Old 11-11-2007, 01:28 PM   #1
accelguy
Member#: 107217
2005 2.0 WRX
Question May I have you to look at my logs, please?
I am still very new to the tuning scene. However, I have modified my ROM lately. Would anyone be kind enough to look at my logs and my ROM to see if it is safe for use?
Any comments about my rom and logs are welcome.
EDM WRX 05 2.0 M/T (same hardwares as USDM)
Mod lists
FP TD05H EVO3 16G
STi Intercooler + deflector
STi pink injectors
Walbro 255L fuel pump
GM 3-way boost solenoid
Catless UpPipe
65mm Catless Downpipe
75mm Catless Axleback
Throttle body coolant hose removal
93 gas every time
To download the files, please wait 40 seconds then hit "Click here for download"
www.uploading.com/files/ZIX3IB6O/rev9.hex.html (rom)
http://www.uploading.com/files/RAD2P..._2239.csv.html
http://www.uploading.com/en/files/D2..._2238.csv.html
I would be grateful if you could let me know if they are safe to run on my car.
accelguy is offline   Reply With Quote
Old 11-11-2007, 01:40 PM   #2
accelguy
Member#: 107217
2005 2.0 WRX
deleted
Old 11-11-2007, 10:57 PM   #3
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
no logs or roms on either sites...
icslowmo is offline   Reply With Quote
Old 11-12-2007, 01:15 AM   #4
accelguy
Member#: 107217
2005 2.0 WRX
Dear Icslowmo, I have pm you my logs and rom.
I am sorry for the inconvinence. I've just realised that one needs to log in to view attachments.
If you are interested to check out my my logs and rom to see if the rom is safe to run on my car, simply either download it from the above links or leave a msg to say you want them and I will sent them to you via pm.
Thank you
Old 11-12-2007, 03:00 AM   #5
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
You have too much timing advance at 2K where it looks like you left the stock advance number in and then flattened the map below it. Your KC drops at time mark 578 on one log from 7 down to 5.5 then goes back up. The decrease starts at 2K RPM and wraps up at 2400 RPM which correspond with the high advance value on the map, although it looks like your EL was only about 2.25(1.12) which moves it a few cells over.
Lower the advance value or adjust the base timing map at the 2000RPM row, and it shouldn't pull timing there. Other than that it looks good.
/Brox
Broxma is offline   Reply With Quote
Old 11-12-2007, 03:21 AM   #6
accelguy
Member#: 107217
2005 2.0 WRX
Dear Broxma,
Thank you very much for your generous help and advice. I will change the values accordingly and log some more.
Thanks again.
Old 11-12-2007, 02:13 PM   #7
accelguy
Member#: 107217
2005 2.0 WRX
I tried reducing the Max Ignition Timing Advance by 3 degrees between 2000-2400 RPM at 1.0 -1.1 EL to see if I can fix the drop in KC. However, after 4 reflashes of 3 degrees reduction each time, the drop in KC got worse every time down to KC = 2. Therefore, I increased the Timing advance by 3 degrees from the original value and reduced the KC drop for the above RPM as close as the logs below.
http://www.uploading.com/en/files/T1...35EL_.hex.html
http://www.uploading.com/en/files/26...11216.csv.html
http://www.uploading.com/en/files/U2...11604.csv.html
Do you think having around 18 psi has maxed the efficiency of my turbo on my rex?
How can I get more power from my rom?
Is my AFR on the rich side? How lean should I aim at going for each rpm when I get my LM-1?
Thanks
Please look at my logs rodney757 Open Source Reflashes 2 02-28-2009 08:02 PM
Please help take a look at my logs... spitfirezip100 Engine Management & Tuning 22 04-27-2007 04:12 AM
utec experts please look at my log warpspeedwrx UTEC 10 03-13-2007 06:00 PM
Please Look at my Logs Need BB Engine Management & Tuning 7 01-17-2006 01:59 PM
Went to look at my brothers STi, they have one blue one not spoken for in GR Scooby do Mid West Subaru Owners Club Forum -- MWSOC 0 05-23-2003 03:20 PM
