
LRP
So you think Subaru decided to suffer reliability to improve emissions? I cant have a hunk of junk I cant use under WOT. As far as I know COBB doesnt have an access port yet, not that I would want to do that. I'm not one to risk denying my warranty. I would perfer a SOA fix right now, atleast until the warranty is up.
Old 11-12-2007, 09:35 AM   #10
MasterKwan
Member#: 98961
2003 WRX
This isn't a new issue. It's been known since 04-05? There won't be a fix from SOA. Pretty sure this change was mandated by the EPA. My guess is that Subaru's willing to eat the cost of motor replacements for the rare people who beat on their cars hard enough to pop the motors.
Old 11-12-2007, 11:29 AM   #11
CarterMarkham
Member#: 79085
2011 Subaru WRX Lim
LRP
I find it very unsettling. I have been in contact with a couple of Subaru dealers and other Used Subaru specific dealers. I have faxed the log to the dealership I usually go to to see what they have to say, and I have an appointment with another dealership Monday. They will have the car all day. I know you say that this is "normal" according to SOA, but in reality its not normal, and its not smart. With my luck the engine will blow at 60,001 miles...
Old 11-12-2007, 12:19 PM   #12
MasterKwan
Member#: 98961
2003 WRX
It's not clear to me what you expect. The dealers can't do anything about it. They can install new flashes from Subaru but, if the federal government mandates this delay before going into open loop do you think Subaru's going to fight with them about it?
If you want to save your motor, don't drive it hard and hope someone comes out with an aftermarket flash that turns off the delay. Either that or sell the car and buy something NA. How often do you need to go wide open throttle anyway? For me, when I'm on the track it's 50%+ of the time. On the street, it's never unless I'm playing around.
I'm sure that's how Subaru looks at it too. 4% of the people who buy the LGT beat on it, the other 96% won't. So, at worst they're looking at replacing some motors on the 4% who beat on the cars. What costs Subaru more, replacing some motors or fixing the issue? I'm sure they've done the math...
Can someone check out these logs. davis10 Open Source Reflashes 12 05-25-2010 10:12 PM
Can someone check this log? ezil71 AccessPort 0 05-08-2010 11:08 AM
Can someone check my learning view please? jexeffectz Open Source Reflashes 2 03-16-2010 12:24 PM
Can someone disect my log? Jaredm83 Commercial ECU Reflashes 20 01-04-2007 11:40 PM
can someone check my coil pack wiring for me? rabbitnutz Subaru Conversions 7 01-24-2006 10:26 PM
