Welcome to the North American Subaru Impreza Owners Club Monday December 29, 2014
Old 11-13-2007, 06:50 PM   #1
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Default Enginuity Logs...And Random Questions
Heres a couple logs from my 02WRX.
2.2L forged stroker
TBE
Up Pipe
Ecutek (I had a rotated kit on it before. car was put back to stock and retuned. i have since added the tbe and up pipe, no tuning.)
To correct this knock do i add fuel or just pull back my base timing map? How do I tell if Im running lean if the AFR is pegging to 11.02 at WOT?
Is there any way to tune the AFR without getting a wideband?
My base timing map seems weird from 4300-4800 (where its knocking), the values jump 10, 9, 11.
When graphing 2D base timing should the curve be linear or have a slight increasing slope, or slight decreasing slope?
Can anyone explain exactly what the Feedback Knock Correction is? Didnt have it on the 1st pull, but had it on the 2nd at 6000rpm.
Thanks In Advance,
Ron
run1
Code:
RPM	LOAD	BASIGN	ADV	IGN	KC	FDBKC	FINEKC	PSI	MAF	MAF	EGT	IAM	INJ	IAT	WSGT	THROT
2555	2.04	37.3	0	30.5	0	0	0	-4.21	42.83	2.62	914	16	13.63	64	13.33	12.94
2621	2.41	27.11	5.27	27	3.5	0	0	-0.73	52.68	2.78	914	16	17.89	64	29.02	24.71
2698	2.92	19.38	8.79	22.5	8.5	0	0	1.74	65.56	2.94	923	16	20.72	64	44.71	33.73
2799	3.53	14.8	8.79	18.5	8.5	0	0	5.22	82.41	3.18	932	16	25.68	64	60.39	49.41
2936	4.27	11.64	9.14	16	9	0	0	9	104.47	3.44	941	16	41.97	64	70.59	61.96
3103	4.78	8.83	8.09	13	8	0	0	13.64	123.61	3.62	950	16	50.97	64	75.69	76.47
3275	4.73	7.77	7.38	13	7	0	0	17.27	129.16	3.66	959	16	55.19	64	74.90	100.00
3438	4.84	7.77	7.38	12.5	7	0	0	17.85	138.62	3.7	986	16	60.15	64	70.20	100.00
3648	4.92	7.42	7.38	12.5	7	0	0	17.85	149.51	3.82	1004	16	66.15	64	63.53	100.00
3842	4.64	7.77	7.38	14.5	7	0	0	17.85	148.56	3.82	1022	16	67.21	64	64.31	100.00
3998	4.59	9.88	7.38	16.5	7	0	0	16.69	152.93	3.84	1049	16	70.79	64	67.84	100.00
4190	4.61	10.94	7.73	16.5	7.5	0	0	16.25	161.02	3.9	1076	16	75.97	64	71.76	100.00
4332	4.75	10.59	8.09	15.5	8	0	0	16.25	171.4	3.98	1103	16	81.34	64	74.90	100.00
4507	4.78	9.53	8.09	14.5	8	0	-1.05	16.69	179.71	4.02	1121	16	87.5	64	77.25	100.00
4678	4.68	9.53	8.44	16.5	7.5	0	-1.05	16.69	182.49	4.04	1148	16	90.83	64	79.61	100.00
4808	4.6	9.88	10.2	17.5	8.5	0	-1.05	16.54	183.95	4.04	1166	16	93.2	64	81.96	100.00
4937	4.6	11.29	10.9	20	9.5	0	0	16.11	189.14	4.1	1193	16	93.74	64	86.27	100.00
5123	4.45	14.45	9.49	22.5	9	0	0	15.53	189.88	4.1	1202	16	95.08	64	86.27	100.00
5244	4.4	17.97	7.73	23.5	8	0	0	14.65	192.48	4.12	1220	16	95.1	64	89.41	100.00
5438	4.23	18.67	8.09	25	7.5	0	0	14.07	191.73	4.12	1238	16	96.3	64	93.33	100.00
5547	4.19	19.38	8.79	26	8.5	0	0	13.49	193.59	4.12	1247	16	95.86	64	97.25	100.00
5664	4.08	19.73	9.14	27	9	0	0	13.06	193.59	4.12	1256	16	94.26	64	100.00	100.00
5769	4.06	20.78	8.79	27	9	0	0	12.62	195.07	4.14	1274	16	94.77	64	100.00	100.00
5891	3.99	21.13	8.44	27	8.5	0	0	12.48	195.81	4.14	1274	16	95.52	64	100.00	100.00
6043	3.87	21.48	8.09	27.5	8	-2.11	0	12.19	195.07	4.14	1283	16	95.4	64	100.00	100.00
6142	3.8	21.84	8.09	23.5	5.5	-6.33	0	11.9	194.33	4.12	1292	16	95.66	64	100.00	100.00
