Old 11-13-2007, 11:32 AM   #1
Gorge
Member#: 97449
2007 WRX
Default 17x7.5 or 17x8 Which one and why?
I'm thinking about getting Rota Boosts, but I can't decide which size. The weight difference is about 2 lbs for the 17x7.5 and 17x8.
I'm trying to weigh out the difference of getting wider wheels vs heavier wheels. Any advice/suggestions?
Gorge is offline   Reply With Quote
Old 11-13-2007, 12:08 PM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Are you going to be running 245's in the near future? That's the only reason I would be getting an 8" wide rim...
rougeben83 is offline   Reply With Quote
Old 11-13-2007, 02:18 PM   #3
Gorge
Member#: 97449
2007 WRX
I think I'd need to roll my fenders for 245s... so not any time soon.
Old 11-13-2007, 03:09 PM   #4
BIGSKYWRX
Member#: 7958
09 GH B+
generally from a performance standpoint the wider the better unless there is a rule set your competing under that limits the width of the rim
a rule of thumb is that .5" of rim width adds an additional .2" of section width for a given tire, it also effectively stiffening the side wall
obviously room is a consideration- the same tire on a narrower rim may not casue any rubbing issues, same tire on a wider rim may (also pay attention to offset diffferences between the two rims if any)
usually the difference in weight is neglible betwen rims of a 1/2" difference (talking the same make style rim here ) so folks usually choose width (but as in most things- not alwyas )
Old 11-14-2007, 01:16 AM   #5
shatteringstar
Member#: 149604
2006 Limited WRX
Originally Posted by Uncle Scotty View Post
take it from me......
If I had it to do again.....17x8 and 245/40 and done.
no doubt
does this still hold true Uncle Scotty?
shatteringstar is offline   Reply With Quote
Old 11-14-2007, 07:48 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
no as in not
Old 11-14-2007, 07:49 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
indubitably
Old 11-14-2007, 10:02 AM   #8
Yoo Shin
Member#: 87327
2010 12 parsec Evo X
I still kill threads
Depending on offset you will not rub with 245/40s on 17x8"s.
Yoo Shin is offline   Reply With Quote
16x8 or 17x7.5 or 17x8 gc835 Tire & Wheel 16 10-23-2010 10:44 AM
2009 Impreza 2.5 - 17x7.5 or 17x8 Wheels opusxxvii Tire & Wheel 9 03-14-2010 05:16 PM
17x7.5 or 17x8.5????? dillsky Tire & Wheel 10 03-22-2008 10:01 PM
WTB: Gramlight 57S 17x7.5 or 17x8.5 Bronze moss Private 'Wanted' Classifieds 0 08-15-2006 01:31 PM
17x7.5 or 17x8, 53mm offset? paulw Brakes, Steering & Suspension 2 03-27-2001 12:00 AM
