Old 11-13-2007, 10:49 PM   #1
alphagoose
Member#: 158302
2010 legacy gt
Default rev limiter
can someone help me to ajust my rev limitor. i want to bring it down some but i dont know how to change the values in enginuity.
alphagoose is offline   Reply With Quote
Old 11-13-2007, 11:05 PM   #2
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
Assuming you know how to find the rev limit tab in enginuity, you want the "on above" number to be higher than the "off below".
IF you want a 6900rpm limit, then the "on above" is 6900K, the "off below" would be 6850.
this is how I have mine set and it works....just don't mix them up...it will turn it off completely
Wheeler Bement is offline   Reply With Quote
Old 12-27-2007, 09:31 PM   #3
oscarmayer
Member#: 33863
2001 rs2.5
silver/champaign
but that makes you below the stock rev limit. stock is 7k-7200. (on my sti.)
oscarmayer is offline   Reply With Quote
Old 12-28-2007, 01:10 AM   #4
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Math is hard.
07 stage 2, ecu limiting boost 8-7 psi after hitting rev limiter Varanont Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 09-26-2007 03:27 PM
Rev limiter crazy? car revs att 5k!! Stealth_RS Normally Aspirated Powertrain 14 04-13-2006 09:58 AM
rev limit, launch rev idea.... 80884 Proven Power Bragging 49 06-24-2004 09:29 PM
Car feels like it hits the rev limiter when it's not hitting the rev limiter Tainted Transmission (AT/MT) & Driveline 21 01-09-2002 01:21 PM
('93-'01) What kind of Rev limiter? Layman Impreza Forum 5 05-19-2001 01:27 AM