6203	3.77	22.54	8.09	30.5	1.5	0	0	11.75	194.7	4.14	1301	16	93.96	64	100.00	100.00
6276	3.72	22.89	8.44	31.5	8	0	0	11.61	195.07	4.14	1310	16	94.91	64	100.00	100.00
6438	3.64	23.59	8.09	32	8	0	0	11.46	195.07	4.14	1310	16	94.76	64	100.00	100.00
6488	3.62	23.95	8.44	32.5	8	0	0	11.46	196.18	4.14	1319	16	94.11	64	100.00	100.00
6550	3.58	24.3	8.44	33	8	0	0	11.61	195.44	4.14	1328	16	93.62	64	100.00	100.00
6690	3.51	24.65	8.79	33	8.5	0	0	11.75	195.81	4.14	1337	16	94.2	64	100.00	100.00
6720	3.46	25	8.79	33.5	8.5	0	0	11.61	195.07	4.14	1346	16	93.69	64	33.33	100.00
6793	0.28	25.35	9.14	35	8.5	0	0	11.61	193.59	4.14	1346	16	0	64	26.67	100.00
run2
Code:
2053	1.14	35.2	40	0	0	0	0	-4.21	19.64	2.16	1031	16	8.42	68	3.14	24.71
2048	2.01	25.7	31.5	8.09	7	0	0	0.29	33.69	2.46	1022	16	11.18	68	18.82	51.76
2152	2.2	21.84	28.5	8.44	8	0	0	1.6	38.27	2.54	1022	16	15.15	68	37.25	67.45
2223	2.37	19.02	26	8.44	8	0	0	2.9	43.98	2.62	1022	16	16.12	68	52.94	94.90
2321	2.55	16.56	23.5	8.44	8	0	0	4.35	49.32	2.74	1022	16	18.32	68	68.63	100.00
2414	2.87	14.1	21	8.44	8	0	0	6.09	57.77	2.86	1022	16	21.12	68	84.31	100.00
2502	3.19	11.99	18.5	8.44	8	0	0	7.98	66.44	3.02	1022	16	25.62	68	100.00	100.00
2618	3.65	10.94	17.5	8.79	8.5	0	0	10.59	79.74	3.18	1040	16	31.28	66	92.16	100.00
2767	4.17	8.83	16	8.09	8	0	0	14.07	97.75	3.36	1040	16	40.76	66	79.61	100.00
2917	4.82	7.42	12.5	7.38	7	0	0	17.41	116.65	3.56	1058	16	48.08	66	80.00	100.00
3122	4.78	7.77	13	7.38	7	0	0	17.99	122.8	3.6	1067	16	50.52	66	75.29	100.00
3314	4.71	7.77	13	7.38	7	0	0	17.85	130	3.68	1085	16	55.14	66	67.84	100.00
3510	4.73	7.77	13	7.38	7	0	0	17.41	138.32	3.68	1103	16	60.64	66	63.14	100.00
3684	4.73	8.83	13.5	7.38	7	0	0	16.98	145.24	3.78	1121	16	64.44	66	63.92	100.00
3870	4.66	10.23	15	7.38	7	0	0	16.69	150.41	3.82	1139	16	67.69	66	65.88	100.00
4015	4.63	10.94	16.5	7.73	7.5	0	0	16.54	154.88	3.86	1166	16	71.09	66	68.63	100.00
4223	4.64	10.23	16	8.09	8	0	0	16.69	163.29	3.9	1184	16	77.47	66	70.98	100.00
4396	4.69	9.53	15.5	8.09	7	0	-1.05	16.83	171.74	3.98	1202	16	82.53	66	72.94	100.00
4526	4.71	9.88	15.5	9.49	8	0	-1.05	16.83	177.64	4.02	1220	16	86.9	66	74.90	100.00
4699	4.67	10.23	16.5	10.55	9	0	-1.05	16.54	182.86	4.06	1238	16	91.22	66	76.86	100.00
4857	4.55	11.99	19.5	10.2	9.5	0	-1.05	15.96	183.58	4.06	1256	16	92.22	66	80.39	100.00
5027	4.53	15.86	21	9.14	9	0	0	15.24	189.88	4.1	1274	16	95.44	66	84.71	100.00
5154	4.42	18.32	23.5	7.73	7.5	0	0	14.65	189.88	4.1	1274	16	94.56	66	87.45	100.00
5289	4.34	19.02	24.5	8.09	8	0	0	13.93	191.36	4.12	1292	16	95.91	66	91.37	100.00
5474	4.21	19.38	26	8.79	8.5	0	0	13.49	193.22	4.12	1301	16	95.76	66	95.29	100.00
5555	4.17	20.08	26.5	9.14	9	0	0	13.2	193.22	4.12	1310	16	95.99	66	100.00	100.00
5677	4.05	21.13	27	8.79	8.5	0	0	12.62	192.85	4.12	1310	16	95.78	66	100.00	100.00
5827	3.99	21.48	27.5	8.44	8	0	0	12.33	193.59	4.12	1319	16	95.72	66	100.00	100.00
5976	3.91	21.84	27	8.09	8	0	0	12.19	194.7	4.14	1328	16	95.61	66	100.00	100.00
6029	3.88	22.19	28	8.09	8	0	0	12.04	195.07	4.14	1337	16	95.17	66	100.00	100.00
6152	3.8	22.89	28.5	8.09	8	0	0	11.61	194.7	4.14	1337	16	94.5	66	100.00	100.00
