Old 11-13-2007, 02:13 PM   #1
Blackmojo
Member#: 137587
2004 WRX Sti
JBP
Default Spark Plug Issue
Ok, so here is a wierd one...
I am the proud second owner of a 2004 wrx sti. Bought the car with 10k miles, changed plugs at 30k service last yr (car actually had closer to 35k by the time I got around to the service). The plugs I got from the dealership were NGK PFR6G SOA part number 22401aa530. Went in yesterday same dealership got NGK ILFR6B SOA part number 22401aa630.
Now when I did my service at 35K I compared plugs and proceeded. Meaning I was paying attention to the fact that the plugs were indeed correct and the same.
How is it that my car came from Subaru with these plugs, which I have been told are for the 2.0l WRX motor? And has anyone else had this issue? Will I have any issues putting the newer, longer plugs in my car?
I do still have the original plugs, at home (currently at my shop), but seriously what gives here?
Blackmojo is offline   Reply With Quote
Old 11-13-2007, 08:55 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
sti plugs are physically longer.
so there would no way your plugs were for a 2.0l motor.
unless the previous owner did something dumb.
part numbers 22401xxxxx are for 04 sti
P is platinum, I is iridum
Old 11-14-2007, 07:57 PM   #3
Blackmojo
Member#: 137587
2004 WRX Sti
JBP
I'm telling you, yes they were. The plugs I have been running for the last 45k were the exact same plugs (NGK PFR6G). The plugs I put in yesterday were 3/8" longer and were the NGK ILFR6B. I have all my parts reciepts and as noted above were the part numbers for the two different plug sets.
Anyway the car hasn't changed the way its running, other than its a little snappier (probably just the butt dyno).
Still curious if anyone else has run into this?
Old 11-14-2007, 09:21 PM   #4
Clayton
Member#: 121184
2004 WRX
It sounds like you were running 2.0L plugs in it previously. Since STI plugs are physically longer than the 2.0l plugs it seems like you finally put the right plugs in there haha...
Clayton is offline   Reply With Quote
spark plug issue subie9022 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-01-2009 10:30 PM
Spark plug issue traffic80 Service & Maintenance 2 05-20-2009 01:53 PM
spark plug warranty issue biohazard06 Warranty Issues & SOA Problems 9 09-22-2007 03:21 PM
Having Issues With Spark Plugs cruzinWRX2 Service & Maintenance 3 11-02-2006 09:53 PM
Spark Plugs, CEL's, Misfires, and UTEC issues JayGold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 04-16-2003 01:35 PM
