Old 11-10-2007, 11:55 PM   #1
jhull
Member#: 114359
Default To those with Wideband Please help
Just went SD with the utec, now Im on the road to tuning everything. I purchased a innovate LC-1 wideband kit. Im having issues getting it to log but Also questioning the A/F reading it is giving me. AT idle its always sitting around 21 Which I think would be really lean... then with little throttle normal cruising its reading between 12-13 at heavy throttle it drops down to around 9 a couple times as low as 7.4.. I thought running this rich would blow a lot of smoke but there doesnt seem to be any.. So my question is is it possible for this to be reading correctly?
Sensor is mounted on bottom of DP. Unit was calibrated, and has maybe a total of 10hours on it.
jhull is offline   Reply With Quote
Old 11-11-2007, 01:57 AM   #2
hotrod
Member#: 14141
2002 Impreza WRX
It should around 15.1-14.7 or so at idle with the engine warm.
Have you gone through the calibration process on the wide band?
It will show 21 when the engine is off after a period of time, as it will read the O2 level in the air (ie 21%). That is how you calibrate the sensor. Look closely at the display and see if that is what it is actually saying. It will also do that while coasting down in gear as the fuel injectors shut of completely. Under those conditions your AFR is 20 - 22 but the engine is not running. If you are in gear and foot off the throttle and coasting down to a traffic light, that is probably what you are seeing.
Larry
hotrod is offline   Reply With Quote
Old 11-11-2007, 09:39 AM   #3
jhull
Member#: 114359
Larry,
Thanks for the reply, Yes I did calibrate it before use, It reads around 22 while at idle, (car running, not in motion ect.. ) could it really be running that rich without blowing out smoke?
Old 11-11-2007, 10:41 AM   #4
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Originally Posted by jhull
Larry,
Thats lean son, it could be calibrated wrong, you could have exhaust leaks or intake leaks. The car won't run that lean so it is definitely getting a bad reading.
Old 11-11-2007, 05:38 PM   #5
hotrod
Member#: 14141
2002 Impreza WRX
Yes if you have an air leak in front of the sensor (or the sensor is very close to the end of the tail pipe) it can be pulling in excess air and screwing up the reading.
22 is very very lean! (as in melt piston lean if your under any load) Most engines will not even run that lean unless the engine is fully warmed up.
Larry
Old 11-11-2007, 08:50 PM   #6
WeldingHank
Member#: 98645
2002 WRX Wagon
check the calibration in the unit. sometimes they are set to something weird (custom, methanol, ETC) and will give you weird readings like that. Make sure its set to gasoline.
WeldingHank is offline   Reply With Quote
Old 11-11-2007, 09:23 PM   #7
jays05
Member#: 78165
05 STI 35r + e85
Recalibrate...
jays05 is offline   Reply With Quote
Old 11-12-2007, 07:53 PM   #8
jhull
Member#: 114359
Thanks for all the replies, I noticed today its never reading a inbetween I thought I seen it around 13 14 ect.. but now noticing that doesnt really happen. Its always around 22.4 at idel, and at light throttle its down to around 8-9 WOT its 7.4 and starts blinking.. Innovate recommended recalibrating. I will try that tommorow. thanks again for all the replies.
ughh, just moved to socal and now have to deal with smog, please help! Dfish Service & Maintenance 1 07-29-2008 10:11 AM
STi Not Making Advertised 300hp? To those with STi dyno sheets, HELP! Sinister Subaru Proven Power Bragging 42 06-05-2005 12:57 AM
Found problem with tube to factory boost gauge- please help GregH Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-15-2002 09:39 PM
Those who are good with turbos please help me S-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-27-2001 07:20 PM
To those with Hella 500s, please help IMPBOY Technical Forum Archive 11 07-11-2000 10:30 AM
