Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 11-13-2007, 01:37 PM   #1
jd20jd
Member#: 131768
2004 WRX
Default 5mm spacers..
I have a 18x7.5 EVO 5 Enkei. I was wondering if I can still get away using 5mm spacers with my stock lugs and my stock bolts?
Thx
jd20jd is offline   Reply With Quote
Old 11-13-2007, 05:29 PM   #2
AzN121184
Member#: 40943
2003 subaru wrx
aspen white
u should be fine with 5 mm spacers on stock studs. the lugs will depend on the wheel itself i believe.
AzN121184 is offline   Reply With Quote
Old 11-13-2007, 05:42 PM   #3
remowgn
Member#: 41149
04 09 FXT
SSM
That's not true.... 5mm spacers are pushing it. 3mm or 1/8" spacers are pretty much your only choice if you really want to be safe. Subaru-specific 5mm spacers come with studs.
remowgn is offline   Reply With Quote
Old 11-13-2007, 05:49 PM   #4
jd20jd
Member#: 131768
2004 WRX
my spacers came with the studs on all 4 corners, Im thinking if it needs to be installed or just use the stocker for now...
Old 11-13-2007, 06:41 PM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
unless the 04 comes with longer studs stock than my 02 I would NOT, NO WAY run a 5mm spacer without fitting longer studs... I could only get about 3 turns on the stock studs with a 5mm spacer
UkNuck is offline   Reply With Quote
Old 11-13-2007, 08:39 PM   #6
remowgn
Member#: 41149
04 09 FXT
SSM
Is it worth having your wheels fall off? I'd definitely install them.
http://www.youtube.com/watch?v=jv4m41viy4I
Old 11-13-2007, 08:58 PM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
It depends on how many turns you can get away with on your stud. If you can geto 8-9 full turns on the stud you're ok.
People forget the depth of the rim center (or where the stud goes through at each hole) varies from each wheel so a 5mm can sometimes be used, sometimes it can't.
rougeben83 is offline   Reply With Quote
WTB: 5mm spacers (2) and 10 mm spacers (2) 5x100 thatkhmer SCIC Private Classifieds 3 11-20-2009 02:36 AM
Autometer gauges, diff lock bolts, H&R 5mm spacers, and dead pedal... CreoWRX Private 'For Sale' Classifieds 14 03-15-2004 03:56 PM
Will WRX wheels fit over sti 4 pots with 5mm spacers?? Rallyspec Tire & Wheel 4 01-22-2004 09:01 AM
Will 5mm spacers require longer studs? Evegan Brakes, Steering & Suspension 2 04-04-2003 03:42 PM
STi 4-pots fit with 5mm spacers w/ stock WRX wheels? CP Brakes, Steering & Suspension 1 05-30-2001 05:08 PM
