Old 11-14-2007, 12:07 AM   #1
rallyrab
Member#: 145844
Default fp green/2.0...round 2
last summer i finally did the turbo swap that ive wanted to do for about 3 years now, i put a 2.4/7cm ewg green on my 02 wrx along with 750cc injs and large top mount along with all other supporting mods...tbe, up pipe, inlet and fuel pump with the ap to finish it off, i took it down to agile and did a few runs, the car made 311 whp and 245wtq at 18 psi which wasnt too bad due to a terrible boost leak out of my oldschool txs bov.....
.....so after doing this swap ive figured out the weak points of everything ive done and im ready to start again, this time im goin with the greddy fmic instead of an ebay tmic and im gonna get rid of the tumbler valves and get a recirc bpv that hopefully wont leak
id really like to get a tune with race gas but im not sure what to be running, any opinions on whats good to use.....?
i cannot wait to get started....after everything is done id like to push it to 23,24 psi and see what the green is really capable of
rallyrab is offline   Reply With Quote
Old 11-14-2007, 01:48 AM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
are you asking what type of race fuel or what EMS you should be running?
fastnoypi is offline   Reply With Quote
Old 11-14-2007, 02:21 AM   #3
Silver_Bell_WRX
Member#: 7677
2005 WRX
How is the Green on the 2.0l I was thinking of maybe going this route eventually. About when does the boost come on?
Silver_Bell_WRX is offline   Reply With Quote
Old 11-14-2007, 03:29 PM   #4
SUBOO5
Member#: 85825
08 EVOH10
in like sin!
SUBOO5 is offline   Reply With Quote
Old 11-14-2007, 03:33 PM   #5
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
18 psi isn't anything on that turbo, you need to turn the wick up on that thing. IMO, I'd research some other front mounts besides greddy.
SBW is offline   Reply With Quote
Old 11-14-2007, 06:22 PM   #6
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
FP Green is a lot of fun, full boost is around 4500-5000 rpm depending on what gear you started in. I recently tuned a 05 WRX Wagon with FP Green, Greddy FMIC, Spec C Intake Manifold, PE800s, and headers with catless TBE, . Using a UTEC with Speed Density I turned it up to 24 psi on 92 octane and the car flat out moves. If I get a chance I will be touching up the tune this weekend on the dyno and see what kind of power it is really making.
BTW the headers and Spec C manifold made me add 12% more fuel to get AFRs back to where they were before the installation of those mods. TGV deletes and good headers would be advised when pushing the limits on this turbo. You will need a Big MAF intake to push 24 psi on this turbo, I hit 5.0 volts maf at 6200 rpm but since it was UTEC SD this wasn't a problem.
Old 11-14-2007, 07:18 PM   #7
rallyrab
Member#: 145844
yea sorry i was wondering what type of race fuel i should be running, my friend uses vp and loves it...just lookin for some opinions on what everyone is running in the wrx for a race fuel map
and like master said, boost comes on roughly around 4000 in 1st and maybe a little later in higher gears but it hits soo hard when it does, i love that feeling so waiting til 4k is worth it ha
i wanted to turn the boost up a bit more but with my bov leaking, it wouldnt have been the best of ideas until thats fixed...so im thinkin ill start at 22 or something and work my way up, id love to hit 360whp and somewhere close on the tq........all in all i love the green on my car, highly recommended!!
Old 11-15-2007, 08:53 AM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you may have mentioned it already, but which headers?
ken
Old 11-15-2007, 01:04 PM   #9
Master2192
Member#: 83254
98 2.5 RS
04 WRX
ken
The owner tells me they are GT Spec headers.
FP Green, SZ 49, Blouch 2.5 R on Stock internals k22addict Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 02-21-2009 12:21 PM
2.0 to 2.5L with blown 2.0 ecu????? AUTO DjKlown UTEC 1 11-20-2008 07:58 PM
FS/FT: FP GREEN 8cm 0 SHAFT PLAY mannyOlicious Engine/Power/Exhaust 8 10-24-2008 02:01 PM
FP Green fitment problem on 2.5block gotawd Subaru Conversions 11 11-28-2005 12:25 AM
FP Green Spool up on 2.0L WhiteKnight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-18-2004 04:19 PM
