#1 |
Member#: 162567
There was no good answer. Being told it wasn't possible to being told it is. Well, after looking around all you have to do is ground a piece that connects to the E-Brake. For those who have no experience, don't worry I don't either. I took all pictures after it was all done, but the parts I'm missing aren't all that important.
Also, I do not advise watching a movie while driving. Let the passenger do all the work! What you need: 22Ga Wire 22Ga Quick Connects 22Ga Ring Terminal Wire Strippers Crimper There may be easier ways but, this is how I did it. 1) Take the E-Brake Boot off ![]() 2)Open the Counsel Thing and unscrew the 2 screws ![]() 3)Unscrew the screw that holds the entire piece in. ![]() 4)Slightly life up to unlatch the front part from the shifter part. Slide trim backwards. (The white thing on the top part of it holds the thing in hence why you have to slide it backwards) Then just lean it on back seat to keep it out of your way. ![]() 5) Unscrew the shifter, take trim off. Undo all inside stuff if you wish. I took mine out when I installed short shifter and never saw the need to put it back in. (No pictures here) 6) Make room so you can work around the E-Brake. (Picture is blurry and to lazy to go unhook everything again) 7) Locate a plastic piece that latches on to the E-Brake. It should have a gray wire with it. You can take this part out and leave it with all your other car stuff as it isn't needed but since I already have a messy enough place I decided to leave it there and crimp a connector on if I ever decide to sell the car I'll just hook it back up to the E-Brake. ![]() 8) Since radio shack didn't have any 22ga ring terminals I just soldered a 22ga wire on to a 10-12ga terminal and crimped that. I put on a connector on the other end. (Picture shows me using a smaller wire, I think in my car it self I have it atleast twice as long.) ![]() 9) Crimp on the other connector to the gray wire. ![]() 10) Now I just used the other side of the screw where the black thing was latched on to for the ground, I took that off and put the ring terminal on and put it back all together. ![]() 11) Connect the gray to the new grounded wire and viola you now have a full functional navigation system! ![]() Sorry for the poor video. Driving and taking a video + shifting = not so great video/driving/shifting. Hopefully this takes care of all those how to bypass the new Nav system!!!
#2 |
Member#: 95195
W. Canada
Vehicle:1974 Rat Rod Bug back and white |
yeah you also have a constantly on ebrake light..... i guess, why not put it on a switch and leave the ebrake hooked up and diode isolate the two so that you still have ebrake functionality and it isnt constantly bypassed, then you can flick the switch off and have it work like normal incase the po-po pulls you over and tries to fine you
#3 |
Member#: 63390
Vehicle:2004 Impreza WRX Wag |
Sweet no side effects? The MPG and other engine/car management functions still work? Navi doesnt twig out like some Legacy Navi people mentioned?
What about the Brake light in the gauge cluster does this remain lit all the time now? |
#4 |
Scooby Scammer- Do Not Buy From User
Member#: 132902
Vehicle:2006 wrx tr silver 99 BMW 323is |
I guess there is a good possibility that since most factory radios are built by aftermarket companies the ebrake wire might be separate in the radio harness(rather than getting a data signal from the bcm). It would be worth a try to pull the radio and take a METER not a test light and meter any unidentifiable wires in the harness and see if any of them go negative or change status whatsoever when you pull that ebrake. If so then just isolate the wire and replicate the change be it positive, negative, 100k resistor,ect. whatever.
#5 |
Member#: 95195
W. Canada
good call hector, i will test the wifes harness next time i have it in the shop and see what i can find!
#6 | ||
Member#: 162567
Also, how could a po-po fine me for such a thing? Quote:
As I stated earlier, this was just a quick fix for those wanting to bypass the system. At least this opens up a window for people to talk about other ideas. |
#7 |
Member#: 95195
W. Canada
I dont know about the US, but up here in canada it is up too a $2500 fine for watching a video while driving, there is one at least one person i know who got this fine for watching a DVD while he was driving. so yeah...
I like hectors Idea better, if you could some how find the wire behind the deck and diode isolate from there with a switch you would never have the ebrake light come on unless the ebrake it self was on. just take a multi-meter and find the wire that changes when you pull on the ebrake, (test with car running) and then make a switch to replicate the same action, with that then you could still have the full functionality of the ebrake system and also have a switch and your ebrake light wouldnt be affested. switch on to watch DVD's, if police pull you over a simple flick of the switch and your back to the factory system. |
#8 |
Member#: 162567
I've been pulled over a couple times when I had my Impala. I had my I-Pod set up when I was on my long road trips and I ended up getting pulled over twice going each way. They saw the Ipod and asked what movie was playing but didn't say anything other than that. Was let off for speeding 5-15 over each time. Maybe luck but knowing that you can get fined in Canada will certainly make me want to put in a switch as I might be driving to Calgary soon.
#9 | |
Member#: 42242
TXIC
Vehicle:2006 STI White |
#10 |
Member#: 162567
Well, I've never had any of my cars inspected and that was when I was living in MN. Not sure what CO laws are as of yet, but I am going to put in a switch since its an easy deal
#11 |
Member#: 137918
TXIC
Vehicle:2005 G35 Diamond Graphite |
wouldn't your ebrake light always be on?
#12 |
Member#: 162567
Yes it would always be on if you didn't incorporate a switch between the connection going to the new ground. All you need would be two extra crimps if you did it right away instead of doing it after. If you did it after all you have to do is get two new wires, crimp a connector on each end and there ya go. When you don't need the functions just flip the switch and the brake lights off. But I haven't really noticed the light either way.
#13 | |
Member#: 44912
SWIC
Vehicle:2007 BMW 335i White |
#14 |
Member#: 44912
SWIC
Has anyone else done this yet?
#15 |
Member#: 54597
Vehicle:08 'Busa, 08 ML63 10 Multistrada, 996 Targa |
FWIW, I would recommend grounding in the head unit harness, rather than at the e-brake itself. At the e-brake will cause the whole car (DCCD, cluster, etc) to believe the e-brake is pulled, and requires you to install a switch, etc. Grounding in the head unit only tricks the nav system.
Here's what I did: http://www.iwsti.com/forums/2008-sti...ml#post1723696 |
#16 |
Member#: 11652
E. Canada
Vehicle:'11 STI 5dr Red '70 Porsche 914/6 |
Grounding the ebrake would also disable the DRLs, no?
#17 |
Member#: 54597
#18 |
Member#: 173217
Vehicle:2008 WRX Obsidian Black Pearl |
OK, everyone is on track with the behind the radio harness idea.
I did yhis and works great. NO E-Brake Light!! See Here: http://www.webjogger.com/WRX/2008WRX/08wrxnav.htm |
#19 |
Member#: 173217
Might as well attach a pic as well, but see above!!
| Thread Tools | |
| Display Modes | |
| Full DIY: GM solenoid install (56k warning) | Freon | Engine Management & Tuning | 489 | 10-19-2012 01:05 AM |
| Nevada Road Trip Pics (Book, Pics, 56k warning) | RHayes | North West Impreza Club Forum -- NWIC | 8 | 07-08-2008 08:01 PM |
| Turbo XS Gasket Damaged? (a few large pics; 56K warning) | lethal.adv | Factory 2.0L Turbo Powertrain | 2 | 03-24-2006 07:13 PM |
| NASA AutoX Pics 5-23-04 (heavy 56K warning) | InfamousDX | Tri-State Area Forum | 20 | 05-24-2004 11:52 PM |
