Old 11-13-2007, 03:56 PM   #1
jcayos
Member#: 94471
2003 WRX
Default Open Ecu?
Hey guys, I have a reflash question. The shop that I go to, has problems flashing my ECU, the guy keeps getting the Cannot get Kernal message. He has reflashed many EVO's, and newer WRX models without a problem, so he knows what he is doing. I bought the Tactrix cable for my car, 2003 WRX, can anyone give any suggestions to what is going wrong? Any info would help, or do you all think I should just go with Cobb or a UTEC?Thanks.
Mods
Greddy FMIC
FP 18G, 8CM
PE 650 Injectors
Walbro Fuel Pump
Cobb Catless Downpipe
HKS Uppipe
HKS Carbon Ti Catback
Perrin Short Ram Intake
Blitz BOV
Tien Flex Susp.
Hallman Pro Boost Controller
Koyo Radiator
jcayos is offline   Reply With Quote
Old 11-13-2007, 04:41 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
If your car is used the previous owner may have had a ECUTek license on the ecu, this would prevent him from being able to reflash the vehicle. You will need to goto a shop with a ECUTek license to check though. Otherwise the guy could have been trying to put the wrong year reflash on your vehicle too.
Old 11-13-2007, 11:29 PM   #3
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
Might be how your starting it up. ECUFlash gets picky about the exact time and order you do things.
Step by step..
Flash block connected, Map loaded in ECUFlash, hit the flash button and hold up at the dialog screen.
Get the key in the position just before it turns on, no lights or anything yet.
Put the cursor over the "OK" Button, turn the key and hit the "OK" button immediately following.
If you wait too long, it will give you the error you have. You can actually hit the button a little before and it will still work. You can also get that error if you don't have the extra block installed on the 02-03 cars.
It's just picky. Have one hand on the key and one on the button, ready to click "OK" and it should work. If not, something is wrong elsewhere.
/Brox
Broxma is offline   Reply With Quote
Old 11-14-2007, 12:07 PM   #4
Master2192
Member#: 83254
98 2.5 RS
04 WRX
^^^You don't have to be that fast (also its a lot easier to just hit the enter button...). IIRC you have like 3 seconds to hit the ok button and that only applies on 02-03 ecus, the rest you can wait forever.
Old 11-14-2007, 01:13 PM   #5
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
On mine, if I am not Johnny on the spot with it, it fails. I don't even get close to 3 seconds. If I had that much time i could turn the key and have time to look over the laptop and hit the button, but I literally have to do it two handed, one on the key, and one on the "OK" Button.
/Brox
Old 11-14-2007, 04:37 PM   #6
MasterKwan
Member#: 98961
2003 WRX
That's how I do it too. Key, Click.
Old 11-14-2007, 11:31 PM   #7
jcayos
Member#: 94471
2003 WRX
Thanks guys for all your help and info, I am going to the tuner tomorrow and will keep you all updated. I am the only owner of the car, so it is probably the timing thing, I hope.
Old 11-15-2007, 01:36 PM   #8
JMS77
Member#: 136833
Here you go-
1.Hit the "Flash to Ecu" button(a pop up box will appear) BEFORE you turn the key to the ON position
2.Turn key to ON position
3.HIT Enter to activate the flashing process
This assumes the Green connectors and Jumper is in place.
If you tun the key to the on position and the car goes into the Test Mode cycle, before you hit the Flash to Ecu button, you will get the error.
Hope this helps.
JMS77 is offline   Reply With Quote
Old 11-16-2007, 12:28 AM   #9
jcayos
Member#: 94471
2003 WRX
ok guys, we got it to work, but the only thing now is we don't have data logging software. I tried downloading one that was posted up on a previous post, but it did not work. Is EcuExplorer the only data logging software there is for a 2003 wrx or is there any other ones. Another question, when done tuning do I disconnect all the wires or do I leave any plugged in, and does anyone have a base map for my setup that they would not mind sharing? Sorry for all the questions, just want to make sure we are doing every thing correct. Thanks again.
Old 11-16-2007, 01:21 AM   #10
veightkiller
Member#: 78967
2011 335i
enginuity have a logging software same with ecuedit but you have to pay for ecuedit.
veightkiller is offline   Reply With Quote
Old 11-16-2007, 11:47 PM   #11
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Okay so I had a very similar problem today at the tuner. He tried getting it to flash but no dice.
Stock ECU, basically stock car, had AP but unmarried and sold it. He pulled my file but nothing past that. Said something about a problem with 02 WRXs?
If it helps any, my voltage is NOT where it is supposed to be. IDK why, but we had the multimeter and it doesn't meet the program's requirements.
imma_stocker is offline   Reply With Quote
Old 11-19-2007, 06:29 PM   #12
veightkiller
Member#: 78967
2011 335i
so he can pull your stock map but he can't flash it with a new map? is everything connected underneath the steering wheel?
Old 11-19-2007, 06:49 PM   #13
bboy
Member#: 56468
04 Improved STI
Dirty White
Try the 1.30 version of EcuFlash instead. I've found it works better for some of the older ECUs. I have no idea why.
Old 11-20-2007, 01:02 AM   #14
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
exactly. The program requires a small voltage window from one of the connectors, but my car puts out something way off. Something some 02s and 04s have.
Open ECU Opinions St0k3d Commercial ECU Reflashes 47 01-08-2007 07:31 PM
Open Ecu? brandonbeeb Commercial ECU Reflashes 3 07-16-2006 02:41 PM
Street tuner/Open ECU/Engenuity training P&L Motorsports Inc. Mid West Subaru Owners Club Forum -- MWSOC 52 07-05-2006 11:56 PM
proposal: open ecu flashing project colby Engine Management & Tuning 106 09-26-2005 02:30 PM