6244	3.75	23.24	31	8.44	8	0	0	11.61	195.44	4.14	1337	16	94.58	66	100.00	100.00
6308	3.72	23.59	31.5	8.09	8	0	0	11.61	195.44	4.12	1355	16	94.2	66	100.00	100.00
6488	3.57	23.95	32	8.44	8	0	0	11.46	193.22	4.14	1355	16	94.11	66	100.00	100.00
6516	3.56	24.65	33	8.79	8	0	0	11.46	195.81	4.14	1364	16	94.28	66	100.00	100.00
6678	3.51	25	33	8.79	8.5	0	0	11.61	195.44	4.12	1373	16	94.03	66	100.00	100.00
6690	3.5	25.35	33.5	9.14	9	0	0	11.61	195.07	4.14	1373	16	92.77	66	99.22	100.00
6775	3.44	25.7	34	9.49	9	0	0	11.75	194.33	4.14	1382	16	92.5	66	0.00	100.00
Old 11-13-2007, 07:06 PM   #2
Tea cups
Member#: 103136
Try logging less parameters. I wouldn't worry about the small amount of fine correction near 4000 rpm, but you do have a decent amount feedback correction around 6000-6100 rpm. Try logging only rpm, throttle opening angle %, engine load, manifold relative pressure (corrected), feedback knock correction, fine knock correction and boost error. Feedback knock correction is the closest thing to a knock light, at least as far as what the ecu perceives as knock.
Tea cups is offline   Reply With Quote
Old 11-13-2007, 07:16 PM   #3
Phatron
Member#: 36033
CEO PhatBottiTuning
Updated the logs with less parameters....didnt log boost error.
Why is Fine KC ok? And feedback KC not?
Also, what does boost error tell you?
Would my piston slap from the forged internals cause the knock sensor to register an event?
Thanks
Ron
Old 11-13-2007, 07:21 PM   #4
Tea cups
Member#: 103136
Originally Posted by Phatron View Post
Updated the logs....didnt log boost error.
I didn't mean filter out the logs you already have. I mean doing another log with just those parameters I listed. The sampling rate goes down with each additional parameter you add for logging. This means you will have more useful data if you log the absolute minimum number of parameters you need to get the info your looking for.
Old 11-13-2007, 07:46 PM   #5
benw
Member#: 103320
2005 wingless
aspen white
a cold motor with forged slugs could be noisy, as well as a stock engine for that matter.
feedback knock correction is the immediate reduction in timing due to perceived knock (like merchgod said).
fine learning knock correction is a reduction in timing due to past knock events in that area of the map.
boost error is defined as target boost - current boost. So, if you are set to 18 psi and you are currently boosting 20 psi, you will register a -2 boost error. there are several turbo dynamics tables that manipulate the wastegate in cases of both negative (overshooting your target) and positive (undershooting your target) boost error.
benw is offline   Reply With Quote
enginuity log questions nhat Commercial ECU Reflashes 10 10-24-2007 01:16 AM
Advise on enginuity log JOWANKEL Engine Management & Tuning 21 10-05-2007 06:23 PM
Enginuity logging with AP cable/adapter? NorCal06STi Commercial ECU Reflashes 1 04-17-2007 08:14 PM
Stalling Problem - Look @ my Enginuity Log runvusofme Engine Management & Tuning 3 01-26-2007 02:35 AM
2 odd and random questions for you SE people!!! ooberdoob South East Region Forum 11 11-07-2005 05:38 PM
