Old 11-13-2007, 10:30 PM   #1
JDMG3
Member#: 137792
1997 Legacy Outback
Green
Default My Legacy Outback STI V4 Story
This might not be the most chosen platform for perfomance aplication but I initially got that car just its practicality. AWD, ABS,Heated seat, lots of space for the Dog and camping equipment and not to expensive with 280 000Km on the clock. Go the car for 1 week and I spun a crank bearing on the original engine. put in another EJ25 from Japan this time. Its suppose to be good and more reliable than the american one. I drove it one year and it blew a head gasket. F%$*!!! I was pissed.
I came around a good deal that was posted on the board for a STI V4 EJ20K that was completly rebuilt with V6 bottom end parts, a V2 tranny, a suretrack rear diff and wrx rear brakes. I also purchased a 3in turbo back exaust (catless) and a TD05 turbo.
Here are some pics.
parts I got, and a catback 3in SS exaust for 150$
I adapted my 2.5 engine harness to the V4 engine and then i cut my ecu connectors, after 6 hours I finished splicing the wires to the new ecu.
JDMG3 is offline   Reply With Quote
Old 11-13-2007, 10:31 PM   #2
JDMG3
Member#: 137792
1997 Legacy Outback
Green
took everything outta the car
then i put the new powertrain in....
relocated the cruise control vaccum pump and actuator
I had to cut my clutch reservoir and relocate my bypass valve since I am using a V6 tmic. you can also see the new location for my wastegate selenoid. I put it there since I used the original EGR wires to hook it up.
go myself a cheap 3in bellmouth down pipe mounted to a TD05
installed my exaust, 3in turbo back and it makes an awsome sound
I finally heres an Outback you dont see often
...Conclusion all that is left is changing the gears in the rear diff. since its wienning like crazy and and getting my STI suspension. No problem with the engine what so ever, it runs great and cant wait for the break in period to be over.....;-)
Ian
Old 11-13-2007, 10:38 PM   #3
JDMG3
Member#: 137792
1997 Legacy Outback
Green
I will also try to make cleaner.....here was my last project....
Old 11-13-2007, 11:33 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
nice why take the vf-23 out for a td05?
Old 11-13-2007, 11:41 PM   #5
JDMG3
Member#: 137792
1997 Legacy Outback
Green
turbo did not come with the engine.....unfortunatly
Old 11-14-2007, 12:43 AM   #6
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
I thought my wagon was a sleeper.....that thing would make vipers and corvetts look like waist of money if you did a stand alone, inj, and raised the boost a couple of psi
snowman4us is offline   Reply With Quote
Old 11-14-2007, 01:54 AM   #7
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I thinks my dad's '98 Outback needs a stronger motor too.
FuJi K is online now   Reply With Quote
Old 11-15-2007, 09:58 AM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
All you need now is the underhood duct for the hood scoop!
Marnix is offline   Reply With Quote
Old 11-15-2007, 11:00 AM   #9
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Awesome! Green outbacks are like the plain janes of the Subaru world... Total sleeper
Old 11-19-2007, 10:32 AM   #10
sti-zy wagon
Member#: 88109
1999 Legacy w/STi V4
"Hunter" Green
awesome swap. Complete sleeper. Very close to my own legacy wagon, but you get me with the outback part, hahaha. Congrats on adding to the sti swapped legacy wagon club
sti-zy wagon is offline   Reply With Quote
Old 11-20-2007, 10:53 PM   #11
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
Looks like my Outback (only lower with smaller tires and a tiny engine that makes more juice than my 2.2 )
Old 12-14-2007, 12:01 PM   #12
JDMG3
Member#: 137792
1997 Legacy Outback
Green
update.....
Got some STI V7 struts and installed them( Iknow the pic has a V8 strut but I went to exange it later)
It took like 16 hours to get all the body pacers out and to change all the parts from outback to regular leg parts like tranny cross member, drive shaft and hagner bearing , struts(V7), steering colum and shaft, shifter assembly, trailing arms, sway bar mounts etc... Naturally this is quebec and the bolt where mostly all rusted and seized.
sand blasted a few parts and painted a few also..
i had to relocate the windsheild washer hose in the hood weebing so it would clear the intercooler and bypass valve
I installed wood trim from the wrecked LegGT I bought and Boost gauge in a Homemade with exaust gauge pod!
Cheers....more updates to come cauz i got JDM Headlights, tail lights, tweeters and front grill in the mail!
i dunno if this will work but here is the sound of the exaust witch I think sounds pretty nice
Click here to watch Subbie-Exaust
Old 12-14-2007, 05:10 PM   #13
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Cool project, and it sounds like you found a clever way to tackle the wiring. Your car is very well preserved for over 280km!
jamesfacts is offline   Reply With Quote
Old 12-14-2007, 05:59 PM   #14
Kraziken
Member#: 38629
1999 Legacy GT (STI)
Nice,
I like to think my swapped Legacy is a sleeper, but I think I have too much bling now. Your Outback is a true sleeper.
Nice job.
Kraziken is offline   Reply With Quote
Old 12-21-2007, 03:34 PM   #15
draco356us
Member#: 24795
2003 WRX Wagon
Don't know how I missed this, but that is one nice sleeper. In fact maybe too nice, now I have to make sure my wife doesn't find this otherwise I'll never hear the end of it.
draco356us is offline   Reply With Quote
Old 12-23-2007, 11:42 AM   #16
scrape
Member#: 163720
2001 Legacy Outback
i want to swap my 01 limited so bad. Youre definitely inspiration
scrape is offline   Reply With Quote
Which Intake for my Legacy Outback? Al_Smokemcrack Legacy Forum 24 05-30-2008 09:55 AM
lowering springs on my legacy outback spdracr00 Legacy Forum 10 12-21-2004 01:18 PM
('93-'01) Busted Hand Brake In My Legacy Outback SubaruLover Impreza Forum 5 06-14-2001 12:17 AM
Help.....Busted Hand Brake In My Legacy Outback SubaruLover Legacy Forum 1 06-13-2001 07:19 AM
Busted Hand Brake In My Legacy Outback SubaruLover Mid Atlantic Impreza Club -- MAIC 0 06-10-2001 08:17 PM
